| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 | |
Drives: 16 CBS WRX Limited
#30 |
Drives: Ultramarine FR-S
After my second install attempt, I still have the rattles! Someone who has installed the mirror without rattles needs to chime in. I thought I did everything right as far as not over tightening. The problem is that there is some movement in between the big black bracket and the windshield...
#31 | |
Drives: Awesome
calibrated! [ame="https://www.youtube.com/watch?v=CpMQkNbNXRI&feature=youtube_gdata_player"]https://www.youtube.com/watch?v=CpMQkNbNXRI&feature=youtube_gdata_player[/ame] Last edited by Retro86; 06-30-2013 at 03:49 PM. |
| The Following User Says Thank You to Retro86 For This Useful Post: | jacobzking (06-30-2013) |
#32 |
^^^^^ LOL LIKE!
#33 | |
Drives: '13 BRZ Lmtd
mirror adapter plate fix
I also thought I was careful not to over-tighten the two screws into the adapter plate, but mine didn't grab well either. I took it apart and it seemed to me like the adapter plate holes were not a good fit for the screws used. I tried some nuts on the screws and they seemed to be 1/2 inch long 8-32 (but they might also be a nearby metric equivalent). So, to fix my mirror rattle I simply bought some 1/2" flat-head 10-32 screws and a 10-32 tap at home depot (the tap came with a pilot drill bit that I didn't use). I used the tap to properly thread the holes first, then re-assembled using the bigger screws and ta-da, a nice firm grip to the plate. I will see if this permanently fixes the rattle: I expect it will.
#34 |
B R Z
Drives: BRZ 6MT Limited
the mirror actually fell off on me about 2 months ago. it all started with vibrations and kept getting worse and worse. went to the dealership and they fixed it right up. but seems to be happening again. slight vibrations as of now.
#35 | |
Drives: 13' DGM Built FBM BRZ
#36 |
White Guy
Drives: 2005 Subaru WRX STI
Im with delusional. My mirror fell off completely the other day. Tried re tightening them but they wouldn't grab. I ended up drilling out the holes with a #19 bit and tapping with a m5x80 tap. I also bought longer screws and put some nail polish on the threads before install. So far so good.
#37 | |
#38 | |
SLO NO MO
http://www.colonialsubaruparts.com/P...ode=H501SSA040 Sent from my Nexus 4 using Tapatalk 2 |
#39 |
Hook 'em
Back to check in on this thread!
I'm actually in the same group as you guys, the mirror was vibrating while driving and actually started to rattle. I ended up replacing the two black screws that actually appeared to be slightly stripped. Hopefully this fixes the issue otherwise I'll be drilling and tapping the mounting plate as well.
#40 |
I noticed the problem with mines is that the black bracket itself is not tightly fitted onto the windshield. I'll try to post a video to show you guys. If you try moving the mirror slightly pay attention to the movement of the bracket...
#41 |
Drives: '13 BRZ
I used this for a homelink mirror without a hitch. Thanks for the write up.
| The Following User Says Thank You to Colombo For This Useful Post: | TommyFive (07-08-2013) |
#42 |
Drives: Brz WRB - Europe LHD
Only after rebuild a new thread (5mm x 0.8) and 2 new screws it sems all ok, but fitting isn't very fine on the mounting plate. I'll accomodate later.
| Installed Auto Dimming/Homelink mirror | DEC1 | Cosmetic Modification (Interior/Exterior/Lighting) | 71 | 09-10-2020 09:46 AM |
| Fuse Location for Auto Dimming Mirror Harness | tonytduc | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 11-27-2013 08:46 AM |
| auto-dimming mirror | white devil | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 10-05-2012 12:05 AM |
| Auto Dimming Homelink/Compass Mirror Part Number | R0ME0 | BRZ First-Gen (2012+) — General Topics | 5 | 04-19-2012 12:19 PM |
| question about tinted windows with auto dimming mirror... | Norcalmav23 | BRZ First-Gen (2012+) — General Topics | 13 | 04-06-2012 07:37 PM |
