AVOturboworld
Old 03-01-2013, 02:31 AM   #2255
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
As posted in the stage 2 thread: http://www.ft86club.com/forums/showthread.php?t=27399
Update:
A more polished Stage 2 by Drift Office was completed today. Made some minor changes here and there, and finished up the hardware of Stage 2.
Here is the dyno of the runs made today. It should be noted, this was run on straight from the pump Costco 92 octane (10% ethanol). We left the big wheels and tires on even though it probably costed us a few percentage points on power figures.
A short video of one of the runs today.
[ame="http://www.youtube.com/watch?v=u4pwCGinyww"]Stage 2 tuning on the AVO Turbo FR-S - YouTube[/ame]
The tune was totally clean, I'm happily surprised at how well it's running at 8psi. This was on stock injectors, stock fuel pump. What has been changed from Stage 1 is the addition of a 7psi wastegate actuator (with a boost controller), high flow front pipe, 2.5" cross-over pipe, 3bar map sensor. This is all flowing into a 2.5" AVO catback as well.
AVOturboworld is offline   Reply With Quote
The Following 5 Users Say Thank You to AVOturboworld For This Useful Post:
Alienate (03-01-2013), Brody602 (03-01-2013), BRZranger (03-01-2013), cmss2000 (03-01-2013), Draco_PR23 (03-01-2013)
Old 03-01-2013, 08:11 AM   #2256
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
i want it to crack 300
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 03-01-2013, 08:17 AM   #2257
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
Looks fine to me....If I can get away with not replacing the pump, injectors and clutch (at least not right away), then that's exactly what I'm looking for.
cmss2000 is offline   Reply With Quote
Old 03-01-2013, 08:24 AM   #2258
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Exciting!!!
that makes me calculate that it's gonna need ~13psi to crack my target 333whp on 93 with a supernice toqrue plateau
I'm in whatever it takes )
Just ship dem kit pls pls pls!!!
MSTiFK8R is offline   Reply With Quote
The Following User Says Thank You to MSTiFK8R For This Useful Post:
Sportsguy83 (03-01-2013)
Old 03-01-2013, 08:30 AM   #2259
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
That's exactly it. The boost can be cranked up to meet the 300whp figure many have, but the clutch, pump, and injectors would need to be replaced at that point.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 03-01-2013, 08:36 AM   #2260
2forme
Which clutch are you running on the STG2 setup?
Old 03-01-2013, 09:12 AM   #2261
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Hmmm...looking to beef up the clutch a little?
chadstyle is offline   Reply With Quote
The Following User Says Thank You to chadstyle For This Useful Post:
2forme (03-13-2013)
Old 03-01-2013, 09:26 AM   #2262
cmss2000
Even at this power level, some people are probably going to need a clutch. Will depend on driving style and your setup. I'm not running big tires and don't abuse the clutch (no burnouts, etc), so I'm hoping to get away without one for a while.
I'm also hoping to avoid some of the other supporting mods that are needed (or useful) when you start making big power...suspension, driveline mods, oil coolers, fans, etc.
Old 03-01-2013, 09:52 AM   #2263
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
@AVOturboworld any idea when the release will be for the stage 2 kit? Also any confirmation on price? and if you can kindly answer this question I had previously asked you http://www.ft86club.com/forums/showp...postcount=2231
Thank you,
Brody
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-01-2013, 11:09 AM   #2264
deucethemoose
Yeah it will all depend on how you use the power. If you're out clutch kicking/drifting/excessive hooning/etc. then you will eat the clutch up quick. Most people right now are not looking to tear in that much on a new car.
Old 03-01-2013, 11:55 AM   #2265
AVOturboworld
Originally Posted by Brody602 View Post
Will the stage 2 be cheaper to buy stage 2 immediately as a complete package as opposed to stage 1 and then upgrading to stage 2?
Possibly - I haven't committed to this simply because it's not finalized. The testing we are doing isn't just for reliability/power, but also to see what components are must have's vs. optional.
Also, the manual generates more whp correct?
Thanks,
Brody
Yes, on the dyno it's showing more power at the wheel, both at the baseline and after the kit. We are simply looking at a slightly larger drivetrain percentage loss is all, and the difference will get smaller and smaller as the power goes up. If you look at the whp gains from baseline to stage 1 on the automatic charts, they were nearly identical in amount of gain.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
Old 03-01-2013, 11:59 AM   #2266
AVOturboworld
I haven't blown out the clutch (yet) but certainly am making a good effort at it! Will be doing more testing (cough cough, drifting practice) this weekend at the elevated power levels. I have to allow that one reason my clutch is staying together is because it's Seattle. The rear end rarely has an opportunity to hook up when the pavement is either slightly wet or extremely wet.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 03-02-2013, 01:36 AM   #2267
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by vubaru View Post
Dat. Torque. Curve.
^^^ Exactly!!!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
vubaru (03-02-2013)
Old 03-02-2013, 02:39 AM   #2268
BRZranger
I want to add that the differences in the runs likely have to do with heat, so the next step is an oil cooler
Worth mentioning that Bob noted that oil temps remained very cool, his words "surprisingly cool." I am not sure I'll need a oil cooler yet, so I'll be monitoring oil temps as we bump up towards stage 2.
I just ordered an avo catch can and should be installed soon... I think you'll want one soon as you see it, very stealth.
BRZranger is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZranger For This Useful Post:
Sportsguy83 (03-02-2013), vubaru (03-02-2013)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
