Old 01-18-2014, 07:58 AM   #57
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Originally Posted by Brianbajnauth View Post
And also the trunk popper. After a few mins of sitting it doesn't work
The same thing happened to me until I got the 2nd bypass. Every time I would start then turn off my car the door locks and trunk release would work for about 10 min then my Advanced Key Fob would stop working. I installed the bypass for my door locks and my problems went away. Now it works perfect every time.
This is the bypass I used for my door locks.
milkesfrs is offline   Reply With Quote
Old 01-18-2014, 09:03 AM   #58
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Same bypass as the other one, right?
kmbkk is offline   Reply With Quote
Old 01-18-2014, 09:18 AM   #59
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Yes, its the same. You will need to flash one bypass with the TB firmware and the other bypass with the DL firmware.
The Following User Says Thank You to milkesfrs For This Useful Post:
kmbkk (01-18-2014)
Old 01-19-2014, 09:25 AM   #60
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Originally Posted by Sniper2606 View Post
Jesus all that work for just a push to start?
Well everybody has their flavor.
I would of got a BRZ limited.
Regardless goob job
Believe it or not I learned a lot by doing this Mod. It help me learn where everthing is located inside the car. My friend has an M/T FRS and it would not start. I looked and seen his clutch switch plug was cracked and came loose. I had it fixed in less than 5 min. Saved him a trip to the dealer and some cash.
charged86 (01-19-2014)
Old 01-19-2014, 12:10 PM   #61
Brianbajnauth
Drives: Scion frs firestorm
Deffinatly learned me a lot too!!!
Trust me!
Is there anyway to bypass or unplug the factory alarm system? I believe the factory alarm system is arming the car after the door has been shut for 10 mins. Could I be right? Doesn't hurt to try/ experiment. Lol
Brianbajnauth is offline   Reply With Quote
The Following User Says Thank You to Brianbajnauth For This Useful Post:
milkesfrs (01-19-2014)
Old 01-19-2014, 12:11 PM   #62
Brianbajnauth
The clutch bypass switch is located above the kick panel to the right. The second switch up.
Old 01-19-2014, 01:37 PM   #63
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Trust me!
You are exaclty right about the factory alarm system is arming the car after the door has been shut for 10 mins. Your FRS CPU is looking for the right encrypted code from the key fob you are using to let it know its OK to open the doors. Unless your Neo you will not brake the code. All new Subarus and the FRS need the 2nd bypasses to klone the encrypted code and send the code through the viper to open door / unlock door . You did the Viper install correctly. Get the 2nd bypass, flash the door lock firmware hook it up to your Viper 5704 and you good to go.
As far as disabling the OEM secruity feature you would need to ask the dealer to do this. I dont know if they can even do this or solve your problem.
Old 01-19-2014, 06:51 PM   #64
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
If you go to the Subaru dealership and ask for that Push start button and it's panel that comes with it... can you swap that button for the TRD push button?
914_WHITE_FRS is offline   Reply With Quote
Old 01-19-2014, 07:19 PM   #65
Brianbajnauth
How much for a bypass?
Old 01-19-2014, 08:30 PM   #66
milkesfrs
milkesfrs's Avatar
Drives: hot lava
50.00 for the bypass. 40.00 for the cable to flash the module. Go to your local alarm shop and they can flash it for about 10 bucks
Old 01-19-2014, 08:35 PM   #67
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Yep, the TRD will work. You can get it on ebay
Old 01-19-2014, 11:36 PM   #68
Brianbajnauth
Damn that's pretty expensive! No other options?
Old 01-19-2014, 11:43 PM   #69
914_WHITE_FRS
If I were to go get the panel and push button, If i take it to a shop where the know how to do remote alarm systems. Could they be able to do it without all those extra stuff u had to buy in the internet? What should I let them know what they need to do to get it working?
Old 01-20-2014, 01:08 AM   #70
E.T
Drives: Toyota 86 & Subaru BRZ
Far out well done haha.
E.T is offline   Reply With Quote
DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) Chaetagnath DIY (Do-It-Yourself) Guides 225 09-03-2017 06:20 PM
Advanced Keys for GT owners..? luv85 Australia Classifieds 10 10-22-2013 07:48 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Advanced Keys Inc + Viper 5904 Iddoit2er Electronics | Audio | NAV | Infotainment 5 02-24-2013 03:50 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
