Old 07-31-2013, 09:13 AM   #15
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
How about posting a picture of your install?
Link does not have a image of the adapter.
Curious about the amount of clearance between the sensors screwed into the ports and the oil fittings / hoses and the oil drip-lip.
Thanks
Brzzee is offline   Reply With Quote
Old 07-31-2013, 01:40 PM   #16
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Just waiting on a shorter filter extension screw from Mocal. Either Friday or Monday. I'll post up a pic when it's all in.
Best I have for now is the manual from TRD: http://www.trdparts.jp/manual_pdf/86/MS131-18001.pdf
BatStig is offline   Reply With Quote
Old 08-03-2013, 03:43 PM   #17
BatStig
Some say.....
BatStig's Avatar
Here's a quick pic of the TRD plate under the Mocal thermostatic plate. Fits beautifully.
Old 09-10-2013, 07:06 AM   #18
Brzzee
Brzzee's Avatar
Shorter fitting
What's with needing a different attachment fitting with Mocal plate?
Way like what You've discovered. Thanks for sharing.
Old 09-10-2013, 11:13 AM   #19
BatStig
Some say.....
BatStig's Avatar
The filter extension screw that came with the Perrin kit is sized for the Mocal sandwich plate and the spacer. The TRD plate is taller than the Perrin spacer it replaces, so the Perrin extension screw is too short. I ended up using two filter extension screws: the one that came with the TRD plate as well as one that fits just the Mocal adapter.
Old 09-10-2013, 01:51 PM   #20
Brzzee
Brzzee's Avatar
Ah, the fun of mixing and matching from different sources bespoke systems!
Good on you for making it work!
Old 09-10-2013, 03:23 PM   #21
muffinz
Drives: 2013 DGM BRZ Ltd
Not sure if the fittings / sensor types exist...but could you put a T connection inline with the oil line going into the oil cooler to measure temp? or pressure? or both?
I used the existing galley plug for my pressure sender and it works fine.
muffinz is offline   Reply With Quote
Old 09-15-2013, 01:22 PM   #22
wrohdejr
Drives: 2013 subaru limited wrb brz
I am installing a Prosport oil temp and pressure gauge. I am using a perrin plate and then a prosport plate everything is going on ok. When i start the car i get a small oil leak under the perrin plate. I am torquing the plate nuts to 55lbs as stated in the perrin instructions is that to much? Also i can see one of the o rings flex out of the bottom of the perrin plate. What is everyone else torquing there nuts at?
wrohdejr is offline   Reply With Quote
Old 09-15-2013, 10:07 PM   #23
BatStig
Some say.....
BatStig's Avatar
I hope that's a typo. The instructions I got called for 25ft-lbs.
Old 09-12-2015, 11:29 AM   #24
jdnguyen
jdnguyen's Avatar
Drives: 2013 FR-S Series 10 and 2010 Camry
Originally Posted by BatStig View Post
I will be changing my stack from what I posted above.
I got my hands on a TRD sandwich plate for the sensors and it's just tall enough that I can use it in place of the spacer supplied with the Perrin oil cooler kit.
So, my stack will be:
Filter
Oil cooler thermostatic adapter
TRD plate
I'll post a pic up next week.
I'm looking at doing the same setup. Whats the part number on the extension bolt? Do I contact Mocal directly for the part?
I'm trying to get a list of parts I need to do this.
Thanks!
jdnguyen is offline   Reply With Quote
Old 09-12-2015, 12:48 PM   #25
BatStig
Some say.....
BatStig's Avatar
Thanks!
It is their standard length extension screw for an M20 filter. The part number is ES20. You can order it from www.batinc.net who is the official Mocal distributor for the US.
Old 09-12-2015, 01:37 PM   #26
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Most oil cooler adapter plates like my Mishimoto have taps for external sending units.
OR
As I did, oil pressure off the main oil galley and oil temp off the ECU via my "Scan Gauge". My Scan Gauge is also reading automatic tranny temp and engine water temp.
Lunatic is offline   Reply With Quote
Old 09-12-2015, 11:15 PM   #27
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Strong work @BatStig. Just ordered the TRD plate from Japanparts. I have a DIY oil cooler kit (Setrab 13/Mocal thermostaic plate) that I havent installed yet. Will I just use the extension from the TRD plate AND the extension from the Mocal plate like you did? Did I read that right?
TIA
xkalelx is offline   Reply With Quote
Old 09-13-2015, 08:05 PM   #28
BatStig
Some say.....
BatStig's Avatar
TIA
That is correct.
Cyberstork gauges ANREX Cosmetic Modification (Interior/Exterior/Lighting) 53 08-11-2016 06:07 PM
WTB: Gauges AtlasMick Engine, Exhaust, Bolt-Ons 2 03-29-2013 12:04 AM
Ecu and displays/gauges stockysnail Engine, Exhaust, Transmission 7 03-02-2013 06:23 PM
gauges where the radio is? J-Money Cosmetic Modification (Interior/Exterior/Lighting) 7 02-05-2013 10:11 PM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 06:26 PM
