Koji_Online
Old 02-11-2014, 02:30 PM   #393
mfbmike
Drives: 2013 FRS, 2008 R32
Just did this. Holy cow, what a difference. Feels worlds better and much more natural, even mechanically.
I was amazed at how "soft" the clutch pedal feels now in comparison to before. I'm assuming this is normal?
My clutch is now parallel, maybe a mm or 2 above my brake pedal. Plenty lower for me. It's amazing being able to slide my left foot from dead pedal to clutch now with just raising heel slightly whereas before it was completely raising leg. lol.
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
fstlane (02-11-2014)
Old 02-11-2014, 04:29 PM   #394
fstlane
fstlane's Avatar
Drives: BRZ Limited
This is exactly the reason I need to adjust mine. Thanks!
fstlane is offline   Reply With Quote
Old 02-11-2014, 05:53 PM   #395
fatherfork
Fears Hiccups
fatherfork's Avatar
Drives: Toyota badged 2013 Whiteout FR-S
Originally Posted by fatherfork View Post
...So, making this adjustment moves the pedal closer to the floor ..., but in doing so it also releases some of the tension at the top end of the clutch pedal resistance. This is probably why so many have mentioned the clutch feels lighter. ...
I'd suggest anyone wishing to make this adjustment read through the entire thread before committing so you know everything you might encounter. There were plenty of things I'm glad I knew before making the adjusent that I learned from this thread. You'll discover some on your own, but don't work harder than you need to.
fatherfork is offline   Reply With Quote
The Following 2 Users Say Thank You to fatherfork For This Useful Post:
mfbmike (02-11-2014), s0sl0w (01-24-2015)
Old 02-11-2014, 05:54 PM   #396
mfbmike
I read through all 18 pages lastnight (granted, it was at like 2AM lol) and recalled reading that a softer clutch pedal would be a result.
Just wanted to make sure.
fatherfork (02-11-2014)
Old 02-18-2014, 08:20 AM   #397
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Just did this on my 14 BRZ and it is sooo much easier to drive smoothly! I've currently got the clutch slightly above the brake, but will probably mess with it some more once it warms up. It engages pretty close to the floor now, but I'd really like no free play as I'm coming off the floor (only a couple mm of free play right now). Definitely recommend any 86 owner to do this asap!
xxBrun0xx is offline   Reply With Quote
Old 02-22-2014, 02:10 AM   #398
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Originally Posted by artizhay View Post
Your car came stock with 0 free play? Sounds like something of concern. :/
where should the free play be? at the beginning when you depress the clutch pedal, or at the end as you depress it fully?
i have free play at the end of the pedal toward the floor. no free play when i first go to step on it.
i have been smelling my clutch burn, but I've been attributing that to the new car smell.
subiestyle is offline   Reply With Quote
Old 02-22-2014, 06:51 PM   #399
grodenglaive
Drives: asphalt FR-S
both
grodenglaive is offline   Reply With Quote
Old 02-22-2014, 09:43 PM   #400
CoolBReeZe
Canyon Carver
CoolBReeZe's Avatar
Drives: 2013 CBS BRZ Limited 6MT
"Both" in the preceding post is correct.
If your clutch begins to engage just off the floor; the pressure and friction plates don't have enough clearance. Clearance is necessary to keep the clutch from partial engagement when the clutch pedal is fully depressed.
Free play at the top is necessary to keep the throwout bearing from remaining in contact with the pressure plate. Such contact spins and wears the throwout bearing. Heat build-up can also transfer to the diaphragm spring used on most conventional clutches. Excessive heat can result in less plate pressure end eventually; a slipping clutch.
Bottom line for me: clutch engages about an inch from the fully depressed position. Can depress clutch pedal about an inch against spring pressure before the hydraulics engage. Result: I have reasonable clearance between the pressure and friction plates when the clutch pedal is depressed. The throwout bearing does not contact the diaphragm spring on the pressure plate when the clutch is released = a healthy clutch over the long term.
'13 Crystal Black Silica BRZ Limited 6MT | Michelin Pilot Super Sports | Limo tint | WeatherTech mats & cargo liner | LEDs replace incandescents | Rydeen backup camera | LED mirror covers | smoke side markers | cQuartz Finest nano paint protection | full front clear bra | stubby antenna | Euro armrest | Grimmspeed hood struts, MC brace
CoolBReeZe is offline   Reply With Quote
Old 02-24-2014, 04:28 PM   #401
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
So I've had my fr-s since June 2012 and I've got 17.2k miles on it.....just did this easy mod and it's by far the best mod I've done to my car, besides the innovate
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 03-01-2014, 12:33 AM   #402
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Just did it right now super easy clutch feels softer I did 2 adjustments on THE clutch to see where like it I'll keep messing with it on my day off but as of right now it feels way better thanks .. Only thing was I couldn't august the cruise control cause the the wires were twisting and I DIDN'T want to rip anything what do you guys recommend??
el-92 is offline   Reply With Quote
Old 03-01-2014, 12:34 AM   #403
el-92
el-92's Avatar
Adjust **
Old 03-04-2014, 03:00 AM   #404
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Remove the helper spring if you want to get rid of the "softer" clutch feel, totally beefs up the stiffness with it gone.
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 03-05-2014, 07:19 PM   #405
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
This is the easiest DIY!!! I spent more time reading and watching the DIY guide than actually adjusting it. It took less than 2 mins. No joke. Thanks a bunch guys!!!
So well worth that effort.
DrDuquette is offline   Reply With Quote
Old 03-06-2014, 01:05 AM   #406
userjack6880
userjack6880's Avatar
Drives: Raven FR-S MT
.ck
Does this have any other effect other than "stiffening" the clutch feel?
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT
1978 Triumph Spitfire 1500
userjack6880 is offline   Reply With Quote
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
