Old 12-19-2013, 03:39 PM   #2003
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Originally Posted by *LongFella View Post
Hopefully, the 255 doesn't look too massive and over power the 18x8 rim... LOL!
Well, you should consider to lower the car (if not done already) as it will look a bit offroadish on stock suspension
Killerbee is offline   Reply With Quote
Old 12-19-2013, 03:42 PM   #2004
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Definitely! Just planning a simple Eibach pro-kit to get rid of the gap...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 12-19-2013, 03:42 PM   #2005
Killerbee
Killerbee's Avatar
Got that setup aswell and can only recommend it. Good choice!
Old 12-19-2013, 03:44 PM   #2006
*LongFella
*LongFella's Avatar
Well, I did read through your car build/journal to see what you were running. Love the rim/tire look you have!!!
Old 12-21-2013, 09:22 AM   #2007
Kody
Drives: 2013 Subaru BRZ
Question about 17x8 PF01 with 235/45-17 on Tirerack
So after a lot of research on these forums I've come the realization that I want to to purchase the Enkei PF01 (17x8) with Michelin Pilot Super Sport Tires (235/45ZR17).
I will be ordering these from Tirerack.com. The problem arises when I try to add the tires after choosing the wheel. Their site won't let me pick the super sports in conjunction with the PF01's, I can only choose from a small variety of tires similar to the Dunlop Direzza Z2's. I have to manually add the wheel then go back and pick the tire as a separate order.
The fact that tirerack says these won't fit well confuses me because I've seen many others with very similar or exact setups. Is there some aspect of this wheel/tire combo that I'm missing?
Also, how would 225/45-17's do on 8" wheels? I'm trying to avoid messing with the speedometer as much as possible.
Thanks for your time!
Kody is offline   Reply With Quote
Old 12-22-2013, 03:23 PM   #2008
olorin
olorin's Avatar
Drives: GBS Premium
Which Michelin PSS would fit best on 18x8.5? I'd love to do 235/35 R18 but that is not an option. I could go up to 245/35 or do 235/40 with a bit more diameter. Or what other tire options that would be fairly equivalent to the PSS?
olorin is offline   Reply With Quote
Old 12-22-2013, 07:36 PM   #2009
Killerbee
Killerbee's Avatar
I'm just giving you some figures here, but you have to decide for yourself what fits your style.
235/45/17 is way off. Thats about 3% off from factory diameter, and ads about 9mm of additional tire flank to your car. If you go for 235 tires, take 235/40/17, thats just 1% off and -2.5mm tireflank from stock.
225/45/17 is about 1.5% off, and adds 4.5mm to the tireflank. So you could do that aswell.
Another option may be 245/40/17, thats 0.4% off and adds 1.5mm to the tireflank.
Make sure however you get a proper offset on your 8" wheels. something in the +35 range would be ideal (depends a bit on what tire you are planning to use
245/35/18 is the best choice if you want to go as near to stock diameter as possible. Make sure however you get a offset on your wheels of about +35 as long as you are not planing/running on coilovers
Old 12-22-2013, 08:04 PM   #2010
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
How about 17x9 +45 with the car lowered on RCE yellow springs? Tires would be 245/40/17 to keep it close to stock.
Nevermore is offline   Reply With Quote
Old 12-22-2013, 08:13 PM   #2011
Killerbee
Killerbee's Avatar
That should rub on the struits/inner fender. You need to get a +35 offset, or some 10mm spacers (or coilovers:-)
Old 12-22-2013, 08:17 PM   #2012
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Is there any way to do it without rubbing or poking? I saw another member's car with 17x9 +35 and they poked slightly. I want it to be as flush as possible, but to avoid rubbing. And I think +45 is the only offset for the wheels I like.
Old 12-22-2013, 08:17 PM   #2013
olorin
olorin's Avatar
Drives: GBS Premium
I have KW V3, would I still need an offset? The wheels are +44
Old 12-22-2013, 08:28 PM   #2014
Killerbee
Killerbee's Avatar
See my answer below. I "guess" coilovers would be the only solution to achive what you are looking for.
I'm not 100% sure on that, however from what I saw on the forums it should work with coilovers since the strut on coilovers is narrower than the stock ones, so there is more space available.
But I leave this question to a coilover owner to answer, since I lack the experience to answer it correctly :-)
Old 12-23-2013, 01:42 AM   #2015
Racer X
I have an FR-S with stock wheels and height. For the next year I want to keep it that way except to use spacers to get the tires out to flush, especially the rear wheels. I am considering using 30mm rear and 20mm front spacers, however, I do not want to risk tire rub. The forums are confusing as to how much spacer can be used for stock wheels and height because most threads also talk about lowering? Anyone have the answer for stock wheels and height?
Racer X is offline   Reply With Quote
Old 12-23-2013, 08:50 AM   #2016
jshadeck
jshadeck's Avatar
Stock wheels and stock height, run no risk of rubbing w spacers
jshadeck is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
