Old 12-19-2014, 03:48 PM   #2591
xDanger_208x
xDanger_208x's Avatar
Drives:
@KraftWerks you were right. They're cogged.
The smooth pulleys must be crazy loud!
Thanks for your help!
xDanger_208x is offline   Reply With Quote
Old 12-19-2014, 05:03 PM   #2592
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Check your belt tension, what Hz did it come in at?
If the belt is too tight, it can cause the added noise.
Beyond that, the noise will most certainly have increased over the OE but the system is more quiet overall than most of the screw-type chargers out there.
KraftWerks is offline   Reply With Quote
Old 12-19-2014, 11:03 PM   #2593
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Exclamation
Originally Posted by Freeman View Post
If the warranty is a concern then I'd wait it out, because it will most likely void the warranty unless you have a hell of a dealership. I will imagine they'd still warranty things not in the driveline though, so like a window switch or a steering wheel, etc.
If this is the case, what is the consensus on the OFT in the meantime? Is this just a waste of money?
Chad86 is offline   Reply With Quote
Old 12-19-2014, 11:10 PM   #2594
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Yes. The kits come with an ECUTek tune so unless you can sell the OFT for what you paid it's worthless. That's just my opinion though.
Freeman is offline   Reply With Quote
Old 12-19-2014, 11:13 PM   #2595
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You can usually sell it for $50-$100 less than retail pretty easily.
Old 12-20-2014, 05:27 PM   #2596
Barbas
Drives: 2013 whiteout Frs
Did I miss something in instructions, trying to install intercooler and the horn in the way.
Barbas is offline   Reply With Quote
Old 12-20-2014, 06:01 PM   #2597
Chad86
Chad86's Avatar
Drives: Toyota GT86
Exclamation
How difficult is this kit to install for a 'noob' who isn't a mechanic? I am used to modding and adding things to cars, etc. and have experience building computers...should I be getting a shop to install this kit or is it basically plug & play?
Old 12-20-2014, 06:29 PM   #2598
vgi
Drives: frs
another failed belt, probably had it too tight.
vgi is offline   Reply With Quote
Old 12-20-2014, 06:30 PM   #2599
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
I haven't ever done a big mod like a supercharger before. But this kraftwerks kit was very well put together and quite easy to put in.
If I remember correctly all the tools you need come in the basic "92 piece mechanics tool kit" or whatever you can buy from Lowes. I had a very experienced mechanic friend who helped me install the kit. But in all honesty, he was just an extra pair of hands. There wasn't any of his "experience" that was needed when it came to installing it.
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
Old 12-20-2014, 07:05 PM   #2600
Chad86
Chad86's Avatar
Drives: Toyota GT86
Cool
Thanks for the encouraging words. What did you do for your tune? Or do you simply just apply the included tune from Ecutek?
Old 12-20-2014, 07:37 PM   #2601
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
I bought my kit used, so I was on my own for getting a tune. That said, I knew all along that I wanted to get a custom tune for my car. Cause that's the biggest differentiantor, I've heard, with these engines lasting a long time or blowing up.
I went with a remote tune with Mike @moto-east and COULD NOT BE HAPPIER! He was absolutely wonderful to work with and got my car running mean! He even helped me through a problem I had one time with bad gas. Overall, just a great experience with him. 10/10 would tune with him again!
KW V3
Old 12-20-2014, 08:11 PM   #2602
Scracho
Drives: 2018 Subaru BRZ
The instructions seem pretty straight forward and there is plenty of available resources online to help you out. My recommendation is to 1) Take it slow 2) Read 2x, 3x, 4x if you question anything 3) Save the beers till after its installed and your initial test run
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
Old 12-20-2014, 08:31 PM   #2603
Freeman
Freeman's Avatar
And your Initial test run is over
Old 12-21-2014, 12:00 AM   #2604
Chad86
Chad86's Avatar
Drives: Toyota GT86
I keep hearing great things about Moto-East. If they can remote tune, that is likely the route I will take. Thanks!
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
