#1555 |
Professional Smartass
Drives: White Out FRS
I'm on my next revision of the @DeliciousTuning tune and let me just say, throttle aggressiveness based on what map your on is amazing. The tune I have has 1-4 from improved, to on off button.
1 is perfect for daily driving, much less "cmon why am I lugging off the line" and more of perfect launch from a stop sign. 2 is amazing. It's the perfect setup for nailing every single downshift, even 2nd. When you give it a hint you want to go faster it gets the hint and then some. If you let someone drive your car, this is the map you let them use just as long as they don't ride your clutch. I'd call it the clutch eater map because even I was having a little trouble at first. I didn't even try 3-4 because 2 was way aggressive. Going back to my original review of the Delicious tune vs the Vtune, now that they're both 93, and with map 1 gas pedal, they are on the same level when it comes to feel. I have no idea what the power levels are like between them, so please don't draw any conclusions as to which tune has more power. I'm still waiting on the Kraftwerks tune so I'll do a major update on all three tunes once I have them all to compare. Also, I had Bill lower the fan engagement by 10F, this will help with track and summer temps. It's no fix, but it will help when you have the AC off since the engagement is pretty high with no AC. |
#1556 |
Don't forget that MPG is also heavily dependent on the tires and alignment you have.
#1557 | |
Drives: 2022 BRZ Limited
#1558 |
Drives: Whiteout FR-S, Evo 8 RS
Does anyone else have these issues?
Bumper not fitting because the grill is pressed up against the charge pipe. ![]() Had to remove some of the unused clip on the Passenger side headlight housing: ![]() Moulded charge pipe and washer fluid neck fits too tight. Molded charge pipe is pressed up against the passenger headlight. ![]() Thanks.
#1559 |
may the schwartz be with you.... |
#1560 | |
Otherwise, nice install. I've never seen one mounted there.
#1561 |
a little track update: after my tuner (mike from Moto-East Tuning @moto-mike) lowered the fan activation temp ( I think about 7 degrees) my coolant temps were stabilized at 205-206 F and my oil temps never exceeded 257 F ..this might be due to slightly thinner oil I've used this time (5w-30 Motul V300 vs Mobil 1 0w-40)..
here is some track footage from the last weekend's event [ame="http://youtu.be/2JDtUJGLag0"]http://youtu.be/2JDtUJGLag0[/ame]
#1562 |
Drives: A bunch of 'em...
Damn, that looks like a fun little track!
#1563 |
oh it's my favorite track no doubt about it
#1564 |
Drives: frs
#1565 | |
Drives: 2013 BRZ Limited
Sent from my SAMSUNG-SGH-I337 using Tapatalk |
#1566 |
The fittings look like standard ferrule fittings. If they didn't come tightened with the kit, you should be (or should have been) able to open them and shorten the hoses as needed with a braided hose cutter.
Just FYI. |
#1567 | |
They're reusable AN hose ends. You can disassemble them, trim the hose, then reattach the fitting. There are lots of tutorials on YouTube, just make sure you take extra care when cutting the hose because some of the steel from the hose can make its way into the threads and ruin the seal. Overall it's not that hard if you take your time
#1568 |
Well perhaps next oil change ill give that a shot. Thanks guys!
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
