#113 | ||
CHECK ENGINE
Drives: 2004 STi
i don't cry about crickets
#114 |
#115 |
CHECK ENGINE
Drives: 2004 STi
That hose definitely doesnt bulge, it may look like it in the photo though.
If i get a chance today I'll look up the numbers, we are pretty busy though may be tomorrow.
| The Following User Says Thank You to CARNZ For This Useful Post: | s2d4 (11-07-2013) |
#116 |
Drives: 2013 SWP BRZ
dying to see results!
#117 |
Drives: BR86
Implementing this water to oil cooler has the great benefits cooler oil, engine & under hood temps aswell as eliminating the risk of a destroyed oil line but would you install it on a DD with occasional spirited fangs considering how hot temps get here in oz during summer ? Excellent & worthwhile write up btw
#118 | |
Drives: 2022 Subaru BRZ
This added oil cooler will likely reduce high oil temperatures encountered on a race track by 20 F/ 11 C. For an unmodified daily driver, it's of no real benefit. http://www.cusco.co.jp/products/asse...ata-20308.html Last edited by track junkie; 11-08-2013 at 05:48 AM. |
#119 |
For a daily driver, the main benefit is bringing the oil up to operating temperatures faster. Its the main reason why all the turbo models have them, but as we have stated it does both this and cool the oil at high temps.
For the low cost IMO this is worth it on a DD. |
#120 |
Just found this, pertains a little to this thread:
http://www.ft86club.com/forums/showp...6&postcount=51 |
#121 | |
Drives: '13 Ultramarine
| The Following 5 Users Say Thank You to roddy For This Useful Post: | Hyper4mance2k (06-23-2015), jcw99 (04-21-2016), pixel67 (11-08-2013), Turkish (11-13-2013), XtremeMaC (11-25-2014) |
#122 |
Drives: BR86
OK. So what would be the typical oil temp for a stock daily drive or is there too much possible variation to call? Lets assume ambient air temp 104F & 50% stop start city & 50% freeway driving, no racing.
#123 |
Track Junkie
Drives: Argento Scion FR-S
For the Russell M14x1.5 side, did you use a o-ring or a copper washer? I'm getting prepared to install my kit soon.
#124 |
CHECK ENGINE
Drives: 2004 STi
I used Teflon tape on the fitting
#125 |
Has anyone confirmed this application in an AT? Are the parts required exactly the same? Anyone have pictures from an AT of where that plug is? Thanks in advance!
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
#126 |
No, the current instructions are MT only. AT doesn't have a plug because that plug is a pipe that goes to the ATF cooler.
| Tags |
| brz, fxt, oil, oil cooler |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| Bought a 2014 Subaru Forester | EAGLE5 | Other Vehicles & General Automotive Discussions | 10 | 10-02-2013 12:54 PM |
| 2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 03:35 PM |
| BRZ 2.0L Turbo in 2014 Forester | Sleeperz | BRZ First-Gen (2012+) — General Topics | 37 | 03-21-2013 06:42 PM |
| Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… | 2013GTRNate | BRZ First-Gen (2012+) — General Topics | 12 | 02-01-2013 12:29 PM |
