#757 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Somewhat? Forgot my laptop at a buddies house so haven't flashed the rom yet. Unit works and plays music, gotta run the GPS to the vent and then run RCA cables to my new amps. No idea how to do the antenna yet, been reading the last few pages and hope someone figures it out 100% and posts it up
#758 | |
Drives: Toyota 86 GTS
#759 |
Drives: Brz WRB - Europe LHD
Hi , guys...I get a trouble...I insert on T7019 the HDSPA key with Vodafone Sim enabled to surf. On PC and Mac the key works fine...but on 7019 signal is there (blue led light for Hdspa) but it seems no connection is. I set the correct APN...but nothing. I tried on hub and front, disabling wifi and so on, Any ideas..? are there some apk to solve this trouble?
#760 |
#761 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Personally I'm not using a 3G or 4G connection. I simply link it using wifi to personal hotspot on my iPhone. I know others with android phones also tether it to their phones as well. Works much better that a SIM dongle from the glovebox.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
| The Following User Says Thank You to nzer For This Useful Post: | Trap63 (06-16-2013) |
#762 | |
#763 | |
Mine didn't come with a manual although got one later and it details all the setup fields you need to complete so it will work with your provider.
| The Following User Says Thank You to nzer For This Useful Post: | Trap63 (06-19-2013) |
#764 | |
sent by my android car navi
#765 |
Oh well - the tether signal is generally better anyway!
#766 |
Random question, on the stock rom my wifi dongle doesn't work on the rear usb port, only the front.
Haven't tried since I rooted it (will try tonight) |
#767 |
Drives: 5 Celica since 1978.Now a GT86
Trap63 regarding the various connections.
The brake wire, is to be connected to pin 6 on 16pins connector. This will avoid to look DVD and may be change GPS infos during driving this means if brake is not on ie not shielded. Personnaly, although I do not watch video during driving I have connect same directly to shield and is OK.Must point out that on T7019 menu you have the option to use this function or not. Leaving this wire free will certainly have no consequences. For the rear camera, the vidéo plug to use is noted "CAMERRA" this will be switched on when the wire noted reverse is connected to pin 2 on 28pins connector and rear gear is on.In fact, this pin will give 12v when rear is on. Regarding root, I have used the last Hal9k firmware for 2.3.7 with new Google Play. Found on 4pda russian forum. Every things are well functionning, I installed TomTom as GPS and other little things for Android, wifi is also ok. I make various trial on desk as I have not yet the time to put in the car, and this will be the opportunity to have a look on the LEDs. |
#768 | |
I had two hubs and one worked with multiple things plugged it and the other hub didn't. So, if using a hub suggest you try plugging directly in. If tat works then try another hub. Also, make sure you have it plugged in before turning the unit on. If you plug and unplug stuff while unit is on they sometimes won't work.
| The Following User Says Thank You to nzer For This Useful Post: | chris's fr-s (02-13-2014) |
#769 | |
I'll try again with the rear |
#770 |
Drives: GT86
---------------- That shouldnt be the case, is the LED on the dongle flashing? |
| Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) | JPxM0Dz | Canada Classifieds | 2 | 01-20-2013 12:51 AM |
| chinese man sues wife for being ugly: wins | wrxgoose | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 11-07-2012 11:58 AM |
| Counterfeit Chinese Airbags | @Art_Mighty | Other Vehicles & General Automotive Discussions | 11 | 11-03-2012 04:20 AM |
| JDM Vs. KnockOff | SIRvive | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 03-05-2012 06:32 PM |
| Gang of Chinese kick, yell, and drag a little caucasian boy | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 34 | 01-20-2012 11:47 PM |
