Old 09-19-2013, 09:34 AM   #57
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Originally Posted by Suberman View Post
There are plenty of planetary transmissions in high end sportscars, depending on your definition.
There is no inherent superiority to a DCT over a planetary gearbox. In fact, the planetary transmission is more efficient, lighter and handles more torque. Also, planetary transmissions are likely to be more durable.
There is one inherent superiority - dual clutch gearboxes are still significantly faster shifting than ordinary autos.
Sent from my Galaxy S4 using Tapatalk 2
chrisl is offline   Reply With Quote
Old 09-19-2013, 12:48 PM   #58
dotdotdotPaul
Question
I don't think this is true.
The RX-8 with an automatic had 30hp less than the manual. The reason was because the redline on the automatic was at 7500rpm -- the limit a 'slushbox' could handle. The manual, on the other hand, redlined at 9000rpm.
The supercars with "automatics" these days are almost certainly automated manuals (whether twin clutch or not).
I'm willing to be proven wrong on this, but will require specific evidence -- what supercar do you think is using a traditional planetary gearbox automatic transmission?
...Paul
dotdotdotPaul is offline   Reply With Quote
Old 09-19-2013, 02:01 PM   #59
zoomzoomers
zoomzoomers's Avatar
The Toyota LFA, Audi R8 V8. There are more, but I'm too lazy to do your work for you.
Z
[QUOTE=dotdotdotPaul;1221853]I don't think this is true.
...Paul[/QUOTE]
Old 09-19-2013, 02:53 PM   #60
chrisl
The Lexus (it's not marked as Toyota anywhere in the world, and Lexus is far more distinct from Toyota than Scion is) LFA uses a single clutch electrohydraulic transmission - no torque converter in sight. As for the Audi? I'm not sure about the older R-tronic transmission (which wasn't amazing, but I don't know exactly how it worked), but the new ones are either the S-tronic (double clutch, and much better than the old R-tronic) or manual. Once again, no torque converters here.
The Following User Says Thank You to chrisl For This Useful Post:
dotdotdotPaul (09-19-2013)
Old 09-19-2013, 02:56 PM   #61
zoomzoomers
The fact of the matter is, and the answer to your question, there are still cars that are in the "super car" category that have non dual-clutch autos. This will probably change as they all progress into offering DCT type systems, but there're still there.
Old 09-19-2013, 03:01 PM   #62
chrisl
The R8 only offers a dual clutch auto, and the fact that the LFA is a single clutch is irrelevant - it's as different from a torque converter auto as a DCT is. If anything, the LFA transmission is closer to the one used in the Pagani Huayra (also a single clutch sequential).
Now, there are still nice cars that have torque converter autos, but nothing up in the super car category - the ones still running torque converters are ones like the BMW 335, Lexus IS-F, and similar.
Old 09-19-2013, 03:06 PM   #63
zoomzoomers
Not too argue with you, but now you're just changing your initial statement about super cars not using autos. You didn't say auto without torque converters, etc. With or without, torque converter, DCT or not, many supercars out there are autos. From the looks of it that's probably what they'll only be offered with in a few years. In either case, technology is changing there's not doubt about that.
Old 09-19-2013, 03:30 PM   #64
Frstorm
Drives: 2013 Firestorm
What about the gtr?
Frstorm is offline   Reply With Quote
Old 09-19-2013, 04:18 PM   #65
chrisl
When did I ever say super cars don't ever use autos? If anything, most of them use autos (but pretty much universally dual or single clutch setups, not torque converters). Maybe you're confusing my statements with something said by someone else?
Oh, and Frstorm: the GTR is a dual clutch auto.
Old 09-19-2013, 04:40 PM   #66
zoomzoomers
Ok, my mistake I might have misread your post before. :happy0180:
The Following User Says Thank You to zoomzoomers For This Useful Post:
Old 09-19-2013, 05:29 PM   #67
dotdotdotPaul
Actually, it was my initial statement that supercars didn't use planetary gear automatics and said I was willing to be proven otherwise. You even quoted me.
You named the LFA and the R8, neither of which use a traditional slushbox (torque converter/planetary gears) system, as chrisl pointed out. They're "automated manuals".
I never claimed there were no automatics -- I specifically disputed the claim by Suberman that:
None of the automated manuals are using planetary transmissions, to my knowledge.
...Paul
The Following User Says Thank You to dotdotdotPaul For This Useful Post:
strat61caster (09-20-2013)
Old 09-19-2013, 05:49 PM   #68
Steve201brz
Originally Posted by chickdigger802 View Post
Are there any large cons for the automatic besides the usual boohahaha between manual vs auto? Auto will still be a blast to wiggle around mountain roads right?
i can only speak for the BRZ. i'm new to this community and don't know the differences in options between FR-S and the BRZ, so for that i apologize.
if you were test driving the subaru, was it a premium or limited AT? was just curious because the dyptronic is worth considering for automatic drivers who want to maintain a DD
Steve201brz is offline   Reply With Quote
Old 09-19-2013, 05:50 PM   #69
jacktman
Drives: BRZ in WR Blue
If you want to shift the AT manually, you don't need to use the paddles. You just need to snick the lever forward for upshifts, and backward for downshifts. I didn't make this up - It shows this in the owner's manual. By using the shift lever, you don't have to search for the paddles when the steering wheel is turning. You also feel as if you are shifting a manual the usual way.
jacktman is offline   Reply With Quote
Old 09-19-2013, 05:51 PM   #70
chrisl
The what? The transmission is the same between the BRZ Premium and Limited...
Auto to manual ric342 Scion FR-S / Toyota 86 GT86 General Forum 135 04-11-2013 12:43 AM
Auto to Manual Obja Scion FR-S / Toyota 86 GT86 General Forum 14 02-04-2013 12:45 PM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 12:33 PM
Manual or Auto? StevenDavisPhoto Engine, Exhaust, Transmission 23 03-30-2012 06:58 AM
