Old 07-15-2013, 01:00 AM   #155
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Originally Posted by FRSBRZGT86FAN View Post
Completely incorrect they said in an interview or press release somewhere that that currently with their business plan they have no interest in Normally aspirated vehicles, they focus only on forced induction now.
Originally Posted by xjohnx View Post
It's not happening. I spoke with them Wednesday.
Originally Posted by Apoc View Post
That would be hard since they have no interest in this platform. The recent posts here were purely misinformation. Unfortunately misinformation flows freely here.
dreams killed x3. lol i really dont like how ecutek licenses work
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 07-15-2013, 03:00 AM   #156
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I read the first few pages then gave up haha.
EcuTek is way to expensive, even more so here in Australia, it's way over priced.
It is cheaper to order a cable and have it sent to a US PO Box and have it forwarded, then buy the tunes from US companies.
AUD$1800+
it's not worth the few KW gain you might get.. \
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 07-15-2013, 08:23 AM   #157
xjohnx
Grip>Slip
xjohnx's Avatar
I've seen several cars with bad OB2 ports
This x1000.
@swift996 i had this happen in my car. Ever since it happened I have found the best way to verify my cable has a solid connection (until I repin my obd2 port) is to go into data logging/map access mode for a few minutes prior to flashing. If the car doesn't drop connection after a few minutes in map access mode, then I know that I have a solid connection and can proceed with the flash.
A bit of a pain, but not nearly as bad as being stranded.
Nightbringer (07-15-2013)
Old 07-15-2013, 09:22 AM   #158
swift996
swift996's Avatar
This x1000.
Thanks, I found if it goes through the Query ECU process than it's good. I'm getting a new cable sent so I'll see if that was truly the issue. At least for now though I'll just leave it alone because my car = fun to drive
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-15-2013, 09:34 AM   #159
xjohnx
Grip>Slip
xjohnx's Avatar
When mine failed it did so after completing the query ECU process successfully and flashing about 50% of the rom. Hopefully the new cable fixes it, although it looks like a lot of OBD2 ports on these cars are having their pins stretched out. Certain adapters work better than others in my car, that is for sure.
Once i verify my port is good and whether or not i need to repin it, i'll be plugging in an OBD2 extension cable that i keep permanently connected, then do all my plugging/unplugging on the other end of the cable, that way the cars port doesn't get worn by repeated plugging/unplugging, instead the extension cable does.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
ATL BRZ (07-15-2013), JimmyMac (07-15-2013)
Old 07-15-2013, 10:41 AM   #160
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Hmmmm good idea!
JimmyMac is offline   Reply With Quote
Old 07-15-2013, 11:34 AM   #161
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
I shall mourn with you as well friend
Old 07-15-2013, 12:27 PM   #162
CSG Mike
CSG Mike's Avatar
Generally, yes. Most of the bigger tuners, from what I understand, operate this way. Also if ECUTek releases new features, or updates some basic level coding stuff enough to have a new file version, the tuners shoot out those updates for free.
I've never worked with a tuner who retunes for free. Software updates are software updates; they add features, but it doesn't change the tune itself.
It's like getting iTunes updates; Apple gives the updates to you for free, but you don't get any more content for free.
Xero-Limit (07-15-2013)
Old 07-15-2013, 12:33 PM   #163
xjohnx
Grip>Slip
xjohnx's Avatar
Both Visconti and FA20club provide updates free of charge (assuming it's not a major change.) Things like adding a header or intake they'll retune for free based on your logs.
Major changes (sc/turbo) obviously require you to purchase a new tune.
Old 07-15-2013, 12:54 PM   #164
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Seems there is some level of confusion even with customers about what is 'updated' for free and what 'minor tune changes' are covered etc.
I mean 'free updates for life' to my mind is extremely different from 'free tunes for life'.....which is what some people that posted are under the impression they will get.
Toma is offline   Reply With Quote
The Following User Says Thank You to Toma For This Useful Post:
Ammonia (07-15-2013)
Old 07-15-2013, 01:45 PM   #165
CSG Mike
CSG Mike's Avatar
If I got free retunes for life, I'd gladly shell out a few THOUSAND dollars, because I certainly will be getting more than my money's worth.
Old 07-15-2013, 02:08 PM   #166
Dynotronics1
That's how we do it. Not sure what limits the other vendors use, but as long as you stay within the same type of induction, your updated calibrations are free for as long as you own the car
Dynotronics1 is offline   Reply With Quote
Old 07-15-2013, 02:14 PM   #167
DJCarbine
Thupercharged
DJCarbine's Avatar
Is there?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-15-2013, 02:19 PM   #168
fenton
So would you be against a customer selling your "updated tune for life" to another person assuming you could confirm the first person removed from their car?
Everyone is talking about these free updates but what does it matter who is getting these free updates, the first or the second customer.
I can understand license because that is tied to your ECU but in the perfect world they should be able to "untie" it from you ECU if you are no longer using it.
And saying these aren't canned tunes is kind of misleading, out of the 300+ tuned BRZ/FRS's how many just run the tune they are given? Im guessing that number is way over 80 percent.
I know I have never requested a fine tuned tune because they have always ran just fine(on base/canned tune), as will most others.
fenton is offline   Reply With Quote
Ecutek's 86 jpit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 07-12-2013 01:35 PM
Will the new Subaru WRX kill resale value of the 3rd gen WRX's? CSI:86 Other Vehicles & General Automotive Discussions 20 06-05-2013 10:31 PM
resale value kbb available Celica00 Scion FR-S / Toyota 86 GT86 General Forum 16 05-24-2013 01:03 PM
resale value jmaryt Scion FR-S / Toyota 86 GT86 General Forum 28 10-08-2012 10:58 PM
ECUTEK????? 20valvewynn83 Engine, Exhaust, Transmission 4 10-03-2012 10:34 PM
