Old 08-09-2013, 04:03 PM   #15
qoncept
qoncept's Avatar
Originally Posted by rupert View Post
That's what I feared. I don't know first hand, but I figured using that as a bobo crossover would end up rather meh.
At one point someone recommended just disconnecting the door speakers. I had already done it at one point while I was trying out a pair of speakers I had laying around. You end up with NO mid bass at all, of course.
qoncept is offline   Reply With Quote
Old 08-09-2013, 04:53 PM   #16
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
I get a lot of rattle from the door speakers from bass. Particularly hip hop music. It's not my favorite genre so I don't listen all the time but when I do the door rattle is really annoying. If I get a sub like the stealthbox will it eliminate the rattle since the bass will be going elsewhere?
No and Yes.
Simply adding a sub will do nothing to stop the doors from providing sympathetic harmonics (rattling). But adding a sub and a cross-over network can stop the rattling AND improve the sound quality. This works because you can limit the low frequencies that you send to the door speakers (only frequencies between 100 and 3000Hz)
And I said "can" because as others have pointed out, if there is something loose in the door you will still need to address that.
Of course, adding a sub can also make things in the truck rattle...but that's a whole new project
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 08-09-2013, 09:31 PM   #17
ZionsWrath
Thanks
ZionsWrath's Avatar
Where can I purchase a small amount of dynamat? Not looking to cover my whole interior, just those bits pointed out in some of the posts above and see where that gets me.
Old 08-09-2013, 11:49 PM   #18
Gary in NJ
Gary in NJ's Avatar
ebay...amazon...Crutchfield...local car audio shop
Old 08-11-2013, 01:38 AM   #19
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Most companies will sell a "door pack" with enough square footage to do a pair of doors, some companies will a single sheet of their product which is typically between 1.5-2 square feet.
Most audio supply places will carry something, and dome places will sell direct to the customers. If you need some suggestions, I use Second Skin Audio products http://store.secondskinaudio.com but Raam Audio also have good products. http://www.raamaudio.com. The only product I can't recommend is Hushmat, but that is due to them taking my money but never fulfilling the products I ordered a long time ago.
If you want to improve the sound from your doors, check out my thread on sealing and deadening the doors, which is a fancy way of saying that you're turning the door into a speaker enclosure. http://www.ft86club.com/forums/showthread.php?t=28506
It's a bit more work and requires a few more materials, but makes a tremendous improvement in sound quality.
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
The Following User Says Thank You to WolfSongX For This Useful Post:
ZionsWrath (08-11-2013)
Rattle-ly Speaker Door Panels engee Cosmetic Modification (Interior/Exterior/Lighting) 45 11-25-2014 08:45 AM
Door speaker question BlackyRose Electronics | Audio | NAV | Infotainment 2 07-26-2013 11:45 PM
Door Speaker Vibration MattM232 Issues | Warranty | Recalls / TSB 16 03-19-2013 08:03 PM
Rattle in door speaker panels Lefty Electronics | Audio | NAV | Infotainment 2 06-18-2012 07:41 PM
Driver Side Speaker Housing Rattle Lefty Scion FR-S / Toyota 86 GT86 General Forum 2 06-12-2012 11:32 AM
