Old 12-10-2013, 01:54 AM   #15
Originally Posted by Rayme View Post
Well there's a big difference between 12.0 and 12.5!
12.6 is a fully charged battery. 12.0 flat is a battery needing a charge. But we're all waiting on OP to boost 'er up and see what happens.
Yep, I agree ....
Some reading for the OP:
http://www.aa1car.com/library/battery_runs_down.htm
Please let us know when you get er cranking again.
Old 12-10-2013, 08:27 AM   #16
B_Rad
B_Rad's Avatar
Drives: 2013 Scion FR-S/Raven Black/6 sp mt
Gonna put a different battery in it today after work. Pretty sure you are all right. It was dead and I pulled it and gave it a charge.
For the mods I am on Airlift airstruts. Which after some reading last night is known to pull a small amount of voltage when off, and they recommend putting a trickle charger if your car is going to sit for an extended periord of time. The battery doesn't have enough amps to kick the compressors on now either.
Planned on upgraded the factory battery this spring anyway so I guess it will just be sooner now.
B_Rad is offline   Reply With Quote
Old 12-12-2013, 08:33 AM   #17
B_Rad
B_Rad's Avatar
Nope no click, been super busy with work and have been unable to get the battery load tested. I was going to use the battery out of my xb to try and start it but some a-hole engineer decided to put a battery with the positve on the right side of the battery. Which makes it backwards to all the batteies I currently have.
Old 12-12-2013, 08:41 AM   #18
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Like everyone else said put a battery charger on it or jump start it with another vehicle to verify if that's the problem. If that doesn't do it try tapping on the starter with a screwdriver while somebody tries to start it. Pretty unlikely on a new car but its possible for the starter to get stuck and tapping on it will free it up.
kask2_6.0 is offline   Reply With Quote
Old 12-12-2013, 10:32 AM   #19
Mikem53
Drives: FR-S 6MT
Sitting for weeks.. Well jump the thing and it will start..
Mikem53 is offline   Reply With Quote
Old 12-12-2013, 11:16 AM   #20
frslee
Just drive it
Drives: 13' FR-S
your youtube clip's title makes our car look bad... Did you try jump start?
frslee is offline   Reply With Quote
Old 12-12-2013, 02:04 PM   #21
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Why complicate things? Use the xb to jump the Toyobaru, it's a fifteen minute operation max. Hell have a buddy over if you don't have the xb anymore (why would you keep a good battery?) and get something to eat, go for a drive afterwards.
You probably don't need a new/upgraded battery, you just need to take care of your car and understand what it needs when you modify it away from OEM.
ineedyourdiddly
Old 12-13-2013, 01:06 AM   #22
Originally Posted by kask2_6.0 View Post
........... try tapping on the starter with a screwdriver while somebody tries to start it. Pretty unlikely on a new car but its possible for the starter to get stuck and tapping on it will free it up.
Oh, I wish ..... but I think the days of "tapping" on things to get them to work has almost come to a close.....
Like tapping on:
* starters (stuck solenoid)
* voltage regulators (stuck points)
* carburetors (stuck float)
* electric fuel pumps
* automatic choke (butterfly stuck)
* radio
* gauges
* horn relay
* various light bulbs
strat61caster (12-13-2013)
Old 12-13-2013, 08:21 AM   #23
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Like tapping on:
* radio
* gauges
* horn relay
lol true.. but it still works for a starter!
Old 12-13-2013, 09:20 AM   #24
Foobar
SLO NO MO
Foobar's Avatar
Agree with everyone else here - jumpstart the FRS from your XB. The stock battery isn't very good in my opinion. It drops below the level necessary to provide cranking way too soon, and once the battery has gotten to that point, its life degrades from there and only gets worse.
Old 12-13-2013, 09:45 AM   #25
Mikem53
Drives: FR-S 6MT
The 12.5:1 CR requires some good cranking amps to overcome..
Old 12-13-2013, 09:45 AM   #26
guysmiley
Sideways and Smiling
guysmiley's Avatar
+1 on the battery being the likely culprit - start there, easiest fix, 95% likely your problem.
guysmiley is offline   Reply With Quote
Old 12-14-2013, 02:50 AM   #27
Poodles
Drives: 2015 Series.Blue
Have to deal with this stuff all the time at work.
Amps and capacity are different. You can have a very tiny battery with a crazy amount of amps, but very little capacity (Those tiny Odyssey batteries come to mind). These cars appear to have a pretty small capacity battery in them to begin with.
After that, you have it sitting for quite a while, and modern cars do have power drains (alarm, clock, ECU, etc).
Now add to that being cold (less amps) and simply temperature changes causing the charge to degrade, and yeah, it's not going to start.
Just because the battery is low on charge, doesn't mean it's bad! Just charge it and go. Running the battery down to nothing (leaving the lights on overnight, etc) can damage the battery, but as you had over 12 volts, it sounds like it's fine.
Old 12-28-2013, 04:21 PM   #28
B_Rad
B_Rad's Avatar
Updated see first post!
Weird sounds and liquid dripping from car kam Issues | Warranty | Recalls / TSB 21 05-07-2014 08:01 PM
car making weird noises after 19" tires installed riironman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-17-2013 11:28 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
