Old 11-30-2013, 04:03 PM   #1
636
636's Avatar
Drives: '23 CWP BRZ
FRS Foglight Switch?
So I just got my hands on a Nigel-JDM foglight kit, without the stalk. I'm generally "alright" at wiring, but confused about one part. I understand the harness and all that, but the switch. I'm not sure how to go about hooking that part up, and also, do we know if I can buy a replacement dash piece with an extra hole for the fog light button?
This is the piece I'm looking for.
And here is what I'm confused about.
Do the two parts I have a line drawn between connect? And also, what's this red open-wire for?
Here's everything I have.
Thanks guys.
636 is offline   Reply With Quote
Old 12-01-2013, 01:23 PM   #2
MrMarinakos
Drives: Asphalt Monogram Fr-s
https://www.toyota-parts.com/product...ch-Bezel/-617/
switch bezel you're looking for
but for your question i have no clue :P
MrMarinakos is offline   Reply With Quote
The Following User Says Thank You to MrMarinakos For This Useful Post:
636 (12-01-2013)
Old 12-01-2013, 02:21 PM   #3
aSaki
When you open the panel piece on the driver side, there is a white connector that is taped up and not connected to anything. That is where you connect your switch, but that button has 4 pins so I don't know which one goes where, you would have to test that yourself.
aSaki is offline   Reply With Quote
The Following User Says Thank You to aSaki For This Useful Post:
636 (12-01-2013)
Old 12-01-2013, 02:46 PM   #4
636
636's Avatar
Drives: '23 CWP BRZ
Thanks guys!
Old 12-01-2013, 05:40 PM   #5
assbox
assbox's Avatar
Drives: Whiteout FRS
can u explain further? i am currently trying to install this fog light kit. I have the lights mounted, that was the easy part. but i do not understand the wiring still. can any one elaborate?
IG: ft86carbon
assbox is offline   Reply With Quote
Old 12-01-2013, 06:52 PM   #6
assbox
assbox's Avatar
if you could possible post pictures of how you wired everything up, it would be greatly appreciated. im kinda stuck at the moment.
IG: ft86carbon
Old 12-01-2013, 07:31 PM   #7
try2findmark
Drives: Bukkake FR-S
Yes those two ends do connect. Its nice cause its kinda like an extension but bad since its sorta cluttered. Anyway you need to find a power source for that red wire, in my case i used the ignition(green wire). Heres a link of where to tap that red wire to: http://www.ft86club.com/forums/showt...=27366&page=27
And you should be set :]
try2findmark is offline   Reply With Quote
Old 12-02-2013, 12:16 AM   #8
636
636's Avatar
Drives: '23 CWP BRZ
Do you have a better link? Or any pictures of how to? I'm still lost. >.<
Old 12-02-2013, 12:33 AM   #9
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
Take off the plastic panel to the left of your dash/steering wheel (the panel faces your door). Then you need to tap the red wire from the switch to the green wire on the harness.
in that picture, they used an alligator clamp to splice the red and green wire together (in order to feed power to the switch).
the ground wire from the switch (black with the metal circle at the end) needs to make contact with a screw from this area.
as you can see here.
If you take the panel off, all of this will look familiar to you.
Old 12-02-2013, 01:03 AM   #10
636
636's Avatar
Drives: '23 CWP BRZ
I see, but as far as the other harness goes. I still wire it up to connect to the headlights? As if I was installing the foglights to turn on whenever my headlights turn on, correct?
Old 12-02-2013, 01:20 AM   #11
m.box.design
I didn't wire mine that way. I just wired mine straight from the fogs to the battery terminal. My fogs are turned on via the switch. The switch only gets power when the ignition is on, because the switch is tapped into the green power wire from the ignition, this way it wont stay on when you turn the car off (to avoid draining the battery). My foglights are separate from my headlights, they do not tap into one another.
The Following User Says Thank You to m.box.design For This Useful Post:
636 (12-02-2013)
Old 12-02-2013, 03:04 AM   #12
636
636's Avatar
Drives: '23 CWP BRZ
Thanks for your help!! Just one more questions to clarify everything, just to make sure I've got this right, if you don't mind.
Does this look right?
Old 12-02-2013, 05:30 AM   #13
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
thats correct. those photos above post are actually my photos lol
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
The Following 2 Users Say Thank You to 86 FRS For This Useful Post:
636 (12-02-2013), nbafandan (12-30-2013)
Old 12-02-2013, 11:23 AM   #14
assbox
assbox's Avatar
you guys rock
i will try this when i get home from work tonight! ^_^
i owe someone a beer!
IG: ft86carbon
The Following User Says Thank You to assbox For This Useful Post:
636 (12-02-2013)
Foglight Cost FRSure Cosmetic Modification (Interior/Exterior/Lighting) 10 12-04-2013 04:57 PM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
Is foglight wiring in the car? FastLap Scion FR-S / Toyota 86 GT86 General Forum 7 08-26-2012 11:54 PM
Foglight replacement help Zadkiel Cosmetic Modification (Interior/Exterior/Lighting) 4 08-06-2012 11:11 AM
