Old 03-10-2013, 07:28 PM   #15
D1cker
Drives: B9 S4/ND2
I had that as an issue on track, it was alignment.
D1cker is offline   Reply With Quote
Old 03-13-2013, 05:44 AM   #16
XPR Small Block
Drives: Scion Frs
if there sqeeking you may have got them to hot or a pebble stuck it between the pad an rotor quick easy fix pull the pads off take some really coarse sand paper and take the top layer off the pad usually fixes the sqeek
XPR Small Block is offline   Reply With Quote
Old 03-13-2013, 06:17 AM   #17
Mitch
form follows function
Drives: RIP '13 BRZ
1. Check front pads for obstructions.
2. Bleed front brakes to clear bubbles.
3. Check alignment.
4. Pray to Norse gods for clarity in braking.
Mitch is offline   Reply With Quote
Old 03-14-2013, 01:40 AM   #18
g0lden
Drives: 2013 Scion FR-S Argento
you didn't do any brake flushes or anything of that sort have you?
If so possible air in line to one side ?
g0lden is offline   Reply With Quote
Old 03-14-2013, 02:30 PM   #19
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Here's another vote for bleeding. The brakes didn't feel right to me when I got my car, after 500 miles there was no change so I bled them. 2 of the lines had a lot of air in them.
Scenic Driver is offline   Reply With Quote
Old 03-14-2013, 02:35 PM   #20
zoomzoomers
zoomzoomers's Avatar
All seem like possibilities, but I'm going to go with, your rotors are warped. Happens when you have misaligned suspension or you're really hard on your brakes and one side/rotor get's too much heat/pressure. That warps your rotors and you can do one of 2 things. 1. replace that bad rotor or 2. grind or lap (is that the correct term?) the rotor back to spec. Good luck.
Old 04-30-2013, 12:02 PM   #21
BJPLondon
Did you ever get a satifactory resolution to your FR-S brakes pulling to the right problem? I am experiencing the same issue with my BRZ. It's going back to the dealer for the 4th time...
Thanks
BJPLondon is offline   Reply With Quote
Old 04-30-2013, 12:05 PM   #22
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Given your location, I guess it's a long shot, but here goes... Did you drive on salty roads last winter? Salt is no friend to brakes and can (indirectly) cause them to get stuck.
Guillaume is offline   Reply With Quote
Old 04-30-2013, 12:25 PM   #23
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
I actually performed a brake service to clean out the dust and removed and replaced the calipers. The pads are still in 80% material left. The problem went away... My ebrake is prematurely worn.
I'll be back!!
F3dzo is offline   Reply With Quote
Old 04-30-2013, 03:04 PM   #24
BJPLondon
I did drive during the winter, but the problem has existed since day one. The dealer replaced the front-right caliper, which seems odd to me, since it's pulling to the right. In my experience, it's always the caliper ACROSS from the pull that's been the culprit.
Old 04-30-2013, 03:16 PM   #25
BJPLondon
Hey F3dzo Thanks for the feedback. I'll check the e-brake and follow up with the remaining calipers. Did you change out the rear calipers as well? The reason I ask is that during hard braking from higher speeds, the rear end feels a little squirrelly - then it pulls to the right. Not a good feeling. I wonder whether it's the left front sticking or possibly the back.
Old 06-18-2013, 08:30 PM   #26
Carwhisperer
Drives: A lot of supercars.
[ame="http://www.youtube.com/watch?v=OCyJ5-10QyE"]VID 20130616 175852 - YouTube[/ame] my car makes this noise without breaking, just during acceleration or letting off the throttle, and when shifting. Anyone else experience this?
Carwhisperer is offline   Reply With Quote
Old 07-10-2013, 02:57 PM   #27
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Another one for bleeding. I was getting a pull to the left under moderate/heavy braking. I have 29K kilometres, stock everything. There was air in all the lines but the worst was the passenger side which explains the pull. Not to mention the car is way more stable under heavy braking-doesn't seem squirrelly anymore.
Gords_zenith is offline   Reply With Quote
Old 01-12-2015, 08:20 PM   #28
Clott
Clott's Avatar
Drives: 2013 Raven FRS(Sold): Fiesta ST
That clicking Sound I assume you got fixed Carwhisperer? If not, the solution for me at least was having my axle spline replaced under warranty.
Clott is offline   Reply With Quote
The Following User Says Thank You to Clott For This Useful Post:
omegared19 (01-12-2015)
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
BBK,BRAKE PAD,BRAKE ROTORS,MASTER CYLINDER BRACE +MORE @ Source,LLC SOURCE,LLC Brakes, Suspension, Chassis 94 07-07-2013 11:56 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
Cold / Wet weather brake issue? Ingen Scion FR-S / Toyota 86 GT86 General Forum 6 10-29-2012 12:42 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
