| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
UCSB!!!
Drives: 2017 GTI sport
Running RX-7 Wheels
If I want to run stock FD rx7 rims, will I need a spacer? They are 16x8 and weight 15 lbs with an offset of 50mm. Sorry I do not know much about wheels.
#2 |
NW Region Moderator
Drives: FR-S No More
Wrong bolt pattern. Your car is 5x100 (five bolts on a 100mm circle) but the RX-7 and most other Japanese sports/luxury cars are 5x114.3.
You would need a spacer/adapter to change the bolt pattern.
| The Following User Says Thank You to DarrenDriven For This Useful Post: | HachiEnam (08-20-2015) |
#3 |
Lurker
Drives: '14 BRZ Ltd 6MT
5x114.3*
Instagram : @brampbell_candon Facebook : Hipster Vision Photography |
| The Following User Says Thank You to shifter907 For This Useful Post: | DarrenDriven (09-08-2015) |
#4 |
UCSB!!!
Thank you guys for replying!
#5 |
NW Region Moderator
Not sure if I had a brain fart or a finger fart, but yes, that is correct. Oops!
| The Following User Says Thank You to DarrenDriven For This Useful Post: | shifter907 (09-08-2015) |
#6 |
Drives: FD
There are two versions of the wheel just FYI. There's a reinforced version that's a little heavier.
Reinforced version on the right.
#7 |
UCSB!!!
Thanks
. But this post was from 5 months ago and I got a set already. Sent from my iPhone using Tapatalk |
| Essex/AP Racing BBK Owners- What wheels are you running? | JRitt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 170 | 04-15-2025 03:48 PM |
| For anyone running Forgestar F14 wheels | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-11-2014 12:52 AM |
| Anyone running 245/45R16 on 16x8 wheels? | stockysnail | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-04-2014 12:15 AM |
| Running 2011-12 STI Limited wheels possible? | brzadmir | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 07-31-2013 06:19 PM |
| What size wheels do you plan on running? | poormans_LFA | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 51 | 04-28-2012 06:30 PM |
