Old 04-29-2014, 08:55 PM   #813
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by zoth View Post
I think that's the OEM crank pulley bolt. To be re-used
Lol freaked me out. I was like WHAT IS THAT I DONT HAVE THAT lol.
Time to bolt the pulley system up and see how she fits with the oil cooler.
post_break is offline   Reply With Quote
Old 04-29-2014, 09:54 PM   #814
post_break
post_break's Avatar
Ok so I mounted the pulleys. Here's the deal with the forester oil cooler. It fits. Now it's very tight. We're talking 3-4mm tight, but it fits. The nice thing is that the part that is too close for comfort can be ground off with a dremel. The pictures don't do it justice.
The pictures make the bolt look closer than it appears in person.
I will run this setup and have no fear of that nut ever contacting that part of the cooler. If it does I have bigger problems.
So there you go. The forester oil cool will "fit" depending on how you view this gap.
Please note you CANNOT run the hardline from the forester oil cooler. I have standard coolant hoses running down to a T. The hard line goes in the same place as the drivers side mounting bracket. That's what uses those two holes that the bracket utilizes that are magically unused.
This oil cooler setup is about $250 from subaru and paired with an upgraded radiator should perform just fine on the track.
Old 04-30-2014, 01:15 AM   #815
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Cool I'll probably put in my order soon for the OEM Forester oil cooler. I'm not looking forward to the install though since I'm going to have to remove the Kraftwerks S/C plate to make it fit I believe. I'm not 100% sold on whether or not an upgraded radiator would have that big of an effect on the overall cooling though. Seems like there just isn't enough surface area between the coolant and oil to be as effective as all those traditional oil coolers - even with a bigger radiator. My simple minded thought process goes... if it is good enough for a ~300 hp WRX/STI/ForesterXT, this should be good enough for my ~300hp FA20. (Hopefully with the smaller pulley going in at the same time it'd be 300++hp). (I don't track it much - more of a fun DD)
mit_peid is offline   Reply With Quote
Old 04-30-2014, 01:22 AM   #816
Oil coolers are one of the first upgrades done on any WRX/STI that's driven hard...
Old 04-30-2014, 01:44 AM   #817
mit_peid
Boosted Noob
mit_peid's Avatar
I guess I'm saying I don't really drive it all that hard. The other option (which is honestly quite likely) is to see if time will bring a thermostatic solution that will be compatible with the KW kit. If I don't drive it all that hard, not even sure if the OEM solution is all that necessary.
Old 04-30-2014, 02:34 AM   #818
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Dude, You beat me to it, I was planning to install the kw kit and OEM oil cooler this week good to know it's working with no problem
glamcem is offline   Reply With Quote
Old 04-30-2014, 09:06 AM   #819
post_break
post_break's Avatar
That's good, we still may need a couple of people to verify fitment. I look forward to seeing it all bolted up together.
Old 04-30-2014, 10:37 AM   #820
glamcem
glamcem's Avatar
I will also install koyo radiator so hopefully I don't run into any fitment issues
Old 04-30-2014, 10:47 AM   #821
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Do you think the spacer is similar to the one Cusco makes?
zoth is offline   Reply With Quote
Old 04-30-2014, 10:51 AM   #822
post_break
post_break's Avatar
The cusco oil cooler is just a subaru part I believe. The only difference is they used a WRX pot, and added a machined aluminum lip. It's like 4x the price too.
Old 04-30-2014, 11:02 AM   #823
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
You can add me to the list. Paid for it yesterday.
Freeman is offline   Reply With Quote
Old 04-30-2014, 11:18 AM   #824
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Originally Posted by KraftWerks View Post
You sure can! That was the point behind the divorced belt system.
I'd like some clarification here. You said that was "the" point, as in there were no other reasons for not running a single belt for the entire system.
So essentially, the system was designed in anticipation of failure?
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 04-30-2014, 11:23 AM   #825
captain_jack
captain_jack's Avatar
No, they also designed the system this way to not use a intake tube that had to bend around the blower and get heat soaked while doing so.
may the schwartz be with you....
Old 04-30-2014, 11:53 AM   #826
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
No system is 100% reliable. User error, installation error, manufacturing faults etc... will happen. Engineering some contingency into the system seems... prudent, no? I mean, Titanic and all...
KKaWing is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
