Old 09-17-2012, 12:07 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Eibach Anti-Roll Kit - Press Release
Got news of this today.
Front and Rear sway bar kit from Eibach for the Scion FR-S and Subaru BRZ
Images:
Info:
Eibach 25mm Front & 19mm Rear Anti-Roll-Kit for 13 Scion FR-S / 13 Subaru BRZ
FOR THE ULTIMATE IN TUNABLE SUSPENSION PERFORMANCE, Complete your suspension upgrade with an Eibach ANTI-ROLL-KIT. While our PRO-KIT performance springs are regarded as the primary suspension enhancement components, the Eibach ANTI-ROLL-KIT allows critical fine-tuning of your Scion or Subaru's handling characteristics.
Our ANTI-ROLL-KITS reduce body roll through increased design stiffness over stock bars. The result: increased handling and cornering grip in any performance-driving situation.
Manufactured from cold-formed, tubular high-strength aircraft-grade steel for precision performance, and finished with a long-lasting red powder coat finish, the ANTI-ROLL-KIT comes complete with all necessary mounting hardware and instructions for easy bolt-on installation.
Performance Tuned Sway Bars for Improved Handling and Reduced Body-Roll
Perfectly Balanced for Optimum Neutral-Steering Handling and Precise Turn-In Response
Precision Engineered and Calibrated for PRO-KIT and SPORTLINE Performance Spring Kits
Eibach Hi-Tensile Steel Alloy, Cold-Formed, Tempered and Shot-Peened for Long-Lasting Performance and Durability
Greasable Urethane Bushings For Increased Responsiveness
Precision Forged Ends and OEM Style Pressed Bushing Locaters (No Welding Or Weak Points Here)
Million-Mile Warranty
FRONT:
Eibach bar: 25mm (1.0 in) tubular, adjustable
Eibach measured bar rate: 2 position adjustable
P1 = 66 N/mm (376 lbs/in) +167 %
P2 = 86 N/mm (488 lbs/in) +248 %
Eibach bar weight: 3.4 kg (7.5 lbs)
Bushings: New urethane bushings with grease grooves.
End Link: OE
Approximate installation time: 1.5 hr
REAR:
Eibach bar: 19 mm (0.75 in) tubular, adjustable
P1 = 38 N/mm (217 lbs/in) +92%
P2 = 50 N/mm (283 lbs/in) +153%
Eibach bar weight: 3.2 kg (7.1 lbs)
End Link: OE
FT-86 SpeedFactory is offline
Old 09-17-2012, 11:46 PM   #2
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Very nice, Eibach always makes awesome stuff and for great prices too!
Thanks,
Rick
RallySport Direct is offline
Old 09-19-2012, 03:59 PM   #3
simpleisbest
Senior Citizen
Drives: Scion FR-S
Nice! Do you have any product offerings for a set of front adjustable endlinks to go along with the front sway?
simpleisbest is offline
Old 09-19-2012, 10:47 PM   #4
Captain Insano
Thanks for posting. Do you know if these swaybars have any weight savings (since they are tubular) over the OEM swaybars?
Captain Insano is offline
Old 09-19-2012, 10:54 PM   #5
FT-86 SpeedFactory
There is no weight savings unfortunately. Weight is actually increased due to the additional material.
Old 09-20-2012, 10:04 AM   #6
BRZ?
Drives: 2014 SWP 6MT BRZ
Is FT86 Speedfactory offering these as a kit with the pro kit swaybars? Saw it being offered with springs on tirerack the other day. http://www.tirerack.com/suspension/s...odClar=Limited
BRZ? is offline
Old 09-20-2012, 05:15 PM   #7
empower-auto
Kouki-Monster
empower-auto's Avatar
Part # ?
Rich Anderson
EMPOWER AUTO
empower-auto is offline
Old 09-20-2012, 05:30 PM   #8
FT-86 SpeedFactory
Yes! We can definitely do this. Jeremy will get this up on our website later tonight. You can PM for pricing, if you'd like.
Originally Posted by empower-auto
Part # ?
From our website:
Kit:
http://ft86speedfactory.com/index.ph...roducts_id=370
Front sway:
http://ft86speedfactory.com/index.ph...roducts_id=371
Cheers guys!:happy0180:
-Yo
Old 09-20-2012, 08:44 PM   #9
Captain Insano
OK, so out of curiousity, with the front and rear adjustable eibach swaybars, what would be the combination of front/rear swaybar settings with the very most neutral handling?
Old 09-20-2012, 10:17 PM   #10
FT-86 SpeedFactory
That is totally going to be driver dependent. Something you would have to find out for your own style of driving. And honestly, to give you what I think would be neutral I will have to install these and do some testing once they arrive.
I assume everyone is down for a good review on that?
Old 09-20-2012, 11:06 PM   #11
Captain Insano
Yes sir, most definitely I'm down for a review. I'm very seriously considering this package (eibach springs & front/rear swaybars). I had Prodrive springs and Hotchkis (believe eibach manufactured those for Hotchkis) swaybars on one of my STis and I loved that combo for a daily driver. Much more so than a later STi I had with a coilover setup. Subjective opinion of mine, everybody is different. BTW, that is why I originally asked you about potential weight savings of the hollow/tubular swaybars over stock. On that STi setup, the aftermarket hollow/tubular swaybars were actually lighter than stock, but at same time more stiff than the stock swaybars.
I know the "feeling" of the swaybars will be subjective by driver, but I was more interested in which settings create most neutral feel. It would seem that most (not all) would probably be able to agree on something like that, though they might not necessarily prefer a neutral handling car.
Old 09-26-2012, 12:39 AM   #12
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Hey Cap, just to let you know, Hotchkis manufactures their own sway bars. Hotchkis has actually private labeled sway bars for other companies that wanted their own spec.
Cheers!
Nitro22 is offline
Old 09-26-2012, 07:51 AM   #13
Captain Insano
You know, it's been so long (bought and installed the Hotchkis competition sway bars in 2004 on my MY04 STi)... You are right. I believe the Cobb sway bars were rebranded Hotchkis. And the Eibach/Hotchkis were always rumored to be the same because they have the same specs, but that was never proven.
Old 09-26-2012, 08:58 AM   #14
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
"FOR THE ULTIMATE IN TUNABLE SUSPENSION PERFORMANCE"
holy shit, they made a bar with 4 holes in it, now i can adjust like a pro and get the hot womenz
7thgear is offline
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 05:44 PM
is it necessary to change anti-roll bar? yuli8466 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-25-2012 10:58 AM
Press/Blog Release on FR-S Price (no BeSpoke Audio) Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 44 04-20-2012 01:41 AM
Production Subaru BRZ Revealed! (Press Release + Photos) Zaku BRZ First-Gen (2012+) — General Topics 231 12-13-2011 09:28 AM
Official FT-86 II Concept Press Release, Press Photos, Videos Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 126 05-18-2011 01:27 AM
