#29 |
#30 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Tim_Asphalt_FRS (07-12-2013) |
#31 |
Waited 5 years for this
Drives: '18 MX-5 Club
I understood it as it happens when RPM is above 5200 "after" the shift. If you rev to red line in 1st gear, it drops to 4500 RPM in 2nd gear. So, to create the condition in 1-2 shift, you will need to rev the 1st gear to 8600 RPM.
#32 | |
#33 | |
#34 |
Drives: 2013 BRZ Limited
It seems like aftermarket tunes are remedying this though?
#35 |
Drives: 1985 P-Type
Remember, not everybody wants an aftermarket tune. If the car has a defect, the manufacturer should fix it. They have done so in South Africa, at least, we hope so... it will take some time to see if the "fix" is effective and the problems cease.
#36 |
Member of the year - 2016
Drives: Scion FRS
These topics are discomfiting.
Now afraid of going past 30K in miles, don't want to miss the TSB...
#37 |
They are but nobody wants to pay 600+ dollars for an EcuTek tune that's great and all but it really be Toyota/Subaru's job to fix and/or prevent this, not the owner to go buy there own aftermarket tune and also void any future repairs on the ECU where they will just blame it on your other tune.
#38 | |
| The Following User Says Thank You to Taber For This Useful Post: | FRSBRZGT86FAN (07-10-2013) |
#39 | |
Drives: A lot of supercars.
I promise you you'll notice very tiny misfires at high rpms. I did 2 months before things went really south with the injector seals completely damaged and started to go off like fireworks.. I should've known.. Idky there is a new thread on this SAME issue that's been brought up for months now. |
#40 |
#41 |
As of right now sure. But to put it in perspective I know about 15 86 owners in my local area and 4 of them have had the DI collar issue. 1 of them that has had the issue is active on these forums. All 4 of us are 20k Miles + and bought the car either last June/July.
| The Following User Says Thank You to Carwhisperer For This Useful Post: | bestwheelbase (07-10-2013) |
#42 |
Drives: 1985 P-Type
Exactly. Lots of owners don't post on forums.
| The Following User Says Thank You to bestwheelbase For This Useful Post: | Carwhisperer (07-10-2013) |
| Trunk release failure - BRZ | Smilez | CANADA | 35 | 07-15-2019 11:15 PM |
| Raven down! Mechanical failure :( | rasec29 | Issues | Warranty | Recalls / TSB | 151 | 10-08-2013 12:25 PM |
| 100% DI Failure with Nurburgring rentals | regal | Scion FR-S / Toyota 86 GT86 General Forum | 538 | 10-07-2013 06:18 PM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 09:32 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 01:25 PM |
