Old 11-03-2012, 09:30 PM   #1
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
Will an Alcon wrx kit bolt-on to BRZ/FR-S??
Hi guys I'm looking at purchasing a second hand Alcon mono4 street brake kit for my "twin". The kit was sold to suit a wrx 2002-2007 and the seller claims it is compatible with the brz/fr-s.
I know the STi Brembos bolt on so theroreticly all of the bracketry and rotors should be compatible with this kit. I am unsure about the brake lines though and also didn't realise that the wrx shared the same 5x100 stud pattern with the brz.
Can anyone offer any insights?
spiller is offline   Reply With Quote
Old 11-03-2012, 09:32 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
read up on Sri bremno threads front should work after swapping bleeders to the other side (unless the pistons are equal size then just flip the caliper). But I think the rears are lgt brakes, but I don't remember exactly.
spiller (11-06-2012)
Old 11-04-2012, 05:08 AM   #3
spiller
So the bleeder needs to be at the top or the bottom?
Old 11-04-2012, 05:14 AM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
Top.
Old 11-04-2012, 05:16 AM   #5
spiller
Originally Posted by Calum View Post
Top.
Sorry for the newb question but why is this necessary? For the record these Alcon calipers have different sized pistons.
Old 11-05-2012, 11:37 AM   #6
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
The Impreza brake calipers are mounted on the rear side of the hub. So if you swap them to a BRZ then the bleeder valve will be on the bottom. If the bleeder valve is on the bottom you will not be able to bleed air out of the brake system, because air rises to the top.
Ranatsu is offline   Reply With Quote
The Following 2 Users Say Thank You to Ranatsu For This Useful Post:
Calum (11-05-2012), spiller (11-06-2012)
Old 11-05-2012, 12:57 PM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Air goes up. If the bleeder is at the bottom you'll never remove all the air from the system. You can flip them just for bleeding but that's a pain in the butt.
If the alcon stuff is differentially bored then you'd mount the left alcon WRX one on the right side of the BRZ, right WRX on left side of the BRZ and switch the transfer tubes from the top to the bottom and bleeders from the bottom to the top, basically similar to what you do with the STI calipers. This assumes the alcon's are external transfer tubes, if they are internal, and there's no ports on the other end for switching the bleeders, then you either run them with the differential bores backwards (not the end of the world, but I wouldn't do that) or get something designed for the car, or that can be made to work.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Old 11-06-2012, 03:43 AM   #8
spiller
Dave thanks for explaining, makes sense. What is the sinificance of the differential bores? Do they need to be in a particular order? I'm pretty sure these calipers have internal transfer tubes but the bleeders are reversible according to the seller.
Old 11-06-2012, 04:16 AM   #9
OrbitalEllipses
Drives: Attitude
Uneven pad wear will occur if the bores are in the wrong order. STI Brembo calipers are differentially bored so the right and left side must be swapped to get the pistons in the right order on each side; following this the bleeders must be swapped from bottom of the caliper to top. Sounds like the same process on the Alcon units.
Old 11-06-2012, 04:57 AM   #10
spiller
So if the bracketry is to suit an impreza, technically it should match up to the brz if it is also swapped to the opposite side with its corresponding caliper?
Old 11-06-2012, 05:46 AM   #11
OrbitalEllipses
Drives: Attitude
Knuckles are the same as the Impreza, or should be. Impreza bolt holes fit the Brembo calipers, with new bolts. Alcon calipers should bolt up on either side, the dynamics of the pistons and bleeders is what requires switching sides. That car had heavy front bias...not sure why you wouldn't want to just sell the Alcons and buy something meant for this car.
Old 11-06-2012, 07:25 AM   #12
spiller
Oh for sure, I know the heavy front bias was an issue for the WRX but I wasnt planning on leaving the rear brakes stock. I would probably do the STi rear brembo upgrade to balance things out a little but tbh I havent done any bias calculations to work out what the % would be. The kit is available very near new second hand at about half price. TBH I cannot justify spending 4K + on a brake upgrade for this car at the moment as its not really required. I was having a hard time justifying the alcon kit as it was but wanted to ask the questions here. I will probably just do the STi brembo upgrade when the time comes as at least that is a matched kit front to rear.
Old 11-06-2012, 07:49 AM   #13
OrbitalEllipses
Drives: Attitude
Math has already been done; rear STI Brembo calipers will move bias forwards. Ask @jamal.
Old 11-06-2012, 06:46 PM   #14
spiller
Math has already been done for the STi front and rear kit you mean?
Camber Bolt Help Please! ft86Fan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 114 02-27-2019 11:13 AM
FS: Wedssport TC105N 18x8.5 +43 & Alcon 4 piston Calipers Gambit Australia Classifieds 26 05-11-2014 08:38 PM
Bolt-ons + Tune Power? industrial Engine, Exhaust, Transmission 54 09-05-2012 09:53 AM
Crash bolt question ayau Tracking / Autocross / HPDE / Drifting 8 08-17-2012 01:22 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
