Old 09-18-2013, 10:40 PM   #3193
jdair28
Drives: 2013 Scion FR-S 10 Series
ive got my 10 series for about a month now, with almost 1000 miles on it. I've been putting gas with 10% ethanol (cuz thats all they have here in richmond, VA apparently) but I have not gotten the crickets yet. Is the crickets more the exception than the rule?
jdair28 is offline   Reply With Quote
Old 09-19-2013, 12:10 AM   #3194
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
Originally Posted by projek_01 View Post
I haven't been keeping up with the 10 Series thread. Anyone have crickets yet? it got a little cold today and bam, crickets came along with the weather. Kind of choked....
Yes I've heard them on couple of occasions, but next few times I will drive nothing. Guess it depends on weather, how long I've been driving. They have been non existent more than I've noticed. Still using strictly Shell 91 non-ethanol.
Once my first check up comes ill bring it up if they get worse, along with the spot weld ticking/popping that has been getting worse at rear shelf panel. Anyone know if BRZ TSBs work hand in band with Scion?
FiRStsc10n is offline   Reply With Quote
Old 09-19-2013, 12:16 AM   #3195
Luis_GT
No crickets for me, but I have the rear deck pop, and the faux carbon dash has come unglued
Old 09-19-2013, 12:40 AM   #3196
mush
mush's Avatar
mine too, i didnt notice till i saw someone pointed it out on a diff thread(not my car)... i pressed my dash and yup i have the same problem
Old 09-19-2013, 12:47 AM   #3197
Burrcold
Drives: Subaru BRZ Limited
The silver carbon dash is just an overlay?? What's under it? The regular FRS dash?
Old 09-19-2013, 12:48 AM   #3198
Luis_GT
Yep
The Following User Says Thank You to Luis_GT For This Useful Post:
Burrcold (09-19-2013)
Old 09-19-2013, 12:54 AM   #3199
Burrcold
Yep
Shitty. I really liked the look of the 10's dash. :/
Old 09-19-2013, 01:03 AM   #3200
Luis_GT
It looks nice... they just went the cheap route...
Old 09-19-2013, 03:06 AM   #3201
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
At first, it sounded like a knock under 1200 rpm. Now its just crickets coming from the fuel pump. Dam man, Toyota/Subaru needs to get their shit together. They have had more than a year since launch to fix these things. My rear deck hasn't popped yet but it rattles like a mofo.
projek_01 is offline   Reply With Quote
Old 09-19-2013, 04:14 AM   #3202
SurfAndSand
8SiX
Drives: FRS 10series
My rear deck rattles a bit from the passenger side. I haven't figured out where thats coming from yet. I got the crickets, BUT knock on wood, I had them replace the fuel pump about 600 mi ago and it hasn't come back (mine started at 200 mi, and replaced it around 1200 mi). I've been using 92 E10, because that's what they have here in Hawaii.
SurfAndSand is offline   Reply With Quote
Old 09-19-2013, 08:56 AM   #3203
PSORngr
Drives: FR-S 10 Series
Yep, crickets at just about every idle other than when I first start it up.
PSORngr is offline   Reply With Quote
Old 09-19-2013, 09:08 AM   #3204
FiRStsc10n
FiRStsc10n's Avatar
Check out this thread.
Read Decking Popping/Click
Has a lot of information on possible means for rattle or popping. If it is audible clicking/tapping that occurs usually after 2000 miles, occurs when rear shelf panel bends/twists over uneven surfaces or bumps it is likely the spotwelding issues. Apparently this is bound to happen on all GT86/FRS/BRZ's made due to spotwelding techniques. There is a Subaru TSB in the link above or it can be found in the TSB section on the forum. Either they punch the welds, get it re-welded, or they follow a technique similar to the thread I will attach below for DIY where you insert grease into the areas to eliminate the popping heard from sheet metal rubbing together. Some dealers have a noise locator which will find exact location of where clicks are coming from.
DIY Rear Deck Popping
I guess it all depends on if you have warranty and your dealer with do Subaru TSB or if you'd rather remove the rear shelf panel carpet and do it yourself. Half of the spotwelds can be accessed via the trunk.
The Following User Says Thank You to FiRStsc10n For This Useful Post:
SurfAndSand (09-19-2013)
Old 10-09-2013, 01:30 PM   #3205
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Originally Posted by sato View Post
Good morning ladies and gents...
I'm sorry if I didn't read through all the 139 pages, but I have a small doubt I wish you'd answer. I've seen some series 10 models with spoilers and others without. What is the default?
I ask because I like the five axis spoiler a lot, but if the series 10 already comes with a spoiler, it kind of ruins it a bit for me... another one to buy, paint and install.
Originally Posted by FiRStsc10n View Post
I'm still stumped on which spoiler to go with. I have a soft spot for the BRZ/GT86 spoiler but skeptical on having to get it paint matched. @supra2nv just sent back his TRD spoiler for touch ups because it didn't match 100%. Then there is 5axis which can be factory matches and easy install. Not really a fan of the Scion OEM spoiler but it is growing on me after seeing some of your guys/gals photos.
On another note I saw a thread that the 2014 FR-S is getting knee pads. Might wait out to see if these are cheaper to order via your dealer than JDM option. Jpmcoachworks currently doesn't have simulated leather speaker surrounds as option (possible mistake on website)
Originally Posted by torqdork View Post
Me too. I'm leaning toward the 5 Axis. There's a group buy in progress now but I'm not sure if the vendor can get our color, still waiting for a reply.
http://www.ft86club.com/forums/showt...t=41259&page=3
Originally Posted by Anaxilus View Post
I vote 5axis over the other options. It is only taped on I believe rather than bolted which is either good or bad depending on how you look at it.
Good to know its only taped. Then I can change it when I'm bored of it.
Hey guys this just a reference, theirs currently a Group Buy on Facebook for the Silver Ignition Pre-painted by Five Axis them selfs. Let me know if you guys are interested I can provide more information via PM I believe it's 365 shipped
DesertFrs is offline   Reply With Quote
The Following User Says Thank You to DesertFrs For This Useful Post:
SurfAndSand (10-09-2013)
Old 10-09-2013, 02:45 PM   #3206
frs10
Drives: tezla
nice!
i want the TRD spoiler, anyone have a good deal on that painted in SI?
frs10 is offline   Reply With Quote
2014, brz, fr-s, gt86
Limited edition WedSports GH05T Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-17-2013 03:03 AM
Limited Edition FT86 Oil Cap #127 phenom86 Engine, Exhaust, Bolt-Ons 2 12-12-2012 05:30 PM
Toyota TRD GT86 Special Edition Announced for UK Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 56 07-18-2012 12:23 PM
Limited Edition Colors? bambbrose Scion FR-S / Toyota 86 GT86 General Forum 7 11-30-2011 04:23 PM
