Old 12-05-2013, 07:46 AM   #15
FR-S Matt
I'll follow up again with my service rep about this. I'm in the same boat as the OP. Toyota is realizing that this pump is STILL not working 100%. I'll be one of the first on the list for the next revision. It's not fun going to car shows with a box of crickets under your hood.
I had the SU003-05176 installed and crickets came back in 250 miles. It's no good. Both this pump and my pump from a year ago always chirped. I'm at 12.6k miles.
Old 12-05-2013, 07:57 AM   #16
5AD86D
5AD86D's Avatar
Originally Posted by Tromatic View Post
Depends on how you count it. Original pump, then came the second pump, and IIRC there was a mod to that one after it chirped. This will be pump four, I think. Noting wrong with mine, other than it chirps every now and then. I'll keep that one until a proven fix is out.
To help you guys on this one...no there is NO fourth pump. This will basically be the 3rd attempt to get it right. Hope we all see the new one soon.
5AD86D is offline   Reply With Quote
Old 12-05-2013, 08:05 AM   #17
5AD86D
5AD86D's Avatar
Original pump being the 1st attempt
Old 12-05-2013, 08:41 AM   #18
cnk
Drives: '13 DGM BRZ Limited
There has to be a pump close to the engine to maintain the 3,000+ psi required for current direct injection systems. This isn't a Toyota thing, many manufacturers have similar systems, and to be fair none of Toyota's systems sold in the 86 have failed at all.
I understand the reason for the hpfp. My point is that if the engine only ran port injection, there would be no need for the hpfp. Other cars with hpfp's don't chirp so yes, it is a Toyota D4S thing. And just to be clear, I know D4S exists on other cars. I'm referring to the fact that it's a system designed by Toyota and obviously poorly designed for our cars. I have not heard chirping on an is350 or gs350, both have D4S systems.
Sent from my Transformer using Tapatalk 4
Old 12-05-2013, 09:21 AM   #19
Muskokan
Drives: white Sport-tech
Wait, since when has the oct 17 tsb been deemed a failure? Almost all good things about this one. I've gone over 4k on mine since getting it and not a chirp.
Muskokan is offline   Reply With Quote
Old 12-05-2013, 11:52 AM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
*moves hand*
This is the fuel pump you are looking for.
The Following 5 Users Say Thank You to King Tut For This Useful Post:
Anomie (12-10-2013), ericmpena (12-07-2013), flippy (12-16-2013), jdubz13frs (04-19-2014), OrbitalEllipses (12-05-2013)
Old 12-05-2013, 11:55 AM   #21
Tromatic
The problem seems to be totally random, which must make it very hard to determine the actual cause. I still think it's cavitation related to water content.
Old 12-05-2013, 11:56 AM   #22
ZionsWrath
Thanks
ZionsWrath's Avatar
Maybe I rev too high but I never hear "chirps" only the clicky type normal DI sound at idle. I have a first US shipment car.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Guzic (12-17-2013)
Old 12-05-2013, 12:15 PM   #23
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I never went in for service because there no permanant fix. I will wait and see...hate going to stealership
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
ZionsWrath (12-05-2013)
Old 12-05-2013, 12:21 PM   #24
samisons
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
Hopefully I get the new one as I was ordered one two weeks ago otherwise I should wait and see. It's only a minor annoyance.
samisons is offline   Reply With Quote
Old 12-05-2013, 12:39 PM   #25
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
Originally Posted by cnk View Post
You can blame Toyota for their D4S system. The only reason the HPFP is there is for the DI system. However, keeping the HPFP cool probably has nothing to do with reducing the crickets because if that were the case, there should be fewer complaints when the temps drop.
My chirps are highly affected by ambient tempurature. When its hot out, once i reach operating tempurature the chirps are constantly happening at idle. When its could out, the chirps come and go
lickitysplit is offline   Reply With Quote
Old 12-05-2013, 12:57 PM   #26
cnk
Mine are consistent no matter what the temps. Once the engine is all warmed up, they manifest.
Old 12-05-2013, 01:00 PM   #27
lickitysplit
Don't care
Interesting. I'm on what i believe is rev.2, I got mine replaced early september. Wonder if thats the difference.
Old 12-05-2013, 01:09 PM   #28
cnk
I'm on the original pump and won't replace it until there is a confirmed fix with more than a few months of use and a couple thousand miles under it's belt.
The Following User Says Thank You to cnk For This Useful Post:
IMPORTANT QUESTION AZOOZ_95 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 08-21-2013 03:44 AM
Important: DBA Rear Rotors (BRZ/FR-S) FRS2000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-17-2013 09:08 PM
**IMPORTANT ISSUE****READ THIS****NEED YOUR HELP** fred864 Issues | Warranty | Recalls / TSB 33 04-20-2013 01:57 AM
Color, how important is it to you? Iixii BRZ First-Gen (2012+) — General Topics 63 11-09-2012 11:25 AM
How important is an LSD on this car? colHolm Scion FR-S / Toyota 86 GT86 General Forum 92 05-13-2011 06:53 PM
