Old 09-13-2013, 03:39 PM   #43
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Originally Posted by TomWalton View Post
I got relief from the sense of imminent destruction at high revs - and at highway cruising speeds - by blocking that silly tube that brings induction noise into the passenger compartment. The sound it made was always incongruous to me; didn't sound like an engine running, sounded like a vacuum cleaner. I found it embarrassing, at least; sort of a toy car "feature".
I know this doesn't directly address the OPs question, but I find the car much more pleasant to drive with just the honest engine and exhaust noise. It might lower OP's anxiety level at his cruising speeds if the extra - and silly - sucking sound wasn't being piped in.
What tube? this seems interesting to do!
It should not be an issue. Subaru boxer engines are used, with reduction gears, in experimental aircraft all over the world. In that application they are run constantly run at near full RPM for thousands of hours.
I have personally flown with one in an RAF2000 gyrocopter and a Zenith 601HD fixed wing. I would not hesitate to do it again.
At the revs you are talking the engine is not even at a good fast walk never mind running hard, compared to these uses of them.
Wow!
Originally Posted by Steve201brz View Post
is there a reason is 88? why not round it to 90 or down to 85? first assumed it was the conversion from kmh, but thats 141... kinda curious
oops, I meant 87 miles then, 140 km/h is the max speed limit.
Yamajee is offline   Reply With Quote
Old 09-13-2013, 03:48 PM   #44
Steve201brz
ooo, that's definetly a nice rate of travel haha.
the tube i think he's talking about is the "sound tube". the stock intakes have a tube branching off the left side of it that feeds into the cabin. provides a louder sound to the driver, gives it a more "engine-y" sound...terrible way to describe but i gave it a try haha
Steve201brz is offline   Reply With Quote
Old 09-14-2013, 07:07 AM   #45
Yamajee
Yamajee's Avatar
That's the sound I want to eliminate! thank you! any DIY for this?
Old 09-14-2013, 07:12 AM   #46
regal
Drives: Scion FR-S/Toyota Yaris
Mine does this too. I have read reports here where warranties were denied for removing the sound tube. If you "delete" it hold on to it in case you need to re-install, never give them an out.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-14-2013, 07:20 AM   #47
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Just get some tools and start taking it out. Just be sure to plug any holes you make. And don't forget about the rest of it:
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-14-2013, 07:42 AM   #48
regal
I think what you circled in red rattles too, ideally that would be removed as well
Mods:
Old 09-14-2013, 07:48 AM   #49
Anthony
Weight Nazi
Anthony's Avatar
Yeah, that's what I meant. Don't forget to take it out.
Old 09-14-2013, 10:44 AM   #50
Steve201brz
yea i kept the sound tube stuff, it's worth it and real simple if you want to use the warranty at some point
Old 09-14-2013, 03:15 PM   #51
Yamajee
Yamajee's Avatar
Wow just for a sound tube, they really look for the slightest thing ever -.-.
Thank you ! will give it a try and tell you how it feels like after it's removed.
Will do that.
I think an intake pipe has to be replaced too because that hole would very hard to plug/block.
Old 09-14-2013, 10:20 PM   #52
regal
Will do that.
Someone sells a plug for the intake hole, wish I saved the link.
Mods:
Old 09-14-2013, 11:36 PM   #53
Anthony
Weight Nazi
Anthony's Avatar
That second photo I posted is actually my car. I believe the seller included the original intake piping, so if you don't mind waiting over 2 months, I could sell you my pipe you see in that picture for the cheap.
I've already ordered an FA20Club intake, but I want something in case I need to bring it in for warranty work. Pretty sure he sent the stock piping to me, so I won't need the pipe you see in the picture.
Old 09-14-2013, 11:42 PM   #54
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Just So you know apparently if you can use the cap for the cigarette lighter plug behind the glovebox to plug the hole.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Anthony (09-14-2013)
Old 09-15-2013, 01:53 PM   #55
Yamajee
Yamajee's Avatar
Is it a thread on the forums?
2 months
Might give that a try haha.
Old 09-15-2013, 02:10 PM   #56
Luis_GT
Originally Posted by bkblitzed View Post
depends on my mood. If im pissed ill drive fast. If im bored ill drive fast, if im sad ill drive fast to make me happy. I guess i just drive fast..
I only have 2 speeds... stopped and hallin ass
5th Gear Grind at Freeway Speeds? l0aded Issues | Warranty | Recalls / TSB 124 03-21-2018 07:04 PM
Speeds at each gears. mickey177 Engine, Exhaust, Transmission 10 08-25-2016 06:40 PM
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 10:11 AM
RPM at Highway Speeds sparis45 Scion FR-S / Toyota 86 GT86 General Forum 21 05-26-2013 02:41 PM
Post you speeds for fun... seven Off-Topic Lounge [WARNING: NO POLITICS] 48 01-27-2013 07:37 PM
