Old 12-30-2013, 04:44 PM   #71
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Originally Posted by LBC Por Siempre View Post
This Pan is not a Sump correct?
This oil pan is a sump - it is not a dry sump. though
Pitman is offline   Reply With Quote
Old 12-30-2013, 05:24 PM   #72
LBC Por Siempre
LBC Por Siempre's Avatar
Drives: 2008 Toyota Prius, 2012 911 Turbo
Sorry, I wrote that early in the morning before I had my Methadone - yes dry sump.
One of the big issues with the new 3.8 Flat 6 Porsche is putting in their new 911s is they are all "Integrated Dry Sumps". Whatever in the hell that is suppose to mean.
Most of us would rather see the life of the 3.6 liter derived GT1 engine live on and on but the replacement is this engine called the 9A1. I mean take all the provenance out of it won't cha`?
Which brings to question how much bigger can you make this engine? Sharkworks, an after marker tuner for Porsche motor coaches, has a kit they install that takes the GT1 engine from the GT3 motor and bumps it up to 500 horsies from 3.6L to 3.9L plus an extra 200 RPMS. They won some super prestigious award for aftermarket tuners too for their class. There are other kits out there that go up to 4.0L and 4.1L but none of them have the Mass of kits installed and running flawlessly on American roads. Besides the larger engines are derivatives of IMSA or whatever engines to the reliability isn't really there.
But the furthest thing from my mind at the moment is pulling the motor and cracking it open to up the displacement. I just want some nice and neat installation spitting out 275WHP-285WHP. And if you know any one who can do that for me let me know.
I really need a reason to buy an Air Compressor and some impact wrenches.
LBC Por Siempre is offline   Reply With Quote
Old 12-30-2013, 09:37 PM   #73
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by cf6mech View Post
Nice,....very nice,...you guys are heading off issues before they even arrive for most of us,....or have you figured this out already on a test bed car?,....I know oiling is or will be an issue with this engine as people start pushing its limits. Also the cooling benefits will be a big plus with the increased capacity and fins,...an issue well documented.
Oiling will always be a disadvantage on boxer style motors due to gravity. The older EJ motors did not use a upper pan and relied solely on the lower pan.
Under extreme load, G's and acceleration. The oil is pumped to the heads and whipped around not giving it a chance to return to the pan fast enough.
I believe the OEM have figured that out and that is why the FA motors have an upper and lower pan to keep the oil supply near the moving parts.
The upper pan is also very wide compared to the lower pan. There for, it is recollecting oil a lot easier than the EJ did.
The EJ20 has a 4.8qt capacity and the FA20 has 5.8qt capacity for an NA motor. That is a clear indication that subaru realized there was an oiling problem on their early design.
FullBlown is offline   Reply With Quote
The Following 6 Users Say Thank You to FullBlown For This Useful Post:
cf6mech (12-31-2013), Creole (09-26-2014), ftc~brz (03-31-2014), JackSmiley (01-04-2014), SilverSkyline210 (01-04-2014), SmsAlSuwaidi (12-31-2013)
Old 01-04-2014, 04:25 PM   #74
jx86
Drives: -
Curious to know roughly when this will be available for sale, if it will be compatible with the Greddy Turbo kit, and how much it might cost... Might hold off an installation just for this!
jx86 is offline   Reply With Quote
Old 01-04-2014, 04:54 PM   #75
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Hoping to have somsomething in 30-35 days. The mould is almost done.
The Following 2 Users Say Thank You to FullBlown For This Useful Post:
JackSmiley (01-04-2014), normancw (02-13-2014)
Old 01-04-2014, 09:54 PM   #76
SilverSkyline210
SilverSkyline210's Avatar
Drives: WRB BRZ
I'll buy one
Originally Posted by FullBlown View Post
We are excited to announce that we will be offering an aftermarket oil pan very soon.
The days of drilling and tapping the oem pans are soon to be over. We have sold many pre-tapped pans up to date. Being that this platform is so new, the dealers have a limited supply on hand and we find ourselves occasionally waiting for stock
Also, it didn't make sense to design and produce a pan just for the oil return port. There for, we decided to engineer our oil pan with additional features to make it worth doing.
The design is done and we should have a plastic protoype within a week. From there, we will verify fitment and then head right into production.
Key Features
* 50% more oil capacity vs OEM
* Aluminum casting to ensure high quality consistency
* Heat Sink Fins on the bottom to help remove heat
* 1/2" Return Port for oil return from Turbo/SC
* Bolt in baffle to reduce starvation on hard turns and acceleration
Price $TBA
The baffle is removable and will wrap around the oil pickup
Here is an example of a cast part that we produced.
SilverSkyline210 is offline   Reply With Quote
Old 01-25-2014, 01:39 AM   #77
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Any updates on this pan?
crook (01-25-2014)
Old 01-25-2014, 08:24 AM   #78
crook
crook's Avatar
Drives: storm black GT
^^^this, may aswell through it in with my other order you guys are doing up at the moment for me n Jordan :p
crook is offline   Reply With Quote
Old 01-25-2014, 01:59 PM   #79
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I will let you guys know when it is ready
The tooling is being made to produce this right now.
Captain Snooze (01-25-2014), Nomed Alucard (01-26-2014)
Old 01-26-2014, 04:56 PM   #80
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Special introductory pricing? ....maybe?
Old 01-26-2014, 05:07 PM   #81
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We always offer an introductory price
The Following User Says Thank You to FullBlown For This Useful Post:
Bach415 (01-26-2014)
Old 02-13-2014, 01:26 AM   #82
jx86
Drives: -
Any updates on this?
Sent from my SM-N9005 using Tapatalk
Old 02-13-2014, 01:34 AM   #83
FullBlown
FullBlown's Avatar
Drives: Scion FRS
not yet sorry, it is in motion but we are expecting something soon.
Old 03-16-2014, 11:01 PM   #84
Mathewgzlz
Mathewgzlz's Avatar
Drives: 2013 SCION FR-S FIRESTORM RED
Bump
Mathewgzlz is offline   Reply With Quote
FRS Die-cast model encity5 Scion FR-S / Toyota 86 GT86 General Forum 75 02-24-2019 01:15 PM
Expensive, but cool Die Cast GT-86 Kimsey47 Scion FR-S / Toyota 86 GT86 General Forum 25 11-26-2013 06:12 AM
FS: Die-cast EBBRO 1/43 frs 86 blanco Miscellaneous 4 09-25-2013 11:42 PM
Durability of cast wheels AsianStyle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 12-06-2012 06:10 PM
Any Disney Cast Members here? MF_DEUCE Off-Topic Lounge [WARNING: NO POLITICS] 9 11-18-2011 02:48 AM
