go_a_way1
Old 06-20-2013, 02:27 AM   #1527
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by hanabie View Post
Will 18x9 +42 265/35 hit the rear stock strut? Thanks.
It should not. I can measure in the AM if you like.
And yes, I would choose 245/35 over 245/40. The latter is too tall.
If staggering, 235/40 on 8" front, 265/35 on 9" rear
If square, 245/35 on 8"-9" front/rear
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
hanabie (06-20-2013)
Old 06-20-2013, 03:45 AM   #1528
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
Amazing thread ... Amazing help ... Amazing community
As a newb to the modifying scene, and a new FR-S owner, my question is as follows ...
I love TE37SLs ... but seems to be too many around and I'd like a bit of uniqueness to my new money sink and love, thus I'm wondering if these will fit and what would be the best tires for said combination:
Stock Suspension
Volk Racing G2 - 18x9 / 5x114.3 / Offset +50 on the front and rear
I'm guessing with 5 mm spacer on the rears?
235/35 or 245/35 rubber on all 4
Further question - with the 5mm spacer on the rear to push the wheel out, would I need a kit for the log bolts or would I have enough thread to handle the 5mm? This is a daily driver with tracking becoming more prevalent as mods are added.
Any input would be GREATLY appreciated!
TrogDor the Burninator is offline   Reply With Quote
Old 06-20-2013, 04:15 AM   #1529
ill86
ill86's Avatar
Drives: iG FR-S
@TrogDor the Burninator
^ Incorrect pcd. FR-S and BRZ are 5x100
Offset is a little high..
Please, if you haven't already, read this thread in its entirety ..
Welcome to the forums and world of modifying cars... :happy0180:
Old 06-20-2013, 04:19 AM   #1530
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by Aydhayeth View Post
Had a look at the wheel collection and do see slight variations of this theme running either 35 offset or 40.
Therefore your +33 and +38 will also "fit". as they are only <5mm difference.
Old 06-20-2013, 04:24 AM   #1531
Ahhhhh ... many thanks ... the newb is definitely showing!
Last edited by TrogDor the Burninator; 06-20-2013 at 04:29 AM. Reason: Found the right PCD part ...
Old 06-20-2013, 04:53 PM   #1532
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Car dropped 1" Tarmac Coilovers, 18X9 +40 wheels.
245/40 tire fits? I wanted 245/35, but the difference in price is BIG.
Old 06-20-2013, 04:58 PM   #1533
OrbitalEllipses
Drives: Attitude
That tire should be around .6" wider than the stock 215/45/17 tire. With that wheel and offset, you have 17mm less inner clearance, BUT the Tarmac coilovers are going to be skinnier than the stock struts/spring perch. Just go outside and measure your clearance now to figure out what 17mm would do.
Old 06-20-2013, 05:16 PM   #1534
Sportsguy83
Drives: Limited BRZ
Ok, thanks for the advice.
Old 06-20-2013, 05:20 PM   #1535
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Will this be good
18x9.5 et 30 all around
Front 225
Rear 245
Old 06-20-2013, 07:51 PM   #1536
ill86
ill86's Avatar
Drives: iG FR-S
245/40 is noticeably taller.
Compare 245/35 and 245/40 from your preferred tire manufacturer. You will see the difference in height. If you are OK with that, cool. :-)
PS for anyone else reading, it is imperative you understand we re talking about 18" wheel/tire.
For 17" a 245/40 is excellent on an 8".
Sportsguy83 (06-20-2013)
Old 06-21-2013, 08:52 AM   #1537
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by whitefrs View Post
Will this be good
Front 225
Rear 245
No. But, if that's what you like don't let me stop you.
Old 06-21-2013, 02:05 PM   #1538
dkrou351
dkrou351's Avatar
Drives: Scion FR-S
I have an Fr-S and was thinking about getting the XXR 18 in. wheels. I was wondering if it would be a dumb idea to go with the +20 offset in the back and the +35 offset in the front. I want a wider look for my rear wheels an a flush look for the fronts. I will also be lowering the car 1 - 1.5 inches. Would that work or not? Anyone know?
dkrou351 is offline   Reply With Quote
Old 06-21-2013, 02:25 PM   #1539
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Wheel width will determine if that offset is appropriate.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 06-21-2013, 04:59 PM   #1540
dkrou351
dkrou351's Avatar
Drives: Scion FR-S
wheels Questions
The wheel width will be 8.75 all around
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
