Old 10-02-2013, 01:55 PM   #43
gmsii
gmsii's Avatar
good choice
Originally Posted by mtimney View Post
New info from website! Pricing!
http://store.kraftwerksusa.com/kraftwerks-brz.htm
They don't have any info on HP/Torque, but they do have pricing up and appear to be taking deposits. I'm hopeful this system will prove more powerful than Innovate or Vortech.
in base form it will make approx 80 more whp than stock on 91 octane fuel with stock exhaust and header
on e85 with header and exhaust, this kit made 127hp more than the stock car.
as for ultimate dyno 'numbers' that is going to vary from dyno to dyno. on our dyno, which is a rototest hub dyno (which is the only chassis dyno considered accurate enough to use for R&D purposes by OEM manufacturers), the base vehicle made 157whp...with e85 we were at 284whp
if you want to chase after even higher horsepower, this kit is designed to use the larger rotrex c38 charger which can move enough air to supports 700whp (approx)...obviously actual results may vary, but IMHO 500whp shouldnt be a problem
gmsii is offline   Reply With Quote
Old 10-02-2013, 02:05 PM   #44
gmsii
gmsii's Avatar
more info
here's some more information that can serve as a basis for discussion or comparison with other kits on the market...
Old 10-02-2013, 02:08 PM   #45
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Do you represent Kraftwerks or work for them?
Any info to share about oil cooler fitment on that shop car? It looks like they have a custom sandwich plate to make it fit with that huge bracket in the way. Is it thermostatic?
So this kit also replaces the crank pulley with one that has a toothed section for the SC belt in front of the ribbed part for the OEM belt?
Old 10-02-2013, 02:31 PM   #46
gmsii
gmsii's Avatar
i work on the engineering/R&D side of things at group-a
regarding the oil cooler set-up....the sandwich plate (not thermostatic) was designed tall to make access to the oil cap easier ...not to clear the supercharger plate. the adapter, lines, and oilcooler will be release shortly, as a skunk2 part
The Following User Says Thank You to gmsii For This Useful Post:
ATL BRZ (10-02-2013)
Old 10-02-2013, 02:35 PM   #47
ATL BRZ
ATL BRZ's Avatar
Found a couple more pics
It looks like anyone with a Perrin/Mishimoto/FBM/Mocal oil cooler kit is screwed without new lines and the skunk2 sandwich plate, which is not yet confirmed to be thermostatic.
The Following User Says Thank You to ATL BRZ For This Useful Post:
cobrabyte (10-21-2013)
Old 10-02-2013, 02:48 PM   #48
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Any info on a CARB legal version?
uspspro is offline   Reply With Quote
Old 10-02-2013, 03:52 PM   #49
Razz
Razz's Avatar
Drives: Fast
I saw this at the meet last night.
I didn't get any info on CARB.
Razz is offline   Reply With Quote
Old 10-02-2013, 04:46 PM   #50
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by nelsmar View Post
The 2.87 spun to 53k. Blower would only handle 50k... Just to make sure that was clear haha. Also it sounds like that dyno was on E85 as the post above says +125WHP on E85...
Although I did a quick photoshop overlay over a dyno of mine on E85 (i am running just a tad more boost than them) and the low end seems like it may be more promising.
Their E85 pull looks like my 92 octane pull, 150tq@2500rpm, 211tq@6000 and 274hp. And I'm still on stock pully... So 8.5ish psi @7400
What's the upgrade path for the rotex?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 10-02-2013, 05:55 PM   #51
gmsii
gmsii's Avatar
the kraftwerks system is designed to be able easily use the Rotrex C38 series of chargers. The C38-92 moves enough air to support about 700bhp
Old 10-02-2013, 06:02 PM   #52
JerryMichaels7
Drives: Whiteout FRS
Umm so anyone else see Skunk2 header?? when the fuck did that happen?
JerryMichaels7 is offline   Reply With Quote
Old 10-02-2013, 06:14 PM   #53
gmsii
gmsii's Avatar
skunk2 header
the skunk2 exhaust and header haven't happened yet....the units on the car are pre-production prototypes
Old 10-02-2013, 06:52 PM   #54
JerryMichaels7
They need to make a pro series manifold for the fa20 :P
Old 10-02-2013, 07:19 PM   #55
Calum
That Guy
Drives: 2013 asphalt FRS MT
Max power for the included compressor, the c30-94, is 435 hp. Considering that's probably crank hp so taking away 20% for drive line losses that's 348 whp max with this compressor. Finally, someone picks a compressor that isn't too small out of the box.
Keep up the good work.
Old 10-02-2013, 07:31 PM   #56
Sonolin
Yea I also noticed looking at the compressor map this would be at the very start of the efficiency range (which is quite large). I'm new to this stuff but that's what it looked like to me at least.
And that's all without overspinning the blower which you'll need to do to get the most out of the Vortech.
The main thing I'm concerned with is heat... I've heard mixed opinions on heat with a rotrex unit but I'm hoping its manageable and it looks like they are track testing it so that's good news...
Sonolin is offline   Reply With Quote
[TX] DFW General Discussion feedbag Southwest 1488 06-18-2022 08:25 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
ROTREX SC Brainstorming MANDALAY Forced Induction 61 12-11-2012 06:57 PM
Rotrex kit - why no build? MindtheGap Engine, Exhaust, Transmission 5 10-26-2012 08:01 PM
