#281 |
#282 |
Drives: FRS Silver LS1 swapped.
#283 |
Drives: Scion FR-S/Toyota Yaris
Maybe the cams have a bit to do with detonation? Remember the South Aftrical TSB was issued 4 months ago, so obviously Toyota has no corporate universal agreement to the problem. Subaru may have found the cause with the cam sensor shim, unfortunately it isn't a realistic procedure for most Subaru dealers to perform and obviously Scion isn't signing up for it.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#284 | |
Drives: Moped
I just want to buy my FRS, but I won't as long as these unresolved engine issues remain (seals, injectors, oil leak, stock tune is still garbage).... |
#285 |
I wonder if Subaru South Africa has the TSB
#286 |
Drives: Sterling BRZ Ltd
What do this injectors and seals cost? Obviously I believe Subaru/Toyota should cover the costs but I haven't seen it mentioned.
I'm curious what will happen to guys who have through out the warranty with FI
#287 | |
Its been posted that the seals and gaskets required to be replaced when pulling the injectors are completely out of stock nation-wide and back ordered for months.
#288 |
Yes I read that, I'm more curious as to the price of the parts.
#289 | |
Drives: 1985 P-Type
#290 |
Drives: Asphalt FRS
I don't currently have this problem. I'm at ~1400 miles and still on factory oil.
Once I change my oil should I drive the living hell out of this thing to make sure any problems arise during the warranty period? Definitely worried about this one. We as owners really need to stick together here and do whatever it takes to get Toyota/Subaru to acknowledge and rectify this problem. |
#291 |
Drives: 1985 P-Type
If you're concerned these issues will impact other owners, you need to file a complaint at the link below and make sure that they are all filed under the same category. It is these complaints that lead to recalls.
https://www-odi.nhtsa.dot.gov/ivoq/ |
| The Following User Says Thank You to bestwheelbase For This Useful Post: | yuicebox (07-18-2013) |
#292 |
Drives: A lot of supercars.
Car just threw P0351 - Ignition Coil "A" Primary Control Circuit/Open. The same CEL I got a couple of months ago right before I started getting firecrackers. Awesome.
| The Following User Says Thank You to Carwhisperer For This Useful Post: | Astroboy (10-02-2014) |
#293 | |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
Lemon car?
| The Following User Says Thank You to whitefrs For This Useful Post: | Astroboy (10-02-2014) |
#294 |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 05:26 PM |
| Direct Injector's Leaking | Carwhisperer | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-11-2013 10:31 AM |
| Leaking Oil? | 636 | Issues | Warranty | Recalls / TSB | 11 | 01-05-2013 05:43 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 06:03 PM |
