Just the tip
Drivers window grabbing window seal and pushing it up.
Wondering if any of you have had this and fixed it yourself.
"Drivers window grabbing window seal and pushing it up." I'm no longer in warranty and the guy at the dealer has never hear of the issue, nor is he really any help aside from wanting to charge me $ for service I can do myself. So far I haven't had any leaks but on the rare occasion the window doesn't go all the way up, which I have to push the window button to get it to go up the rest of the way. All I really need is a list of parts I need to replace. Ideally I'd like a DIY forum post with pictures but beggars can't be choosers. Thanks ![]() Door open Door closed pic from inside looking up Door closed pic from outside vehicle Door slightly open
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() Last edited by stockysnail; 12-20-2015 at 07:57 PM. |
#2 |
Well, now, @stockysnail , no, I haven't had that problem.
But, if I did, the first thing I would do is check the weather stripping at the top to see if it was deformed (compare it to the other side). If so, I would re-position the deformed part to where it should be and put a hair dryer to it, then let it cool ..... to see if it would behave. Then, I would apply some silicone to the weather stripping around the window (including the groove). Next, use some alcohol to clean the edges of the glass on the window. That might do it ....... ![]() humfrz |
#3 |
I would try what Hum suggests first but if you do want to replace the parts all the part numbers are on page 55 of the attached.
https://www.dropbox.com/s/2z8l2ws64h...UR%20.pdf?dl=0
#4 | |
Just the tip
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following User Says Thank You to stockysnail For This Useful Post: | humfrz (12-20-2015) |
#5 | |
Just the tip
| The Following User Says Thank You to stockysnail For This Useful Post: | Tcoat (12-20-2015) |
#6 |
Just the tip
@humfrz & @Tcoat I added some pictures to the first post. Cleaning the window and weather strip didn't help.
#7 |
Oh that is nasty! Should have been warranty for sure but too late now. I think replacement is certainly in order.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (12-21-2015) |
#9 |
Drives: '13 BRZ
Happened on my car and I brought the issue up to the dealer. They replaced the strip and no more issues
#10 |
Drives: Whiteout frs
Replace or clean glass and use very little vaseline on the areas that the window is grabbing the rubber
Worked for me...... Use very little vaseline!! |
#11 |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Happened to my car, got the weather strip replaced under warranty, and I'm starting to see signs of it again... It's just a stupid design flaw.
I ended up just using 303 Aerospace Protectant on the seals and it wipe off the excess; it works well enough.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#12 | |
Weather stripping should be replaced. Then, I suggest, you slick it up, to minimize the chance of it happening again. humfrz |
#13 |
There's a TSB that includes reprogramming the window logic to cut the indexing in about half. It makes a huge difference. Your window might also be adjusted too tightly against the seal. I've spent a shit ton of time with my door cards off carefully adjusting mine.
I only work until Wednesday. We should get together over the holidays.
#14 | |
Just the tip
| The Following User Says Thank You to stockysnail For This Useful Post: | Ultramaroon (12-21-2015) |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
| Window seal cracking | ironsurfer129 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-29-2014 09:59 PM |
| window seal deforming | mokinbird87 | Issues | Warranty | Recalls / TSB | 33 | 10-31-2014 06:14 PM |
| window seal? | ravenblackfrs | Issues | Warranty | Recalls / TSB | 3 | 01-29-2014 06:12 PM |
| Drivers Side Window (Not Seal) | Mister | Issues | Warranty | Recalls / TSB | 20 | 12-16-2013 03:56 PM |
