Old 08-26-2013, 02:40 PM   #43
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Just ordered my 4.56 final drive from Weir Performance. Should be here by the end of the week!!!
Dustin is offline   Reply With Quote
Old 08-26-2013, 03:51 PM   #44
37
degrees
37's Avatar
Drives: 6MT BRZ
Here's the list I compiled with help from @Jeff Lange describing what all I'd need. Part numbers are on me so if anyone finds an error, please let me know so I can correct the list.
90179-20018 ... Pinion nut
90311-38070 ... Pinion seal
41231-24010 ... Pinion spacer
90366-35133 ... Pinion bearing*
90311-43009 ... Side seals (x 2)
41222-22010 ... Ring gear lock tabs (x 5)
12157-10010 ... Drain bolt gasket
SU003-00122 ... Fill bolt gasket
(listed above) ... Pinion bearing shims
(listed below) ... Diff washers**
*Note 1: Pinion bearing can potentially be reused if you or your shop has the removal tool and your bearing is still in serviceable condition. Replacement is recommended but not mandatory depending on these conditions.
**Note 2: Side washers might be needed depending on the new ring/pinion tolerances. If anyone has any input on this, please add to the discussion.
Diff washers in order of thickness:
90201-52001 ... T=2.58, MARK 01
90564-46014 ... T=2.60, MARK 32
90564-46015 ... T=2.62, MARK 33
90201-52003 ... T=2.64, MARK 03
90564-46016 ... T=2.66, MARK 34
90564-46017 ... T=2.68, MARK 35
90201-52005 ... T=2.70, MARK 05
90564-46018 ... T=2.72, MARK 36
90564-46019 ... T=2.74, MARK 37
90201-52007 ... T=2.76, MARK 07
90564-46020 ... T=2.78, MARK 38
90564-46021 ... T=2.80, MARK 39
90201-52009 ... T=2.82, MARK 09
90564-46022 ... T=2.84, MARK 40
90564-46023 ... T=2.86, MARK 41
90201-52011 ... T=2.88, MARK 11
90564-46024 ... T=2.90, MARK 42
90564-46025 ... T=2.92, MARK 43
90201-52013 ... T=2.94, MARK 13
90564-46026 ... T=2.96, MARK 44
90564-46027 ... T=2.98, MARK 45
90201-52015 ... T=3.00, MARK 15
90564-46028 ... T=3.02, MARK 46
90564-46029 ... T=3.04, MARK 47
90201-52017 ... T=3.06, MARK 17
90564-46030 ... T=3.08, MARK 48
90564-46031 ... T=3.10, MARK 49
90201-52019 ... T=3.12, MARK 19
90564-46032 ... T=3.14, MARK 50
90564-46033 ... T=3.16, MARK 51
90201-52021 ... T=3.18, MARK 21
90564-46034 ... T=3.20, MARK 52
90564-46035 ... T=3.22, MARK 53
90201-52023 ... T=3.24, MARK 23
90564-46036 ... T=3.26, MARK 54
90564-46037 ... T=3.28, MARK 55
90201-52025 ... T=3.30, MARK 25
90564-46038 ... T=3.32, MARK 56
90564-46039 ... T=3.34, MARK 57
90201-52027 ... T=3.36, MARK 27
90564-46040 ... T=3.38, MARK 58
90564-46041 ... T=3.40, MARK 59
90201-52029 ... T=3.42, MARK 29
90564-46042 ... T=3.44, MARK 60
90564-46043 ... T=3.46, MARK 61
90201-52031 ... T=3.48, MARK 31
37 is offline   Reply With Quote
The Following 10 Users Say Thank You to 37 For This Useful Post:
Anthony (08-26-2013), enjoyminutemaid (06-02-2014), Fly Guy (04-22-2014), GT86_PRAGUE (01-06-2015), jcw99 (03-06-2016), misooscar (08-26-2015), Mr. (10-12-2013), mtsui (08-27-2013), RehabJeff86 (12-05-2013), Toyota86.ir (10-10-2015)
Old 08-26-2013, 04:10 PM   #45
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Originally Posted by 37 View Post
Here's the list...
Very nice!
Originally Posted by Dustin View Post
More good info!!
I wish I was awesome enough to quote people from the future.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
Dustin (08-26-2013)
Old 08-26-2013, 04:35 PM   #46
Dustin
Twin Screw You
Dustin's Avatar
It's a gift. Lol, yeah I just copied and pasted from where he posted in another thread. Sorry bout that. Thanks for the great info @37!!
The Following User Says Thank You to Dustin For This Useful Post:
Anthony (08-27-2013)
Old 08-26-2013, 05:08 PM   #47
8686
8686's Avatar
Drives: 86
Originally Posted by 07jazzrs5gt86 View Post
What new seals part number you need for the install?
How many shims did it come with?
I've read on 1 of the cusco tread that each car have different shims size.
The mechanic told me he used the old seals.
I didn't count how many seals it came with. It was in a small clear bag that I was afraid to open. The install is done but I am on business trip and will not be able to get the car until Thursday when I am back home.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 08-26-2013, 05:15 PM   #48
8686
8686's Avatar
Drives: 86
Originally Posted by 448hpsti View Post
pics? before and after dyno? thx!
I don't believe this mod will add anything in term of HP. It will just help the car accelerate faster.
Old 08-26-2013, 05:18 PM   #49
8686
8686's Avatar
Drives: 86
Originally Posted by JimmyMac View Post
Looking forward to your install! Keep us posting on anything you come across.
The install is done buy our local mechanic but I will not be able to drive the car until Wednesday. cant describe my feelings.
By the way my car is AT
Old 08-28-2013, 11:04 PM   #50
8686
8686's Avatar
Drives: 86
Just drove my car around the block. Difinitly accelerate better. Mostly in 1-3 the gears are shorter than before. My guess, is gears became like MT from 1-3. Need to drive it on the high way to test 4-6 gears. I am very satisfied with this change.
Sent from my iPhone using Tapatalk - now Free
Old 08-31-2013, 01:09 PM   #51
Dustin
Twin Screw You
Dustin's Avatar
Just got my Weir Performance 4.56 final drive and solid pinion spacer. He supplied shims for both. I'm going to buy a few more things before installing it but we've purchased from Weir before and his products are top notch!! We have his axles, final drive, and solid pinion spacer in my brother's AE86. Anyone wanting to do this mod should definitely get in touch with him. Everything for well under $400 shipped and I received it in 2 days!!!
The Following 12 Users Say Thank You to Dustin For This Useful Post:
8686 (08-31-2013), Anthony (08-31-2013), Carlitoz3 (02-07-2016), DAN_BRZ (12-05-2013), GT86_PRAGUE (01-06-2015), jcw99 (03-06-2016), JiB (09-01-2013), JimmyMac (08-31-2013), leon78 (09-01-2013), number1Tango (10-11-2014), RehabJeff86 (12-05-2013), Toyota86.ir (10-10-2015)
Old 08-31-2013, 01:12 PM   #52
Anthony
Weight Nazi
Anthony's Avatar
Very nice.
Dustin (08-31-2013)
Old 08-31-2013, 02:02 PM   #53
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Damn. Nice.
448hpsti is offline   Reply With Quote
The Following User Says Thank You to 448hpsti For This Useful Post:
Dustin (08-31-2013)
Old 08-31-2013, 09:58 PM   #54
37
degrees
37's Avatar
Drives: 6MT BRZ
Nice! Let us know how your install goes without the pinion bearing. For that price I'd have bought one without question, especially since he offers Koyo.
The Following User Says Thank You to 37 For This Useful Post:
Dustin (08-31-2013)
Old 08-31-2013, 10:01 PM   #55
Dustin
Twin Screw You
Dustin's Avatar
That's one of those things I still have to buy. I'm gonna get the pinion bearing, pinion seal, and a few other things.
The Following 2 Users Say Thank You to Dustin For This Useful Post:
37 (08-31-2013), RehabJeff86 (12-05-2013)
Old 09-01-2013, 01:53 AM   #56
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
if youre careful and low miles shouldnt be an issue if youre delicate with the press!
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 489 06-17-2018 01:14 AM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 03:21 AM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 05:06 AM
Anyone w/ 3.727/3.909 Final Drive Post Boost? Staf00 Engine, Exhaust, Transmission 12 05-02-2013 09:38 PM
