Old 09-16-2013, 09:06 AM   #1
chickdigger802
Drives: 1997 Geo Prizm
am I crazy to like the auto more than manual?
So was out test driving this weekend (think i'm near ready to buy... soon... ). Was surprised that I dug the automatic (in sports mode) more than the manual. While the manual has probably one of the best shifters i've messed with, I just couldn't 'get' the clutch at all (Everything after 1st gear... no matter how fast/slow i engage the clutch, I just can't get it smoothly ). Maybe I'm skewed because the 4speed automatic in my prizm is kinda horrid, but auto brz... good stuff.
+ new constructions and what not makes my daily commute oh so more painful makes me gravitate more to the auto :S
Are there any large cons for the automatic besides the usual boohahaha between manual vs auto? Auto will still be a blast to wiggle around mountain roads right?
chickdigger802 is offline   Reply With Quote
Old 09-16-2013, 09:21 AM   #2
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
It is slower 0-60 and 1/4 mile. It also gets better gas mileage. Both of these are due to the difference in the final drive gearing. If you put it in 4.55 FD then it would probably be just as fast (or faster) than the manual and get the same (or worse) mileage.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 09-16-2013, 09:21 AM   #3
2013GTRNate
2013GTRNate's Avatar
Sounds like you would love the BRZ in auto… There is nothing wrong with that at all.
Cheers,
-Nate
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
The Following User Says Thank You to 2013GTRNate For This Useful Post:
Freeman (09-19-2013)
Old 09-16-2013, 09:22 AM   #4
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
The auto has significantly taller ratios, so it will be slower and a bit harder to keep in the peak of the powerband. Also, I think the auto is a bit heavier (not much though). Aside from that, there shouldn't be any further performance penalty. That's interesting that you feel that way about the clutch though - every time I've driven a brz, I found the clutch very easy to use (admittedly, I haven't driven an auto with any regularity in about 7 years though - every car I've owned or driven frequently in that period has been stick, so I'm pretty comfortable with a manual).
chrisl is offline   Reply With Quote
Old 09-16-2013, 09:23 AM   #5
Opposed
Drives: 2013 Asphalt FR-S
Not really any major cons in my opinion. Im sure there will be lots of back and forth like every other auto vs man thread. But really, only cons in my book is that it is much slower from a stand still, but from a roll, they are pretty close. And I want the most fun I can when driving a car, so I will always prefer the manual. But you will get better MPG's, and it is a pretty nice auto for the price range. Do what makes you happy.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 09-16-2013, 09:25 AM   #6
infinite012
Drives: 13 DGM BRZ Ltd
If you drive the automatic transmission BRZ aggressively, the Transmission Control Unit (TCU) will record the "spirited" driving and at your next dealer service interval your entire warranty will be void.
Or at least that's what the dragon told me.
infinite012 is offline   Reply With Quote
The Following User Says Thank You to infinite012 For This Useful Post:
DoomsdayJesus (09-17-2013)
Old 09-16-2013, 09:40 AM   #7
DarkSunrise
DarkSunrise's Avatar
The clutch in this car takes a little while to master, partly because (1) it engages so high and also because (2) the throttle pedal is dead in the first 0.5-1 cm of pressing it. Adjusting the clutch to engage earlier fixes (1). Getting used to the car fixes (2).
Personally, I found this car much more fun to drive with the manual, but everyone's different. If you like the auto better, go for that.
2022 BRZ Build
2013 FR-S Build
Old 09-16-2013, 09:46 AM   #8
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I've heard a ton of good things about the automatic transmission. I kind of wish I had test drove one before buying my MT.
ericmpena is offline   Reply With Quote
The Following User Says Thank You to ericmpena For This Useful Post:
Trigonx (09-16-2013)
Old 09-16-2013, 09:49 AM   #9
Turbowned
Turbowned's Avatar
The clutch you'll get the hang of eventually. The gas mileage is better than EPA-estimated. The auto is slower, more expensive and less desirable. I drove an auto FR-S at an auto-x before buying my BRZ. It was good enough to show me what the chassis was capable of, but I felt hindered by the transmission (traction and stability were on, so this wasn't helping either, of course).
Old 09-16-2013, 10:50 AM   #10
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
The auto is great, with the exception of taking off from a dead stop its just a hair slower then the MT. The shifts are crisp, and quick, probably quicker then most people could shift the MT certainly quicker then I could.
The AT is no slouch and the paddles work great.
Old 09-16-2013, 11:02 AM   #11
whaap
whaap's Avatar
I've driven manuals most of my life and even though my FR-S is a manual and I totally enjoy it I still second guess myself for not getting the more efficient automatic. Oh well, if that's my biggest problem I guess I've got it made.
whaap is offline   Reply With Quote
Old 09-16-2013, 11:03 AM   #12
kakarot1657
kakarot1657's Avatar
Drives: 2013 Subaru BRZ (Galaxy Blue)
you can't go wrong either way. I went with the manual for cost reasons and for a change of pace from driving automatic.
kakarot1657 is offline   Reply With Quote
Old 09-16-2013, 11:59 AM   #13
strat61caster
strat61caster's Avatar
Drove around San Francisco yesterday with my manual, zero regrets.
To each their own, enjoy whatever you end up with, only you have any idea what you'll feel like in a year or five's time.
Edit: due to the direction this thread is taking, I posted mainly to assuage your fears, I stalled twice on my test drive, it gets easier.
ineedyourdiddly
Old 09-16-2013, 01:40 PM   #14
dotdotdotPaul
Wink
I always regret driving around San Francisco, no matter what I'm driving.
...Paul
dotdotdotPaul is offline   Reply With Quote
The Following 2 Users Say Thank You to dotdotdotPaul For This Useful Post:
Seraph (09-16-2013), strat61caster (09-16-2013)
Auto to manual ric342 Scion FR-S / Toyota 86 GT86 General Forum 135 04-10-2013 11:43 PM
Auto to Manual Obja Scion FR-S / Toyota 86 GT86 General Forum 14 02-04-2013 11:45 AM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
Manual or Auto? StevenDavisPhoto Engine, Exhaust, Transmission 23 03-30-2012 05:58 AM
