Drives: Scion FRS
Smells like leaking gas in the car..
I have recently started to smell leaking gas like when you leave a gas stove on. I dont know how to replicate the problem, it comes very randomly. I started to first notice it after a track day. It was pretty hot probably around 20-25 degrees that day. After the track day while I was driving home, I could smell leaking gas. That was about a month ago. Now from time to time I can smell it . It DOES smell like its coming from near where the location of the gas tank is. It usually happes when driving a decent amount of time on the highway. Anyone have this problem? I was thinking of taking it into the stealership for warranty but Just scared to with the few mods that I have.
#2 |
Gas? Dealership or this:
#3 |
Drives: 2014 Subaru BRZ Limited SWP
As long as it's not an aftermarket fuel pump causing a leak, there should be no issue with this being a warranty claim.
Leaking fuel is not safe. Ever. It's a free repair, make your appointment now! |
#4 |
Have you checked around the tank and filler hose? Shouldn't be that hard to track down.. have you done a flex fuel kit?
#5 |
Señor Member
Visconti ever touch your car?
#6 |
Drives: Scion FRS
No tune, I've tried to locate a fuel leak around and can't see. Only thing I have is suspension. Could LCA and that's it. Guess I'll book an appointment. I just hope they don't nail me for my suspension. And I'm scared that they might fuck up my rims
#7 | |
So, is what you're smelling, more like rotten eggs OR raw gasoline ... ?? (you folks didn't know I was that smart .... huh .. ?? ...... )humfrz |
| The Following 4 Users Say Thank You to humfrz For This Useful Post: |
#8 |
hey you, yeah you <3
Drives: 2014 37J FR-S
what humfrz said.
I had that issue on my pickup once @ smog time. Mechanic took catcon off, smacked it, and told me to drive it for like 50miles. Returned after 50 miles, smell gone. ...which reminds me... i need to buy a new one now!
#9 |
Drives: Scion FRS
I am going to try to smell it carefully but from what all my passengers say it does smell like natural gas. I have a track date coming up.......should i avoid it?
#10 |
| The Following User Says Thank You to grinerizer For This Useful Post: | White64Goat (07-08-2015) |
#11 | |
(it could be a leak or your cat conv is messed up) If the smell is coming from the exhaust, my experience is that this happens to my car every now and then ...... usually after a cold start, when I'm backing out of the driveway. Nothing to worry about. If the smell is coming from raw gasoline, I'd suggest you have it looked after ASAP (as suggested above). humfrz |
#12 |
![]() Obligatory visconti reference
#13 |
Drives: 2013 frs
I'm fighting injector issues and #3 has stuck open a few times... stinks like gas in the car as it flouds the engine. If you try too much to start it you can blow away the starter.
Sent from my SM-N900W8 using Tapatalk |
#14 |
Drives: 2013 frs
Injector 3 wire was grounding out and flouding the cylinder. Gas lock blew off the starter but everything is fine now.
| Two of the best smells in the world... | NWFRS | Off-Topic Lounge [WARNING: NO POLITICS] | 24 | 04-02-2015 08:56 PM |
| My oil smells like fuel | HRTROB | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 07-17-2014 10:02 AM |
| Car butt smells | evan | Northwest | 15 | 01-13-2014 10:36 PM |
| Car interior smells like feet. | dem00n | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 12 | 12-29-2013 02:07 PM |
| Oil smells like fuel | SloS13 | Issues | Warranty | Recalls / TSB | 21 | 03-10-2013 11:56 PM |
