#841 | |
Drives: 2013 firestorm FRS
| The Following User Says Thank You to Genomaxter For This Useful Post: | civicdrivr (10-08-2012) |
#842 |
The Ruthless
Drives: 2015 STI Launch Edition
Any plans to apply for a CARB certification for us CA folks?
| The Following 2 Users Say Thank You to Voodoo Rufus For This Useful Post: | drifter (10-08-2012), EN2_Squirrel (10-08-2012) |
#843 |
I talked with avo reps at 86fest yesterday. I cant wait to see the final outcome
#844 |
Drives: subatoy
you guys should go check out the pissing contest they have on the other thread, it's pretty funny.
all I want is 250whp. go AVO! |
#846 |
Drives: 2013 "AVO Orange" FR-S
Hi All
Im Ross from AVO japan Paul is still on the road on the way back from 86fest I said on the Facebook MAP Sensor not MAF Sensor. The stock MAP sensor (Manifold Pressure Sensor) Stops reading at 5psi (.35 Bar) this is no problem for the people who will run up to 5 PSI boost, over this the load deflection dose not calculate correctly. We will be testing a higher pressure MAP sensor (Manifold Pressure Sensor) soon. Regarding the Oil Temp I have done over 500km at the track in NA form over this summer session the last time it was 38c we had a 5 Lap sprit race the water and oil temp did not get over 100c in the race it spiked a bit as it come back in the pits but all cars will after being thrashed for 5 Laps. What we seen in the past with our Time attack Race Car and the D1 86 Drift car we built is after 7000 RPM the Water pump gets cavitation this cavitation air causes the exhaust head to get hot this will increase the water and oil temp and cause detonation. This is Why we never up the RPM limit on Subaru even our Race Car we try for peak toque always. With the Turbo Fitted we will keep a close eye on the water and oil temp and let you know what we find. I hope to be testing at the track on the 16th off this month. The next step this week for the AVO BRZ will be Fuel System testing to see how reliable the fuel system is for the 5 PSI boost. We will test the fuel pump flow in the car and put a external scope to test the injector duty cycle on the direct and port Injectors. There is just not enough information on the logging to get the full information we are after. The turbo kit production run has started at the factory so please give Paul a few days to get back on his feet after the 2600 mile drive and he will have more information for you on this Thanks for your support Regards Ross Wilson |
| The Following 24 Users Say Thank You to AVOturboworld For This Useful Post: | Alienate (10-08-2012), Bomb3r (10-08-2012), Calum (10-09-2012), civicdrivr (10-08-2012), cobrabyte (10-08-2012), djdnz (10-09-2012), domsawww (10-11-2012), DriftEightSix (10-09-2012), drifter (10-09-2012), driver01 (10-08-2012), fasteddy (10-10-2012), FTEIGHTSIX (10-09-2012), industrial (10-09-2012), Jeff86 (10-09-2012), MSTiFK8R (10-09-2012), nix (10-09-2012), No Limit Motorsport (10-09-2012), OjiGeorge (10-09-2012), sandman126 (10-09-2012), Sileighty_guru (10-15-2012), Sportsguy83 (10-09-2012), subatoy (10-08-2012), TheSt|G (10-14-2012), Unleashed (10-08-2012) |
#847 |
Drives: Whiteout FR-S
I saw you had put MAP sensor i don't know why i didn't correct that earlier, working in a parts dept i have people get them confused all the time. I know some people are interested in the exhaust too if you have any info on that.
#848 |
Drives: 22 BRZ
"The turbo kit production run has started at the factory"
Sounds great, thanks for the update. |
#849 |
Drives: Australian GT86
Thanks for the update Ross,
I'm looking forward to hearing from Lee when he has some news on timeframe for instal in Australia! |
| The Following User Says Thank You to Bomb3r For This Useful Post: | Blue86 (10-09-2012) |
#850 |
Drives: DGM BRZ Limited
So if the water pump cavitates around 7k, run a larger pulley and push the engine to 8k. Perhaps Suby was wise here and developed a more efficient pump.
If not, there is a pretty easy way to modify the factory pump to suit higher rpm use while still maintaining good flow at lower rpm. But the good low-end approach is nice and will provide a very fun, responsive, and hopefully reliable setup. 300whp from a t25 size turbo is a riot. Now, I'm not sure if this kit will nail that on pump gas, but having a 300whp powerband makes this car really quick. Deceivingly quick when the powerband starts under 3k rpm and pulls to 7500-8000. |
#851 | |
Pegasus White
Drives: 86
Driving: Pegasus White Manual GTS 86.
#852 | |
#853 |
But to be honest, his car doesn't see long periods at that rpm. Drag racing can cause water pump cavitation too, but you may not see it because of the short burst of speed. Holding that engine at over 7000rpm for extended periods will show cavitation, but you won't necessarily see that in drag racing conditions.
#854 |
Drives: truck and old car
Well, as you can guess the general consensus in the forum is saftey and reliability as we will be foregoing our warranties. With that said... I"m in no hurry here in CA.
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
