Old 10-28-2013, 11:17 AM   #15
FR-S Matt
Originally Posted by Hawaiian View Post
I'm lucky to be in the midwest. There is an abundance of E85 here so I run it almost exclusively in the summer. Due to cold start issues, and snow i go back toy stock tune for the winter to keep the spinning tires down.
Althogh your mpg may go down, the cost per gallon is down as well and my actual cost per mile on 85 is below 93 at least here in the midwest.
I've also run it in my car for well over 15k miles inclucing several autocrosses with no adverse effects.
Yeah, premium is sitting around $3.26 right now. E85 is $2.87. There's only a couple stations in the area that have it currently, but the number is growing. Who knows, I may try it later on. The free power gain it provides is pretty awesome. Not to mention, it makes running boost a lot safer.
Old 10-28-2013, 11:57 AM   #16
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
E85 for me ranges from 2.20-2.60 while pump is around $4 per.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 10-28-2013, 12:22 PM   #17
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I think I read one time that a (very) general rule of thumb is that E85 gets about 15% less distance per volume than E10 or E0. I've never even seen an E85 pump in real life, so I'm certainly not the expert. But I do know that if it's 15% less efficient but 45% cheaper, it's still cheaper.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 10-28-2013, 12:33 PM   #18
Atropine
Drives: 2021 Toyota Supra 2020 4Runner
Originally Posted by campy View Post
Really? Those are two of the best things about this car in stock form.
I meant new tires would be helpful..
And I didn't wanna mess up the current throttle response.
I worded it very poorly...was kinda in a hurry. Was posting at work between patients.
Atropine is offline   Reply With Quote
Old 10-28-2013, 12:41 PM   #19
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Just slap an Innovate kit on and call it good.
husker741 is offline   Reply With Quote
Old 10-28-2013, 12:45 PM   #20
suaveflooder
As @Anthony mentioned, intake, exhaust and tune will help, but also getting rid of rotational mass. Light weight Crank, light weight flywheel, carbon fiber drive shaft, light weight wheels and gears are going to be the best bang for your buck if you want to stay NA. You won't have the actual horse power to back it up, but the car is going to rev faster (and get up to speed faster) and a lighter car is always a good thing.
I'm not planning on doing much to my car, but this would be the rout I would do if I get bitten by the mod bug. I've owned a couple factory supercharged cobras and heat was ALWAYS an issue.
suaveflooder is offline   Reply With Quote
Old 10-28-2013, 12:47 PM   #21
Anthony
Weight Nazi
Anthony's Avatar
Good point. And if we're going to get into that, I have two powerful words:
FINAL. DRIVE.
Old 10-28-2013, 12:48 PM   #22
Anthony
Weight Nazi
Anthony's Avatar
Personally, I'm thinking 4.88, but I've been called crazy before.
Old 10-28-2013, 12:53 PM   #23
suaveflooder
I was looking at 4.55's to keep my mileage somewhat decent, but 4.88's would do the trick nicely!
Old 10-28-2013, 12:56 PM   #24
Anthony
Weight Nazi
Anthony's Avatar
The installation of the 4.88 gearing would double as a funeral for 1st gear outside of standing starts. I'm fine with that, though.
Old 10-28-2013, 01:29 PM   #25
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Mines a dd so if anything I want a taller 6th gear not shorter.
As for weight I think 100-150 is the most keeping stock interior and not spending 10k on brakes wheels and seats...
Personally I'd bore it out to 2.2L before putting 3500 into seats or 1k into shorter drive
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 10-28-2013, 01:38 PM   #26
DKEddy90
DKEddy90's Avatar
Drives: asphalt grey scion frs
Do the light weight crank pulleys make a noticeable difference/and are they reliable?
Sent from my SGH-T999 using Tapatalk 2
DKEddy90 is offline   Reply With Quote
Old 10-28-2013, 01:43 PM   #27
Anthony
Weight Nazi
Anthony's Avatar
Has anyone done that yet? I haven't actually gone looking, but I've only seen it mentioned hypothetically. The only engine I've ever actually looked into having bored out was a Toyota 2ZZ, but the cylinders in that engine are too close together. So I've gotten used to the idea of engine boring being an unrealistic idea, but... this is a whole new engine to me.
Old 10-28-2013, 01:45 PM   #28
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
This is what I came to post. CF driveshaft is where you're going to get insane bang for your buck. From everything I've seen, past the header replacement you're wasting money buying an exhaust even with a tune.
Keep in mind, people love to throw stupid large heavy wheels on their cars and it's no different. If you can get lighter wheels, tires, driveshaft, flywheel, and crank pulley you're looking at seriously increasing WHP without touching the exhaust.
DoomsdayJesus is offline   Reply With Quote
Highest WHP edamons Engine, Exhaust, Transmission 21 09-17-2013 05:53 PM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 10:53 AM
Help! Need torque specs for motor mount Pele86 Engine, Exhaust, Transmission 5 08-05-2013 04:24 PM
Torque specs for trans and motor mounts jah29 Engine, Exhaust, Transmission 0 06-27-2013 09:53 PM
highest mpg possible steve87j Scion FR-S / Toyota 86 GT86 General Forum 29 12-28-2012 08:06 PM
