Found this while changing my tranny fluid
So I was changing my fluid to day and found this ball stuck to the drain plug. It's not a shift ball, they're both there I checked. It does feel funny shifting into fourth like it just falls in no click nothing. Anyone have any ideas?!
#2 |
Drives: SWP BRZ
what da heck!!!
#3 |
Drives: Whiteout FR-S
ummm
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#4 |
Drives: 13 BRZ WRB
You may have a faulty trans bearing inside.
#5 |
Drives: SSM LT MT BRZ
I would stop now and take it to Subaru.
unless you have an aftermarket clutch... |
#6 |
I have an aftermarket everything lol. Trans sounds no different than normal. Not saying something isn't messed up but I might tear te tranny apart this weekend and need to know where to look
#7 |
Well it's coming out and apart this weekend. Does anyone know where to find an exploded diagram or An fsm for this transmission?
#8 |
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
If you search someone posted an .iso file for the complete 2013 BRZ dealer manual. You'll find what you're looking inside.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
#9 |
Omg
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#10 |
whaaaaaaa?!
#11 |
AutoX-10/10ths every run
Probably not good. Please let us know what you find out.
#12 |
I would suspect all bearings and shift detent locations for the shifter mechanism.
you mentioned it went in to fourth with less resistance does it also come out more easily, like slide out too easily while accelerating in fourth? |
#13 | |
shit I guess i could have peeked at your signature before i posted eh?! |
#14 |
We're thinking it's one of the balls from the no.4 transmission clutch hub the synchronizer key spring ball. Could this be the cause of all the grinding trannys?!
| Using higher quality brake fluid vs using cheap but changing more often | ayau | Tracking / Autocross / HPDE / Drifting | 41 | 06-14-2015 01:20 PM |
| How do I check the tranny oil? | mashal | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 08-18-2014 03:03 PM |
| tranny fluid change | Dispect | Engine, Exhaust, Transmission | 3 | 01-27-2013 11:31 AM |
| Is the auto tranny from a isf? | WolfsFang | Engine, Exhaust, Transmission | 6 | 08-25-2012 09:25 PM |
| MT vs AT tranny... better MPG, 0-60? | subatoy | BRZ First-Gen (2012+) — General Topics | 163 | 03-26-2012 06:08 PM |
