Old 10-11-2013, 04:46 PM   #1
Demotic
Drives: 2013 FR-S, IS-300, 2004 VW R3
Turn signals flashing too fast after installing TOM's tails
As the title says my car was rear ended so I changed tail light to TOM's. The emergency flashes at a normal rate but the turn signals are way to quick. I checked all the lights and the wiring and it all seems fine.
Any input is appreciated.
Demotic is offline   Reply With Quote
Old 10-11-2013, 05:01 PM   #2
mfbmike
Drives: 2013 FRS, 2008 R32
Did your tails come with the LED flasher that goes under your dash? It sounds like they did not otherwise you would've mentioned installing it. That is why your tails are hyper flashing.
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
Demotic (10-11-2013)
Old 10-11-2013, 06:42 PM   #3
KSpider
KSpider's Avatar
Drives: '14 S4
What mfbmike said.
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
KSpider is offline   Reply With Quote
Old 10-11-2013, 06:51 PM   #4
Demotic
No they just came with a rely asides from the lights.
So with what you said in mind that's not a problem then?
Old 10-11-2013, 07:37 PM   #5
mfbmike
The LED flasher relay needs to be installed to prevent them from flashing too quickly. Check my build thread, it has a link to a DIY to install the relay under your dash.
http://www.ft86club.com/forums/showp...90&postcount=8
Old 10-11-2013, 08:41 PM   #6
Demotic
Thanks broseph. You've been a great help.
Old 10-12-2013, 07:16 PM   #7
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
beware when you install them , you will have blood dripping down your hands and may need a chiropractor after it from the awkward bending... make sure you disconnect the battery harness before install to prevent any popped fuses like i did and it caused the whole car to shut down and not turn on until i found the problem... just be careful =) and yes you def need the hyperflash relay
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 10-12-2013, 07:21 PM   #8
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Hmm, I didn't discinect the battery. Just popped out the stock one and threw in the new one. No problems lol.
It is always a good idea though when doing anything electrical to disconnect the battery first.
FRSfan111 is offline   Reply With Quote
Old 10-12-2013, 07:52 PM   #9
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Didn't disconnect anything either.
Old 10-12-2013, 08:07 PM   #10
White64Goat
Airbags can be very sensitive at times to changes in voltage, not that changing a flasher should cause any problem, but you can never be too careful.
Old 10-12-2013, 09:32 PM   #11
ScionFR-S
ScionFR-S's Avatar
Exclamation
im only saying that bc i had a bad experience my stock relay came out in five pieces i cracked it bc i was jamming on it and prying the metal levers so much lol
Old 10-12-2013, 10:06 PM   #12
Burrcold
Drives: Subaru BRZ Limited
Getting that relay out made me want to murder kittens.
Old 10-12-2013, 10:15 PM   #13
Doctor Who
Equinsu Ocha
Doctor Who's Avatar
Drives: SWP BRZ Limited
And I thought I was the only one who had a tough time getting that SOB relay out. There was blood everywhere...
Doctor Who is offline   Reply With Quote
Old 10-12-2013, 10:58 PM   #14
ScionFR-S
ScionFR-S's Avatar
could have been misinterpreted for a crime scene in my car after that
Selling both rear OEM tails with amber LED turn signals ThaBigUnit Exterior Parts (Aero, Lighting, Etc.) 2 05-24-2013 03:33 PM
***FR-S/BRZ LED Turn Signals (6K WHITE/AMBER FOR TURNING, NO HYPER FLASHING!)*** Vicious LED Exterior Parts - The Rest 7 11-02-2012 11:05 AM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-12-2012 12:23 AM
Turn signal amber LED's flashing quickly michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 11 07-13-2012 11:55 PM
