Old 08-02-2015, 08:57 PM   #1
trexx0411
trexx0411's Avatar
Drives: 2015 Scion FRS
connectors not plugged in??
So I found a connector on the passenger side up under the glove box that's not plugged in. It looks like it was done purposely it's a brand new car only have had it for 2 weeks. Anyone know what its for?
trexx0411 is offline   Reply With Quote
Old 08-02-2015, 09:12 PM   #2
There are several unused plugs throughout the car. They are for options that not all the cars have. When they go down the line each car is made to it's VIN specifications One could be an FRS the next a BRZ and the the next a European GT. They are not made in batches of the same thing. Since it is actually cheaper to use as many common parts as possible this results in wiring harnesses that have unused fittings.
Old 08-02-2015, 09:44 PM   #3
trexx0411
trexx0411's Avatar
There are several unused plugs throughout the car. They are for options that not all the cats have. When they go down the line each car is made to it's VIN specifications One could be an FRS the next a BRZ and the the next a European GT. They are not made in batches of the same thing. Since it is actually cheaper to use as many common parts as possible this results in wiring harnesses that have unused fittings.
Thats what I assumed it was. Thanks.
Old 08-02-2015, 10:02 PM   #4
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Could be part of the wires for auto folded mirror. 😜
Old 08-02-2015, 10:21 PM   #5
dnieves
Drives: FR-S 10 Series
Are there any pre-existing unused wiring harnesses that can be utilized? Case in point, it'd be cool to have lit doors without having to tap into the wiring for the courtesy light. Speaking of Plug N' Play, is connector behind the radio the same on the FR-S and BRZ? I ask because this is the power source for the BRZ's optional footwell lighting (notice the pattern: I HATE splicing).
dnieves is offline   Reply With Quote
Old 08-02-2015, 10:42 PM   #6
I am sure that some time spent with a wiring diagram a use could be found for some. The big issue would be that you could have the middle of the circuit but nothing on either end. For instance I bet we all have the wires in place for the fog lights but of course there is no switch or lights hooked up to it.
I have the whole wiring diagrams on PDFs at home and will post them up when back there on Tuesday.
Old 08-02-2015, 10:46 PM   #7
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
There's an extra 6 pin connector behind the head unit, I and quite a few others used it to hard wire a dashcam.
Husker BRZ is offline   Reply With Quote
Old 08-03-2015, 07:14 AM   #8
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
It's already been posted...
http://www.ft86club.com/files/BRZwiringi.pdf
Anything worth doing is worth doing twice...
Talus1 is offline   Reply With Quote
Old 08-03-2015, 08:00 AM   #9
extrashaky
Drives: 2014 BRZ Limited
There are a number of empty circuits in the fuse box under the driver's side dash, some switched, some always hot. You can wire directly into them if you're really handy with electrical, but it's really easy just to tap right in through the fuse slots using add-a-circuits.
OFT Keep plugged in without killing battery? Axion Software Tuning 19 06-06-2020 10:30 AM
Found A Connector Not Plugged In bruizerrob Scion FR-S / Toyota 86 GT86 General Forum 14 08-03-2015 06:55 AM
Stock FRS radio harness there but not plugged in? Roadstercycle Electronics | Audio | NAV | Infotainment 1 04-20-2014 04:33 AM
iPhone plugged in via USB not acknowledged after restart OnTheFence Electronics | Audio | NAV | Infotainment 5 08-20-2013 10:47 AM
Are my accessory jacks plugged in? dale.m Electronics | Audio | NAV | Infotainment 3 10-09-2012 12:14 AM
