#29 |
Drives: GT-86
let me know what key you use when the door locks when u walk away? and when u start do you need the key in ignition?
#30 |
Drives: Scion frs firestorm
I don't have push button start I have the regular key with the unlock/lock, panic and truck pop. I do have to put the key in the ignition
#31 |
Now w/ over 400 womprats!
Drives: BRZ LZR
If you made a step by step DIY, I would love you forever.
I have had one of these kits sitting in my closet for several years now and I have never gotten around to installing one due to the lack of proper instructions and my own lack of skill when it comes to wiring. I originally bought it for one of my old Supras, but when I realized how daunting the install would have been, I decided to put it away and revisit it later. Sooooooo, I'm definitely sub'd.
- The Ancient BRZ Sacrament by Zaku |
| The Following User Says Thank You to Guff For This Useful Post: | MaXimus (02-29-2016) |
#32 | |
Drives: Scion FR-S Ultramarine
#33 | |
Drives: hot lava
You need add another idatalink for the door locks or its not going to work. |
#34 |
Drives: hot lava
#35 |
Drives: hot lava
#36 |
Drives: hot lava
#37 |
Drives: hot lava
#38 | |
Drives: hot lava
| The Following 2 Users Say Thank You to milkesfrs For This Useful Post: | Guff (01-14-2014), the new guy (01-14-2014) |
#39 |
Drives: BRZ Limited [37J]
Awesome work.
#40 |
I have installed everything (viper 5704) and it work perfect
Just a few questions. The door locks- it works for about 10 mins and then stops working. I don't have a bypass module for the door locks. Maybe I tapped into wrong wire? Where is it located and wire color? Thanks so much for the help so far |
#41 | |
Drives: hot lava
Power Unlock = pink wire located on the driver kick panel, white 22 pin plug, pin 15 I could not get my door locks to work for my setup without the second bypass module. The FRS has its door lock circuitry controlled by the car’s computer data bus. In order for the remote start Fob to integrate with and control the door locks (which may be necessary in order for the remote car starter to interface with the vehicle’s security system) a Door lock bypass module is needed. If you remote start first the fob will work. After the car shuts off the car’s computer data bus will time out after 10 or 15 min and you fob won't work anymore. My fob did the same thing until I got the bypass. |
#42 | |
I just finish hooking up my viper 5704 today. The only way to get the power unlocks/ lock is to tap into those same wires that you stated and to disable the factory alarm. The trunk poper, door unlock/lock, the remote starter, everything works perfect!!! Thank god! Only thing left to do is to hook up my window module. Btw can I get both left and Right side window motor from the driver side door Panel? If so what color wires? |
| DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) | Chaetagnath | DIY (Do-It-Yourself) Guides | 225 | 09-03-2017 06:20 PM |
| Advanced Keys for GT owners..? | luv85 | Australia Classifieds | 10 | 10-22-2013 07:48 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 03:45 PM |
| Advanced Keys Inc + Viper 5904 | Iddoit2er | Electronics | Audio | NAV | Infotainment | 5 | 02-24-2013 03:50 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 04:44 AM |
