go_a_way1
Old 07-10-2013, 11:01 PM   #1569
orod35
orod35's Avatar
Drives: silver 2013 scion frs
Originally Posted by ill86 View Post
Yes, it will be OK.
Future reference = read this thread and grab a measuring device and/or online calculator.
correction to my measurements. i actually have 18x8 et 35 oz superleggera wheel. i was looking at 245 35 18 tires im skeptical. also is there a place i can order custom centercaps?
orod35 is offline   Reply With Quote
Old 07-11-2013, 12:17 AM   #1570
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Wheel size and tire size is good. :happy0180:
Not sure on center caps.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 07-11-2013, 12:33 AM   #1571
GoSharks
GoSharks's Avatar
Drives: BRZ Limited, WRB, 6 MT
Going a bit crazy on the tire/wheel combo's. Thinking seriously of 18' wheels. I like the RFP1's in 18x8 +45, with PSS 245/35/18 or the Raijins 18.5 +45, same tires. I also like the Rota Torques, staggered 18x8.5/9.5, square 18x8. For my WRB, Gold/Sports Bronze. DD, but maybe a school or track day (again), not looking to drop the suspension right away. Thoughts? Tire Rack says either Enkei's will fit fine. Plan to check out the Rota's at Wheel Dude.
GoSharks is offline   Reply With Quote
Old 07-11-2013, 01:16 AM   #1572
ill86
ill86's Avatar
Drives: iG FR-S
Your call, bro. Are you looking for opinions on wheel choice? If so, I'd go Enkei over Rota.
For DD either would work fine. 245 on an 8 or 8.5 is good.
The Following User Says Thank You to ill86 For This Useful Post:
GoSharks (07-11-2013)
Old 07-11-2013, 02:11 AM   #1573
orod35
orod35's Avatar
Thanks alot
Old 07-11-2013, 03:58 AM   #1574
ill86
ill86's Avatar
Drives: iG FR-S
No problem
Old 07-14-2013, 05:23 PM   #1575
Dipstik-sportech
Dipstik-sportech's Avatar
Will this fit? (width, offset and tire size Qs)
Will stock mk4 supra wheels with 275/40-17 drag radial fit with the project kicks adapters? Or my other option is ap1 s2k wheels with 255/60-16 drag radials. Reason I'm looking at these options is that buddies have them available for me to use rater than buying a wheel and tires setup. The supra is 50 offset and the s2k is 65
Old 07-16-2013, 05:28 PM   #1576
ill86
ill86's Avatar
Drives: iG FR-S
Need more info-
Wheel width (also double check offset)
Just rears or all four?
Old 07-16-2013, 05:32 PM   #1577
Dipstik-sportech
7.5" wide and they're +63 offset. I plan to run a 1" spacer due to the high offset. Just the rears yeah, no need for drag radials on the front lol
Old 07-16-2013, 08:07 PM   #1578
Drftfan
Drives: Argento FR-S
17x9 +20 with 215/45 17 fit?
This is your first performance car?
Drftfan is offline   Reply With Quote
Old 07-16-2013, 08:18 PM   #1579
ill86
ill86's Avatar
Drives: iG FR-S
Effectively a 7.5" +38
With 275 it should fit fine
Rear only drag radials... Yeah yeah :-)
Old 07-16-2013, 08:19 PM   #1580
ill86
ill86's Avatar
Drives: iG FR-S
It will fit but poke... 25mm - 30mm front.
215 on a 9" wheel is obviously a stretch fit.
(will work fine)
Old 07-17-2013, 10:23 AM   #1581
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
I've been getting biased opinions and I need to expand my question to a bigger party.
18x9 +33 offset. 255/35 tire. Stock suspension. Will it rub in the front? I want to keep the front full, as in chunky and full of meat.
I am very insecure. I have no friends. I want people to love me
Old 07-17-2013, 10:53 AM   #1582
djdnz
1337
Drives: 2013 BRZ WRB S/C
Stock suspension, no shouldn't have issues, at least none at the suspension side of things. If you lower you might have some issues at the fender. It's going to poke a lot at stock height. Mexi-flush for sure.
djdnz is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
