Old 12-03-2014, 07:31 PM   #1
ssyed
ssyed's Avatar
Drives: 2013 Frs
OFT - Left it plugged in (3wks) and now car wont start
So for the past 3 weeks, I've left the OFT plugged into the car. Prior to this, I used to unplug it whenever I would park my car but after reading up about the new power saving mode in the recent update, I decided to just leave it plugged in. OFT is updated to the latest firmware.
Every week for the past 3 weeks, I used the car for 5 days and it was parked for 2 days with OFT plugged in. As of today, the car has been parked for 2 days and I go to start it, no go. Thankfully its parked inside my garage and I'm not left stranded somewhere. Last week I started the car after being parked for two days without any issues. No lights or electronics were left on this time when I parked the car two days ago. So my only guess is that it must be the OFT
The reason for my post is to figure out if anyone else has had this experience? If so, to warn others not to leave the OFT plugged in when parking for a few days.
I apologize if this has been mentioned before but I didn't come across anything like this before
ssyed is offline   Reply With Quote
Old 12-03-2014, 07:34 PM   #2
Koa
I face-palmed after the first sentence, and started to conjure up ways to flame you... but after the remainder of the post, it donned on me you're a good guy and that I am a jackass.
gl OP, hope it works out! May this be a good lesson to the folks.
P.S. Would be awesome to have OFT integrated into the HU
Old 12-03-2014, 07:35 PM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The OFT can't possibly keep you from starting your car any more than keeping a code clearing tool plugged in. My guess is that something else drained your battery given the OFTs very minor current draw in sleep mode. Looks like you just need a jump start to get it up and running.
Shiv@Openflash is offline   Reply With Quote
Old 12-03-2014, 11:38 PM   #4
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Yep, also I left mine plugged in for 3 days and it flattened by battery. Had to cancel my plans and trickle charge it overnight. Now I always unplug it if I know I won't drive it within 24 hours.
The Following User Says Thank You to Wayno For This Useful Post:
raven1231 (12-04-2014)
Old 12-04-2014, 12:12 AM   #5
Turdinator
Señor Member
Turdinator's Avatar
I believe in 'low power mode' the backlighting on the screen is still active and using some power.
1974 TA22 Celica
2013 86 GT
Old 12-04-2014, 03:18 AM   #6
JB86'd
JB86'd's Avatar
Drives: JAWS
I also unplug mine when it's gonna be more than a couple days of not driving. I wonder if it's possible for the OFT to be completely off yet still plugged in.
JB86'd is offline   Reply With Quote
Old 12-04-2014, 03:25 AM   #7
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by JB86'd View Post
...I wonder if it's possible for the OFT to be completely off yet still plugged in.
If it can't be done with software I wonder if it could be as simple as adding a toggle switch to the cable that cuts the power wire without having to unplug it every time. It would start back at the start screen instead of keeping its place like it does in low power mode though.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 12-04-2014, 04:23 AM   #8
s2d4
s2d4's Avatar
What's the actual current draw?
Pretty easy to do a calc on how many days it would take to drain the battery.
Old 12-04-2014, 04:25 AM   #9
Wayno
Wayno's Avatar
It's 3.
Old 12-04-2014, 04:31 AM   #10
s2d4
s2d4's Avatar
Originally Posted by Wayno View Post
It's 3.
3A or 3mA?
Old 12-04-2014, 04:32 AM   #11
Wayno
Wayno's Avatar
3 days
The Following 5 Users Say Thank You to Wayno For This Useful Post:
acj47 (12-04-2014), bfsnail (12-05-2014), Jyn (02-25-2015), Kristjan (12-06-2014), troek (12-04-2014)
Old 12-04-2014, 05:54 AM   #12
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Same thing happened to me.
Just had to jump my car and it was good.
I no longer keep it plugged in though.
Old 12-04-2014, 07:52 AM   #13
troek
troek's Avatar
Drives: 2012 Toyota 86
this is all given that you have a full battery. it takes quite a few miles to recharge a battery, and if your constantly driving a couple miles, shuting down and restarting, your battery will always be teetering on the edge of "too weak to crank". wont take too much current draw to push you over that edge.
troek is offline   Reply With Quote
Old 12-04-2014, 08:05 AM   #14
s2d4
s2d4's Avatar
3 days
To flatten the battery in 3 days, it'll need to draw ~1.27A constantly every single hour. Did you measure it with a multimeter?
Not enough to crank as per troek probably makes more sense, I wonder how much it actually draws? Perhaps it's something else like keeping the ECU awake.
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 10:35 PM
filled up w e85 now car wont start..id1000s dw65s jdl kit kingkai23 Forced Induction 8 07-24-2014 11:56 AM
car wont start, winjet to blame?? 7M-King Cosmetic Modification (Interior/Exterior/Lighting) 21 12-29-2013 04:34 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 02:01 AM
URGENT : CAR WONT START DarkCard Engine, Exhaust, Transmission 9 08-01-2013 09:57 PM
