Drives: Subaru BRZ - GBS
Engine cut out/stall followed by CEL
Hey guys/gals,
I warmed the car up as usual leaving a friends house tonight, and then slowly coasted (clutch in) to the end of the cul-de-sac to turn around. My engine then cut out and stalled, and failed to start after hitting the start button right after the stall. Then I waited 5-10 seconds and it started, but was very rough at first and lit up the CEL. It sounded like the engine wasn't getting fuel, but I had been idling for 3-5 minutes prior to that, and also had just over 1/2 tank of gas. Anybody else had something similar? I will be pulling the code with a friends reader tomorrow, but wanted you folks insight and/or experiences in the meantime. |
#2 |
Drives: Scion FR-S
Yeah, I had that problem before, and my car is automatic. lol You might want to go back to the dealer to get your ECU flashed.
| The Following User Says Thank You to TOTO_86 For This Useful Post: | Mr.EvoMR (01-13-2014) |
#3 |
Yep, good idea to read the code.
Maybe it just "hiccupped" and it righted itself and it will be OK. Keep us posted. humfrz |
#4 |
Thanks for the replies, it looks like it cleared itself this morning. Seems like it was some type of failsafe that might have triggered, I'll post any codes I get later today or tomorrow morning.
#5 |
The code that was thrown was P0108, which is a high intake pressure reading from the MAP sensor. Not sure why, I do have a Perrin intake tube, but stock intake. I have checked all the hose clamps, but all are tight and there are no leaks.
| Stall/Torque Converter | DeOppressorLiber | Engine, Exhaust, Transmission | 44 | 06-12-2014 01:00 PM |
| 1st gear + 0 Acceleration: Will not stall | TIE Pilot | Engine, Exhaust, Transmission | 40 | 10-19-2013 02:18 AM |
| Stall in high G turn/oversteer spin | DR J | Engine, Exhaust, Transmission | 23 | 06-04-2013 02:54 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 07:50 AM |
| Partial Stall's WRB | Partial Stall | Member's Car Journals | 3 | 06-07-2012 07:53 PM |
