Old 06-15-2013, 05:22 PM   #15
Carwhisperer
Drives: A lot of supercars.
Could possibly be the case ^ My car Tweets randomly, no matter what im doing other than being in N sitting still. Once I start moving in gear, slowing down, letting out the clutch I hear a much louder "tweet" "chirp" sounding like it comes from either side of my wheels.
Carwhisperer is offline   Reply With Quote
Old 08-10-2013, 02:55 AM   #16
Xx-Ness-xX
Drives: 2013 SWP 6MT BRZ Limited
I have exactly the same problem, but as far as I know there was no noise when I picked up the car, now the car is only about 790 miles in, and I start hearing that tweet/squeak/chirp noises...
Xx-Ness-xX is offline   Reply With Quote
Old 08-14-2013, 11:59 AM   #17
djdnz
1337
Drives: 2013 BRZ WRB S/C
Yup mine chirps, only with the AC on. The Subaru techs "couldn't hear it". Anyone get any resolution with this one?
djdnz is offline   Reply With Quote
Old 08-14-2013, 12:59 PM   #18
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
It's probably the belt slipping on the pulley when the A/C engages, you could try tightening the belt but then you risk putting undue stress on your pulleys and having to replace them prematurely or worst case actually messing up your seals on the A/C pump and having to buy a new unit.
The pulleys are much more resilient than I just made it sound but be aware that's the balancing act when you install belts. I haven't done this on my car although I can hear the chirp, this worked for my truck which had a similar noise when the A/C was turned on. You could also try some "belt dressing" but I'm not a fan of it.
ineedyourdiddly
Old 08-14-2013, 01:02 PM   #19
ohnoimcaught
Drives: '13 FR-S Whiteout
I have one, noticed it even on the highway at 70 miles an hour with windows up. I thought the noise was coming from my left front wheel well.
ohnoimcaught is offline   Reply With Quote
Help me ID this chirp nix Issues | Warranty | Recalls / TSB 3 02-07-2013 09:00 AM
Chirp (Video Inside) StOpNG0x Issues | Warranty | Recalls / TSB 17 12-13-2012 10:06 AM
Chirp at 70mph markitect Issues | Warranty | Recalls / TSB 15 12-05-2012 09:30 PM
With all these CEL/idle, chirp issues, should I postpone buying? Iixii Issues | Warranty | Recalls / TSB 31 10-11-2012 05:18 PM
Those running e85...do you have idle chirp? jeebus Engine, Exhaust, Transmission 6 09-22-2012 11:39 PM
