Old 12-28-2013, 01:23 PM   #43
the.big.kahoona
the.big.kahoona's Avatar
Drives: 2013 Raven 86
Originally Posted by teamturbo View Post
Just ebaying around, anyone know if this kit would fit the FR-S?
http://www.ebay.com/itm/WILWOOD-SUPE...4881b4&vxp=mtr
No it won't
Sent from my SM-N9005 using Tapatalk
the.big.kahoona is offline   Reply With Quote
The Following User Says Thank You to the.big.kahoona For This Useful Post:
teamturbo (12-28-2013)
Old 12-29-2013, 12:13 AM   #44
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
So any updates?
Jmonty is offline   Reply With Quote
Old 12-29-2013, 12:23 AM   #45
MeFryRice
Drives: '13 SWP BRZ
For ~$3100, I don't think it's bad for a set of Alcons, probably because I've seen a couple friends buy a set for their GT-R...
MeFryRice is offline   Reply With Quote
Old 07-02-2014, 11:54 PM   #46
jng
jng's Avatar
Drives: Toyota 86
Anyone else running the Alcon 6/4 BBK have any comments (and pictures), namely whether it is extreme brake overkill + heavy on a non-FI setup?
Currently already upgraded to StopTech SS lines and Street Performance pads on stock rotors, and could consider just getting better rotors and higher temp hybrid / track pads for the track to get more hot laps in. But, am just toying with the idea of the Alcon BBK (front 6pot 365mm disc / Rear 4pot 343mm disc/drum assembly) as an option, mainly for the looks , and better stopping power on the track.
Thanks.
jng is offline   Reply With Quote
Old 07-26-2014, 08:05 AM   #47
jng
jng's Avatar
Drives: Toyota 86
Way too much brake for my little car.
Front: Pictured with Enkei RS05RR 18x8.5, Yokohama Advan AD08R
Rear: Pictured with KW v3
The Following 3 Users Say Thank You to jng For This Useful Post:
Anthonytpt (06-30-2015), CSG Mike (02-19-2015), ultra (07-05-2015)
Old 07-26-2014, 11:47 AM   #48
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
If you are presently running the AD08Rs on the track, try some A005s - I think you will find that they will be a better match for the brakes.
dradernh is offline   Reply With Quote
Old 07-26-2014, 02:09 PM   #49
Boxer486
Drives: small
So who's going to put together a Radi-Cal kit for the 86?
Boxer486 is offline   Reply With Quote
Old 07-26-2014, 08:09 PM   #50
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Just to continue this train of thought...
Here's a link to the CP8522 Radi-Cal caliper (smallest of the 3 sizes that AP produces):
http://www.apracing.com/Drawings/CP8522-2~5S0_CD.pdf
You can see that it accepts a rotor up to 410 mm x 36 mm. That's their biggest rotor they produce, and not necessarily what we'd want. 16" is overkill for well... anything.
If you can identify the ID of the stock wheel, we can calculate the max rotor size:
Max rotor OD = Wheel_ID - 2*clearance - 2*(OD of caliper - max rotor position)
= Wheel_ID - 2*3mm - 2*(30mm)
If we conservatively assume that there is 1/2" from the bead contact zone to the ID of the wheel...
That calculates down to 340 mm. The nearest standard disc sizes are: 343, 330, 325, 315. The standard widths available are: 36, 32, 28, and 25.4.
For the sake of argument, let's got with 325 x 36.
You can do "float in disc" or "float in bell" mounting if you wanna get floaty. Typically you want to float in the disc though. I'm not completely sold on it... but I guess you can also use their new "strap drive" mounting method which further decouples the rotor from the bell:
Here's a link to the bell specs:
http://www.apracing.com/drawings/cp2494-2000CD.pdf
They state that the bells are typically 6.5mm thick, and use 1/4" fine-thread bolts. Bobbins for the chosen disc are CP2494-504MP. This is the "P" type. Washers are CP2494-1305. Nuts are CP2494-117.
Mounting the caliper and spacers for the bell are more complicated calculations than I feel like doing at the moment. It does seem do-able though, if you really want to run them. We'd need specs on the OEM wheels and the OEM mounting holes.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 08-02-2014, 06:57 AM   #51
BRZ888
BRZ888's Avatar
Drives: 2014 Toyota GT86
Hello!
I just purchased a set of the Alcon Extreme 6/4 pot caliper. Do you have any idea where we can buy the spare brake pads for front and rear? Do you know the brand or model of the existing brake pad?
I want to keep an extra set to make sure that it will be readily available when i need it someday.
Thank you!
BRZ888 is offline   Reply With Quote
Old 08-05-2014, 11:42 AM   #52
jng
jng's Avatar
Drives: Toyota 86
Originally Posted by BRZ888 View Post
Hello!
Thank you!
The brake pad that came with my kit is the Ferodo DS2500 pad. I think this is the one that comes from the UK, so yours should be the same if you purchased the kit (blue box with Toyota86/BRZ/GT86 on the printed sticker label).
Old 01-22-2015, 04:41 AM   #53
BRZ888
BRZ888's Avatar
Thank you for your reply! My rear Alcon caliper leak and it came from the piston seal. Do you know where can i buy the piston seal?
Old 02-12-2015, 05:38 AM   #54
86Toyobaru
Drives: 86 & GRB
AP, Brembo and Alcon are all nice brake. But dont forget Japanese brand like Endless and projectMu. If I have budget for BBK, the Endless will be my first choice
86Toyobaru is offline   Reply With Quote
Old 02-19-2015, 01:45 PM   #55
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
Originally Posted by Supermassive View Post
I have the Wilwoods on my car and they are just and inch bigger in diameter than stock but are 6 piston. They feel amazing but I hardly ever really push these brakes as I am not running this car in any endurance races.
I'm interested in Wilwoods 6 pistons for a non-track car.
I was told that there may be issues with VSC or ABS.
Did you experience some problems like that , specially on wet condition on tricky roads ?
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 06-08-2015, 10:53 AM   #56
Supermassive
Supermassive's Avatar
I didn't notice anything odd about them, ABS seemed to work fine, and VSC didn't throw any curveballs my way either.
Supermassive is offline   Reply With Quote
The Following User Says Thank You to Supermassive For This Useful Post:
banane63 (06-11-2015)
FS: Wedssport TC105N 18x8.5 +43 & Alcon 4 piston Calipers Gambit Australia Classifieds 26 05-11-2014 09:38 PM
Will an Alcon wrx kit bolt-on to BRZ/FR-S?? spiller Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 11-07-2012 12:38 AM
