Old 07-12-2013, 12:25 PM   #57
ayau
Drives: Some rust bucket
Originally Posted by RehabJeff86 View Post
My cylinder #3 diagnosed with misfiring with DI failure and its being replaced by Scion warranty as we speak.
Do you track your car? Just trying to get an idea of how these cars fail.
Old 07-12-2013, 12:25 PM   #58
CSG Mike
CSG Mike's Avatar
Originally Posted by track_warrior View Post
Auto-X is light abuse as you are not wot for a 30 minute session and therefore cant generate enough heat to melt the seal. I think this issue will develop on auto-x and spirited drive cars later than on full track cars. My car had 4000 track miles when the injector failed and caused a hole in my piston. Im thinking its a simple fix but it all begins with toyobaru admitting something is wrong and offering a flash fix or DI replacement.
Detonation is detonation...
I've seen cases where it started after just an outlap on the track
Old 07-12-2013, 12:26 PM   #59
CSG Mike
CSG Mike's Avatar
Originally Posted by Toma View Post
Well if the problem truly is 'detonation' 100 octane fuel should easily fix it.
Incorrect. 100 octane can't compensate for a bad timing table.
Old 07-12-2013, 12:30 PM   #60
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
I prefer not to disclose any further information
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 07-12-2013, 12:32 PM   #61
ayau
Totally understand.
Feel free to send me a PM.
Old 07-12-2013, 12:46 PM   #62
RehabJeff86
Totally understand.
Well i think u already know the answer
Old 07-12-2013, 08:18 PM   #63
Tainen
Drives: First SWP BRZ-L
Love your profile pic.
FYI, I can *definitely* hear the det on tip in with my headers. The louder exhaust has made it significantly more noticeable. Autocross actually made it det a TON, since you are on/off/on/off/on throttle the entire course, most of the time above 5800. I was cringing when in the passenger seat as an instructor was driving because of her really great accelerator pedal modulation was making it det pretty much constantly the entire course.
There was far, far less det on the car on the track, since it only det'd once per upshift, instead of 3 or 4 times a second x 60 seconds like it did in autocross.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
The Following User Says Thank You to Tainen For This Useful Post:
RehabJeff86 (07-12-2013)
Old 07-13-2013, 02:25 AM   #64
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Can someone help me figure out my torque readings and if it relates to the DI issue?
I ran the Knock Detector app (https://play.google.com/store/apps/d...kills.kd&hl=en) and did some runs in 2nd and 3rd gear and random RPMs and had a "Possible Knock" maybe 1 out of 5 times or so. Also in the app, my throttle while fully depressing the gas to WOT was only around 83% (should be 99 or close I assume), anyone know what could be causing this? Maybe the ECU holding back for some reason?
Secondly my AFR numbers don't look so good.. Normally around 14-15 at idle which is fine but I have seen it spike to 20 occasionally running extremely lean. One specific instance I remember was when I was coming to a stop and it jumped up to 20 for a seond before returning to ~14.5 at idle. I am assuming this is not normal; can anyone chime in on what's going on? Possible leak causing the AFR to run super lean?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-13-2013, 08:56 PM   #65
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Good question. I dont have a answer for you but maybe someone out there does? I have seen the same afr numbers when doing logging before. Mainly when there was 0 load and 0 throttle postion for a moment.
I do know that at wot the throttle postion is always around 80ish percent. Not sure why they do that.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 07-13-2013, 10:25 PM   #66
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
Can all the folks that actually have the DI issue please let us know your car's build dates... maybe the newer ones already have this fix. So far, all of the cars I know about is was purchased in 2012 with build date in 2012. Can someone confirm or deny this?
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 07-14-2013, 02:57 AM   #67
ft_sjo
Drives: GT86
All of the above is perfectly normal and not a problem.
The Following User Says Thank You to ft_sjo For This Useful Post:
l0aded (07-15-2013)
Old 07-14-2013, 08:10 AM   #68
regal
Drives: Scion FR-S/Toyota Yaris
may be normal for these cars but it certainly is a problem.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 07-14-2013, 08:25 AM   #69
robispec
Drives: Black frs project
and my response
http://www.ft86club.com/forums/showt...34#post1068034
again Mike drove a car on the track KNOWING that the seal had already failed. They had taken the car to the dealer and they said bring it back when it has a code... It was popping going out on the track....and once you have heard this sound you KNOW that the seal is bad. Mike knew this and drove it anyway...
robispec is offline   Reply With Quote
The Following 3 Users Say Thank You to robispec For This Useful Post:
FRSBRZGT86FAN (07-15-2013), michaelosx (07-14-2013), Mikem53 (07-14-2013)
Old 07-14-2013, 11:57 AM   #70
ft_sjo
Drives: GT86
Sometimes I wonder if you're just plain stupid, or are only interested in listening to yourself and/or whatever on Google matches your delusions? Most modern vehicles have adaptive spark strategies which constantly advance the spark angle until a knock event occurs.. KNOCK HAS TO OCCUR FOR THIS TO WORK.
End of discussion. Stop spreading FUD and paranoia.
Trunk release failure - BRZ Smilez CANADA 35 07-15-2019 11:15 PM
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 12:25 PM
100% DI Failure with Nurburgring rentals regal Scion FR-S / Toyota 86 GT86 General Forum 538 10-07-2013 06:18 PM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 09:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 01:25 PM
