Drives: 2013 White BRZ Limited
Transmission - (4th) gear grind
(@ 8k miles) I recently noticed that my trans grinds while shifting into 4th gear. When I'm accelerating very gently at low RPMs, it simply makes the clicking noise you hear when shifting out of reverse. However, it definitely grinds whenever I shift quickly or at higher RPMs... Got a friend to drive it, does the same thing to him. Any ideas regarding what this is or what caused it?
#2 |
Drives: 2014 Subaru BRZ Limited 6smt
Common Problem with a million threads started already. Search using google and you will find some of the longer threads.
To sum up = Bad synchros, bring to dealer, fix under warranty My car goes in Monday for the same problem |
#3 |
Shit. Yours too? Man, I'm sorry about that.
#4 |
| 6th Gear Grind & Replaced Transmission | Bonburner | Issues | Warranty | Recalls / TSB | 45 | 07-31-2016 12:08 AM |
| Grind Into 5th Gear | Since885 | Engine, Exhaust, Transmission | 8 | 01-18-2015 06:47 PM |
| transmission grind in 5th gear | Rocket.BRZ | Issues | Warranty | Recalls / TSB | 7 | 06-30-2014 11:38 PM |
| transmission grind | jbailey8748 | Engine, Exhaust, Transmission | 26 | 05-18-2014 10:32 PM |
| 3rd gear grind | Mo707 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 07-29-2012 08:37 PM |
