Old 10-16-2013, 12:38 PM   #29
CSG Mike
CSG Mike's Avatar
Originally Posted by digital_assassin View Post
So from what I'm reading is that the oil cooler that comes with this kit is only for the Rotrex and not an engine oil cooler. The engine oil cooler will be available at a later date for an additional cost.
Correct. You can also use any engine oil cooler of your choice. The oil cooler included with the kit is for cooling the Rotrex Traction Fluid for the supercharger (it's cooling system is 100% independent of the engine, and doesn't dump heat into the engine oil or engine coolant, unlike some other systems).
Originally Posted by ATL BRZ View Post
It's mounted in the center, behind the intercooler on the undertray? I don't see it mounted anywhere in the pics from the press release, which is why I'm so curious where exactly it's mounted.
To clarify, a Perrin engine oil cooler kit as-is will not be compatible without modification and a new sandwich plate from JR, correct? Or could the fittings possibly be pointed to clear and require no modification?
Correct, it is mounted in the center behind the intercooler. However, you are able to mount it offset, so that you can have two side-by-side oil coolers, one for the Rotrex supercharger, and one for the engine oil. The system is designed to be useable by both casual street cars, and full-on track cars.
I don't see why you'd need a new sandwich plate unless the orientation of the fittings is incompatible. YOu'll probably need new lines to route properly. Unfortunately, we have no test mule with a Perrin cooler that also has the Jackson Racing supercharger kit, so we can't confirm or deny at this time.
ATL BRZ (10-16-2013)
Old 10-16-2013, 12:42 PM   #30
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
It seems as if this kit would need a rotated sandwhich plate similar to the Kraftwerks kit to turn away from the charge pipe but the angle of the photo doesn't make it clear enough for me to tell 100%
digital_assassin is offline   Reply With Quote
Old 10-16-2013, 12:47 PM   #31
Danzzt231
Drives: GT86
Oh yes, Rotrex!
This should make the car feels like it has a bigger engine instead of forced inducted. Perfect.
Danzzt231 is offline   Reply With Quote
Old 10-16-2013, 04:20 PM   #32
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
CARB approval is a huge selling point. Warranty ain't bad either.
Intent > Content
Old 10-16-2013, 04:45 PM   #33
fenton
Am i missing something or is this thing making 160tq at 2500rpm stock? Its making more wtq than the manufacturer claimed flywheel torque....
This must be a very high reading dyno no?
Gains supercharged are still a percentage over stock i realize but i haven't seen dynapack numbers this high before.
Certainly i haven't ever seen numbers higher than manufactures claimed flywheel tq or hp though? How is that possible reading off the hubs?
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
xjohnx (10-16-2013)
Old 10-16-2013, 04:58 PM   #34
Scooter Style
Drives: 2015 BRZ/ Blue Series/ WRB
What fuel upgrades dows the kit come with?
2013 SWP BRZ #137 First BRZ in Columbus, OH! SOLD
2015 WRB Blue Series #900/1000
Team Rowdy
Ohio Native
Instgram brooks_church
Scooter Style is offline   Reply With Quote
Old 10-16-2013, 04:59 PM   #35
MAPerformance
Drives: Asphalt FRS
Looks like a graph from a Dynapak hub dyno.
MAPerformance is offline   Reply With Quote
Old 10-16-2013, 04:59 PM   #36
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Danzzt231 View Post
Oh yes, Rotrex!
I seem to recall hearing that same statement from another Cali vendor hocking another supercharger kit. Hmmm.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
akuhei (10-16-2013), CSG Mike (10-16-2013), xjohnx (10-16-2013)
Old 10-16-2013, 05:57 PM   #37
Calum
That Guy
Drives: 2013 asphalt FRS MT
What fuel, compressor rpm, and pressure was the used in the setup for the posted dyno? Will there be an option to get Jackson Racing's tune without buying an additional license and cable for those that already have an Ecutek tune?
I've gotta agree with my fellow Canadian, @fenton those baseline numbers are really high. I'd say the torque is ~40 lbft high and the horsepower is ~20 hp high.
But, if you look at the percent gains that's about 44% increase in torque and 51% increase in horsepower. Just as advertised.
Adding those gains to the typical baseline of about ~120 lbft and ~165 hp, that should look like 172 lbft and 250 hp at peak on a dyno that would give the typical readings.
Old 10-16-2013, 06:01 PM   #38
CSG Mike
CSG Mike's Avatar
Focus on the % gain, not the actual numbers... at least, that's my take.
Old 10-16-2013, 06:20 PM   #39
rskdsk
Drives: series 10 FR-S (2361)
Looks like the automatic crowd is out of luck!
rskdsk is offline   Reply With Quote
Old 10-16-2013, 06:31 PM   #40
CSG Mike
CSG Mike's Avatar
Not if there's enough interest
Old 10-16-2013, 08:07 PM   #41
DJCarbine
Thupercharged
DJCarbine's Avatar
Looks like a solid kit!
More options for supercharging is a win
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-16-2013, 08:51 PM   #42
xxscaxx
Drives: 2013 SWP BRZ
Looks like a great option. Sure is an ugly setup though
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Pablitomarrero (10-17-2013)
Eibach Anti-Roll Kit - Press Release FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-24-2017 05:55 AM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
Official FT-86 II Concept Press Release, Press Photos, Videos Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 126 05-18-2011 02:27 AM
