Old 01-12-2014, 03:20 PM   #29
J-Money
J-Money's Avatar
Drives: GT-86
let me know what key you use when the door locks when u walk away? and when u start do you need the key in ignition?
J-Money is offline   Reply With Quote
Old 01-12-2014, 08:20 PM   #30
Brianbajnauth
Drives: Scion frs firestorm
I don't have push button start I have the regular key with the unlock/lock, panic and truck pop. I do have to put the key in the ignition
Brianbajnauth is offline   Reply With Quote
Old 01-13-2014, 05:53 PM   #31
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
If you made a step by step DIY, I would love you forever.
I have had one of these kits sitting in my closet for several years now and I have never gotten around to installing one due to the lack of proper instructions and my own lack of skill when it comes to wiring. I originally bought it for one of my old Supras, but when I realized how daunting the install would have been, I decided to put it away and revisit it later.
Sooooooo, I'm definitely sub'd.
- The Ancient BRZ Sacrament
by Zaku
The Following User Says Thank You to Guff For This Useful Post:
MaXimus (02-29-2016)
Old 01-13-2014, 07:01 PM   #32
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
man if i had the money to buy all this i'd write a complete diy for everyone.... but dems da brakes... (see what i did there? haha)
phanguy is offline   Reply With Quote
Old 01-14-2014, 04:24 PM   #33
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Originally Posted by trueno86power View Post
Got a question for you sir!
I've installed a regular remote start on a Scion FR-S. I've used only 1 Idatalink bypass and well everything work fine!
The only thing that still bug me it's the door lock. I try to control them via the door lock switch harness but the module don't seem to pulse right for the BCM.
You need add another idatalink for the door locks or its not going to work.
milkesfrs is offline   Reply With Quote
Old 01-14-2014, 04:25 PM   #34
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Originally Posted by kmbkk View Post
Thank you for this write-up! I plan on tackling this in a month or so. I'm sure I'll hit you up for questions once I get closer.
Sure thing
Old 01-14-2014, 04:27 PM   #35
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Originally Posted by Brianbajnauth View Post
I want to install a viper alarm/remote starter. Do I need 2 bypass modules ( key transponders) like you stated for your install? Thank you
Yes, you will need two. No way around it . I tried
Old 01-14-2014, 04:28 PM   #36
milkesfrs
milkesfrs's Avatar
Drives: hot lava
No keys are needed once you install the system.
Old 01-14-2014, 04:30 PM   #37
milkesfrs
milkesfrs's Avatar
Drives: hot lava
If you don't have the push to start button you will need to use your key.
Old 01-14-2014, 04:33 PM   #38
milkesfrs
milkesfrs's Avatar
Drives: hot lava
I try to write something up ASAP.
The Following 2 Users Say Thank You to milkesfrs For This Useful Post:
Guff (01-14-2014), the new guy (01-14-2014)
Old 01-14-2014, 06:05 PM   #39
BunnyRZed
BunnyRZed's Avatar
Drives: BRZ Limited [37J]
Awesome work. It was hard work, but I got the BRZ Limited that came with the Push Start and called it a day
BunnyRZed is offline   Reply With Quote
Old 01-16-2014, 01:15 AM   #40
Brianbajnauth
I have installed everything (viper 5704) and it work perfect
Just a few questions. The door locks- it works for about 10 mins and then stops working. I don't have a bypass module for the door locks. Maybe I tapped into wrong wire? Where is it located and wire color? Thanks so much for the help so far
Old 01-16-2014, 05:14 PM   #41
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Power Lock = blue wire located on the driver side kick panel, white 22 pin plug, pin 16
Power Unlock = pink wire located on the driver kick panel, white 22 pin plug, pin 15
I could not get my door locks to work for my setup without the second bypass module. The FRS has its door lock circuitry controlled by the car’s computer data bus. In order for the remote start Fob to integrate with and control the door locks (which may be necessary in order for the remote car starter to interface with the vehicle’s security system) a Door lock bypass module is needed.
If you remote start first the fob will work. After the car shuts off the car’s computer data bus will time out after 10 or 15 min and you fob won't work anymore. My fob did the same thing until I got the bypass.
Old 01-17-2014, 12:29 AM   #42
Brianbajnauth
I just finish hooking up my viper 5704 today. The only way to get the power unlocks/ lock is to tap into those same wires that you stated and to disable the factory alarm. The trunk poper, door unlock/lock, the remote starter, everything works perfect!!! Thank god! Only thing left to do is to hook up my window module. Btw can I get both left and
Right side window motor from the driver side door
Panel? If so what color wires?
DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) Chaetagnath DIY (Do-It-Yourself) Guides 225 09-03-2017 06:20 PM
Advanced Keys for GT owners..? luv85 Australia Classifieds 10 10-22-2013 07:48 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Advanced Keys Inc + Viper 5904 Iddoit2er Electronics | Audio | NAV | Infotainment 5 02-24-2013 03:50 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
