Old 07-07-2013, 02:09 PM   #43
Sasquachulator
Pavement Grey
Originally Posted by serialk11r View Post
lol, that's not really how it works.
Its how everything works on the internets. Everyone's an expert and can suggest the obvious easy fix that should take like 5mins to do.
Old 07-07-2013, 02:09 PM   #44
Dezoris
Dezoris's Avatar
Originally Posted by regal View Post
We need a volunteer to pull there injectors, someone who drives spiritedly has over 25k miles and is confident nothing is wrong with the car. Inspect the seals, how are they holding up ? I'd do it but I only drive 7k per year. I'd be willing to pitch in $100 if we started a collection and it was well documented.
Problem is its not as easy as just pulling them, as the service manual states there are non-reusable parts. Just to remove them you need to replace the two of the stainless fuel lines.
I ordered all the parts so I can at least pull them to inspect but was told it was 45 days before they would maybe have the parts. (Seals, insulator, fuel pipes etc.)
It just blows.
Old 07-07-2013, 03:21 PM   #45
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
It just blows.
It does blow, but if your replacing the injectors why not completely replace them with aftermarket parts like say from Deatschwerks or something?
Old 07-07-2013, 03:22 PM   #46
ft_sjo
Drives: GT86
Please stop typing. You're not qualified.
Old 07-07-2013, 03:27 PM   #47
FRSBRZGT86FAN
Smile
Sorry just wondering, stupid question then
Old 07-07-2013, 03:33 PM   #48
Dezoris
Dezoris's Avatar
The car has 8 injectors.
4 Port Injectors (like the ones you referred too)
4 Direct injectors (In cylinder), these are the ones you won't find aftermarket support on and are much more complicated. Also the ones that are having heat/seal issues on some cars.
The Following User Says Thank You to Dezoris For This Useful Post:
FRSBRZGT86FAN (07-08-2013)
Old 07-07-2013, 03:42 PM   #49
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
It just blows.
Couple quick questions.. Are you already experiencing problems with your DI seals or are you doing this out of curiosity and preventative maintenance? Lastly, the parts are 45 days out but out of curiosity how much is the whole setup with the replacement lines and all?
chadstyle is offline   Reply With Quote
Old 07-07-2013, 03:46 PM   #50
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Originally Posted by Muaddib View Post
I am not taking mine past 5k rpm when it is under WOT.
If i was you i would punch it and not baby it while its still in warranty. That way if you ever have an issue it will get fixed.
Originally Posted by lsxiong View Post
We should Sticky this thread for all owners to be aware so Toyota can do something about this. I don't want to buy the car now knowing I will baby it for 5 years then maybe eventually tracking this car after the warranty period.
This car is not reliable when driven spiritedly.
Here is the thread, i encourage everybody that has had this issue to vote.
http://www.ft86club.com/forums/showthread.php?t=38397
20K here and nothing so far.
A rental car having car problems? You guys new to the car world...?
I suggest you read these 3 threads:
http://www.ft86club.com/forums/showthread.php?t=36129
http://www.ft86club.com/forums/showthread.php?t=37810
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following 3 Users Say Thank You to track_warrior For This Useful Post:
KGFRS86 (07-08-2013), Lonewolf (07-07-2013), Rampage (07-07-2013)
Old 07-07-2013, 03:49 PM   #51
brillo
Drives: 2013 Firestorm FR-S
http://www.ft86club.com/forums/showt...83#post1050783
I posted contact info for various auto media if folks want to voice there concerns and for an aftermarket shop that might be able to provide stronger seals in the above thread.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-07-2013, 03:53 PM   #52
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Alright, looks like around 20 people have had this problem.
How many cars have been sold in total?
The Following User Says Thank You to dem00n For This Useful Post:
suaveflooder (07-07-2013)
Old 07-07-2013, 03:56 PM   #53
track_warrior
Track Junkie
You had not seen the thread just like probably more than half the forum. Trust me its a matter of time before you will start seeing the numbers rise. If you track your car or drive hard it will happen sooner or later unless toyota and subaru come up with a permanent fix. My Engine was replaced under warranty and my car has not seen any track since the build, i have 500 miles since it came out of the dealer with a new engine and i just threw a misfire code yesterday but now in cylinder #3. The problem with the Direct injectors is the constant heat from WOT pretty much melts the seal, car goes lean and you start getting misfires that can lead to catastrophic engine failure.
BTW direct injectors seal replacement parts are out of stock nation wide.... I wonder what that means.
Old 07-07-2013, 04:03 PM   #54
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Originally Posted by bestwheelbase View Post
@regal we think good information will come from those who inspect their direct injectors even if they're not experiencing engine problems. There may be many people on the road to premature failures who do not yet realize it.
It never hurts to check, right? Everyone can learn from it.
Someone make a how to and throw it in the DIY and ill have my brother help me do this when we install my catback.
SubaSteve is offline   Reply With Quote
The Following User Says Thank You to SubaSteve For This Useful Post:
bestwheelbase (07-07-2013)
Old 07-07-2013, 04:04 PM   #55
Dezoris
Dezoris's Avatar
I just ordered:
The seals, insulators and fuel pipes for all 4 injectors the intake manifold gaskets and throttle body gaskets required. $400.
When my engine gets hot usually after driving an hour, if I apply full throttle at about 4000RPM I get a loud pop from under the hood. It has happened twice. So I want to pull them to check
If you order a new injector it comes with all the seals installed already.
Each injector is $300.
Its not as easy as ordering the injectors. As they have a flow number on them.
All 4 injectors will have the same number, but there are 3 different part numbers which means you could have number 1, 2 or 3 stamped on the injector.
So basically because of the parts delay, you will have to pull the injectors twice if you have a scorched injector. First to inspect and get the number and order the right part and then a second time to replace an injector if it is bad.
Regardless anytime you pull them to inspect you need intake man gasket, throttle body gasket and fuel pipes per service manual to be replaced.
chadstyle (07-07-2013)
Old 07-07-2013, 04:33 PM   #56
civdaddy
Drives: Slow
^ I say u and turbowski make a video of the di inspection!
civdaddy is offline   Reply With Quote
regalsurinalpost
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 11:25 AM
86 rentals - 2013 era bcj AUSTRALIA 11 04-23-2013 10:27 PM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
BC Coilover failure in the past phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-25-2012 05:07 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
