Old 11-18-2013, 08:56 AM   #15
86TruenoFRS
Drives: Rocket Bunny v1 FRS
Originally Posted by Maverick22 View Post
Hello, I recently purchased a Rocketbunny Kit, well just the fenders anyways, That's all I really liked about the kit. . I wanted to be able to run a really wde wheel and tire. I had my eyes on a 19x 10.75 with either a 20mm or 35 mm offset, obviously i would have to stack spacers for this setup.
My concern though is that the wheels will be too wide. Would I be safer running a 19x 8.75? +20mm or +35mm
Should I run the 20mm with a 25mm spacer? for a -5mm ofset n the front and a 60mm spacer (which is huge) in the rear fo a -40mm offset??
I am trying to figure this out before I get the kit in the post. Thanks in advance.
I am not very good with offsets especially now that I will have to push the wheel out so far. I don't want much stretch on my tire and do not want to poke much, just o have a clean functional wheel and tire.
From my understanding and I've been doing quite a bit of research about this, is in order for it to look proper(not sunk in) you will need to run a wheel w/ in the rear ranging form 10.5-12 wide w/ offsets between -44 - -22. Up front you will need to run a wheel ranging from 9.5-10.5 wide w/ offsets of -25 - -10. Someone correct me if I'm wrong please. This is just what I've been able to come up w/. Now if are going for a more sunk in look than adjust the offset more to zero. Since you are leaning towards the functional aspect, most RB owners run an 18x10.5 +22 w/ spacers. I know one owner that has the Battleship gray RB runs that size w/ a 15mm spacer in the front and 25mm in the rear.
86TruenoFRS is offline   Reply With Quote
The Following 3 Users Say Thank You to 86TruenoFRS For This Useful Post:
JayDee (03-23-2014), Maverick22 (11-18-2013), UltraMarine86 (11-18-2013)
Old 11-18-2013, 08:57 AM   #16
86TruenoFRS
Also if you need help adjusting for offset w/ the width of the wheel got to: http://www.1010tires.com/Tools/Wheel...ulator#Results
This helps quite a bit
Old 11-18-2013, 09:56 PM   #17
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
Well, I pretty much got all of that. I am leaning towards canceling my RB order. It seems like the wheels are going to be scary heavy. I plan to boost the car but dont want to waste my entire budget on this kit that is going to decrease my performance.
Im waiting on the venders reply.
Maverick22 is offline   Reply With Quote
The Following User Says Thank You to Maverick22 For This Useful Post:
Strife26 (03-27-2017)
Old 11-18-2013, 10:45 PM   #18
86TruenoFRS
If you go w/ a 2pc or 3pc forged wheel, they won't be super heavy at all
Old 11-19-2013, 03:28 AM   #19
Maverick22
Maverick22's Avatar
thanks
Old 11-19-2013, 06:35 AM   #20
86TruenoFRS
even a 2pc wheel will require spacers to sit out where I want them.
Not necessarily, you can get a Work Meister S1R in specs aggressive enough that u won't need spacers
Old 11-19-2013, 06:44 AM   #21
Maverick22
Maverick22's Avatar
I dont want to pay the price for work meisters. Wheels get destroyed...... U am not dropping that amount on something that will get eventually replaced,
Although the post above about running a +22 wheel with spacers sounds about right with what I plan to do. I have my eyes on a set of BBS's right now.
Thanks for the help.
Old 01-30-2014, 04:43 AM   #22
trel1100
Drives: scion frs
can anyone get me exact specs for a RB frs with these wheels?http://mirowheels.com/portfolio/type-398-black/
i would really appreciate if someone could tell me exactly what sizes to get for this
trel1100 is offline   Reply With Quote
Old 02-01-2014, 10:01 AM   #23
Maverick22
Maverick22's Avatar
Your best bet for those is going to be the 18x 9.5 +20. Then you are going to need spacers for the front and rear.
The point is to get as close to zro as possible, you might even go into the negative depending on your width, tire and what you are going for. I am waiting on my kit to get here to measure before the wheels so i know what size spacers i might need.
Old 02-05-2014, 02:54 AM   #24
trel1100
Drives: scion frs
so i kind of changed my mmd to these SSRs an dhtey come i a lot of shapes and sizes, with a RB kit on the frs wha would the specs be a 19? btw is mod bargains a reliable site to order from? thx really appreciate it I'm just learning before i take action lol http://www.modbargains.com/ssr-wheels-gtv-01.htm
Old 02-05-2014, 05:20 AM   #25
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
My Rocket Bunny has arrived but I have not ordered the wheels yet. I will most likely go for these wheels, but I dont know what size spacers they are using. Anyone have a clue?
mnsayer is offline   Reply With Quote
Old 02-05-2014, 07:10 AM   #26
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Low offsets, that's your key, 18" is ideal, look for 11" wide in the back with a very low offset and 9-10" in the front with minimum positive offset (mainly +20 would work but you miiiight need to run spacers).
Modbargains are very reliable from what I've heard.
Yamajee is offline   Reply With Quote
Old 02-05-2014, 07:11 AM   #27
Yamajee
Yamajee's Avatar
I'm not sure who you mean but most RB cars run deep dish wheels or concave, meaning that the offsets are low, you either need to find low offset wheels or if you're planning to use spacers, it might look sunk in.
For everybody's info: rear fenders stick out +70mm and fronts stick out +40mm, suppose you have a wheel that is flush with the stock fender and plan on still using it, you need 70mm/3 inch spacers to make it work but who would want to run that wide spacers, dangerous.
Old 02-06-2014, 02:14 AM   #28
mnsayer
mnsayer's Avatar
sorry forgot to share the link. http://www.speedhunters.com/2012/10/...ket-bunny-frs/
The Following User Says Thank You to mnsayer For This Useful Post:
BolognaWalrus (10-04-2014)
Replica rocket bunny crildz Cosmetic Modification (Interior/Exterior/Lighting) 103 05-09-2014 05:35 PM
Rocket Bunny FRS in Dubai TAP Auto Parts FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 49 12-04-2012 02:39 PM
Red Rocket Bunny FR-S - Speedhunters RaceR FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 10-12-2012 01:48 AM
Rocket Bunny or Modelista? HELP!!! ShowstoppersUSA Cosmetic Modification (Interior/Exterior/Lighting) 21 08-16-2012 02:23 PM
GReddy/Rocket Bunny Wheels? Coultergeist Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-15-2012 03:39 AM
