Old 07-09-2013, 07:18 PM   #29
thill
Sorry, can't see videos at work (I have a real day job... I just pretend to be a racecar driver on the weekends)
Those dang'd day jobs....
Old 07-09-2013, 07:25 PM   #30
CSG Mike
CSG Mike's Avatar
Originally Posted by ayau View Post
He's a forum junkie during the day.
Multitasking
Tim_Asphalt_FRS (07-12-2013)
Old 07-09-2013, 07:48 PM   #31
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by denkigrve View Post
It should still happen on any shift in any gear since the load is based on RPMs and not gears.
I understood it as it happens when RPM is above 5200 "after" the shift. If you rev to red line in 1st gear, it drops to 4500 RPM in 2nd gear. So, to create the condition in 1-2 shift, you will need to rev the 1st gear to 8600 RPM.
Old 07-09-2013, 07:51 PM   #32
Sigh-on-Rice
Originally Posted by thill View Post
Got it. If that South African TSB is correct it describes this condition occurring when you are above 7k rpm in either 3rd, 4th, or 5th gear and then end up back above 5200rpm on the upshift. Not sure why this would not apply to 1st and 2nd (ECU must protect for this?)
Again, assuming all of this is even accurate.
If you rev 1st gear to 7450 and shift to 2nd gear, the RPM would be at 4500.
Old 07-09-2013, 08:07 PM   #33
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Well, the fix retards timing after 5200 rpm in 3rd 4th and 5th, Idk but wouldn't that mean that maybe the timing is too far advanced by the ecu during and after 3rd?
Old 07-09-2013, 09:28 PM   #34
Taber
Drives: 2013 BRZ Limited
It seems like aftermarket tunes are remedying this though?
Taber is offline   Reply With Quote
Old 07-09-2013, 11:37 PM   #35
bestwheelbase
Drives: 1985 P-Type
Remember, not everybody wants an aftermarket tune. If the car has a defect, the manufacturer should fix it. They have done so in South Africa, at least, we hope so... it will take some time to see if the "fix" is effective and the problems cease.
Old 07-09-2013, 11:54 PM   #36
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
These topics are discomfiting.
Now afraid of going past 30K in miles, don't want to miss the TSB...
Old 07-09-2013, 11:55 PM   #37
FRSBRZGT86FAN
Smile
They are but nobody wants to pay 600+ dollars for an EcuTek tune that's great and all but it really be Toyota/Subaru's job to fix and/or prevent this, not the owner to go buy there own aftermarket tune and also void any future repairs on the ECU where they will just blame it on your other tune.
Old 07-10-2013, 09:58 AM   #38
Taber
Oh, I agree 100% with you. A brand new "sports" car should not require an expensive aftermarket tune to fix something like this. My question was really geared more towards myself, who was planning on purchasing a tune in the next month or so anyway, so if this is infact a fix, then great, I'll buy it now.
The Following User Says Thank You to Taber For This Useful Post:
FRSBRZGT86FAN (07-10-2013)
Old 07-10-2013, 06:35 PM   #39
Carwhisperer
Drives: A lot of supercars.
Right, but the detonation should be quite noticeable (popping/backfire) correct? I shift quite often in the 5200+ rpm range from 1-2 and 2-3. I can only imagine lots of people are doing this as well besides me and I have never heard a detonation occur. It seems like this would be happening a lot and there would be tons of failures vs just a handful that have been reported here??
YES. You'll know.
I promise you you'll notice very tiny misfires at high rpms. I did 2 months before things went really south with the injector seals completely damaged and started to go off like fireworks.. I should've known..
Idky there is a new thread on this SAME issue that's been brought up for months now.
Carwhisperer is offline   Reply With Quote
Old 07-10-2013, 06:43 PM   #40
reeves
Don't worry, it's only affecting ~1% of the cars out there.. you're ~99% safe. I stomp on mine's all the time without worry.. almost up to 30K too
Old 07-10-2013, 07:39 PM   #41
Carwhisperer
As of right now sure. But to put it in perspective I know about 15 86 owners in my local area and 4 of them have had the DI collar issue. 1 of them that has had the issue is active on these forums. All 4 of us are 20k Miles + and bought the car either last June/July.
The Following User Says Thank You to Carwhisperer For This Useful Post:
bestwheelbase (07-10-2013)
Old 07-10-2013, 07:53 PM   #42
bestwheelbase
Drives: 1985 P-Type
Exactly. Lots of owners don't post on forums.
The Following User Says Thank You to bestwheelbase For This Useful Post:
Carwhisperer (07-10-2013)
Trunk release failure - BRZ Smilez CANADA 35 07-15-2019 11:15 PM
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 12:25 PM
100% DI Failure with Nurburgring rentals regal Scion FR-S / Toyota 86 GT86 General Forum 538 10-07-2013 06:18 PM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 09:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 01:25 PM
